Everything posted by The Scooby
EJ swap under way
y-pipe fit fine, but the cats hit the X-member, but nothing a 15lbs BFH couldn't solve. so today ill just do some finishing touches like readjusting where some things sit so its more visually pleasing, as well as more clearance. then i have to do the RR wheel bearing on my dad's 99 outback.
EJ swap under way
well im running a single port engine, so i have the 98 single port Y-pipe, to the stock 98 cats for now until i can get a test pipe made (eleminates cats) and after that i have a stock flange bolted on with about 4inches of pipe off the end. i plun on running a 2.25inch exhaust and a little muffler in the stock location. i hope to fab that up today at work, as well as finish the bash plate.
New Toy, 88 RX
thats a nice come up, epically with that low of millage. makes me miss my 86.5 turbo 3dr i had.
It lives on
actually for a flux core thats made by chicago electric its a good entry level, since i can weld up to 1/4inch plate together its not bad at all. i would use my lincoln pro-135 mig, but i don't need it just for prettier welds for my bumpers, other people... sure ill use it. but why not the 90amp flux and take a grinder to it like i did to dress the welds, no one will be the wiser.
It lives on
you saw my front bumper i built. thats a 90amp H/F special. if you don't trust it bring it by and ill burn it in for you.
Let's see everyones OFF ROAD light set-up
for now, getting at least another pair for the bumper, as well as some floods off the basket.
A bit of a facelift for my Wheeler wagon
if i remember right its 235/75/15 and a 2inch lift
exhaust
90-94 exhaust is identical. 95-99 exhaust is identical, 93-01 impreza is identical. you will see no gain. and if you plan on lifting it, and going turbo you are waisting your time. a turbo will be no use off road unless you run on dunes for pre-running. you want low end torque, not top end horse power.
What are the best front brake discs?
i know whats alot cheaper, easier to use, and wont wear out... A PARACHUTE and if that doesn't work... spend your money on some cross drilled rotors and have them crack. get some quality brembo blank replacement rotors, and some quality pads, not auto zone junk. this coming from a guy who used to drive the grape vine daily.
AfterMarket thermostat
The Scooby replied to screwbaru2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbuy a OEM or you will be replacing it again within a few weeks/days
is this a VLSD chunk?pics added
both are open, you can tell by the spider gear pin that goes through the middle.
93 2.2 into 96 obw?
ahh yours has a 2.5, then swap in the 93 engine, swap on the 2.5 intake wiring and it should be good
93 2.2 into 96 obw?
use your intake manifold of the 96, bolt it onto the older 93 or whatever year it is, and bolt it into your car. only thing you are gonna run into is that from 90-95 the exhaust was a dual port manifold, on 96+ its a single port exhaust so you will have to find a new from Y-pipe section to match the longblock you put into the car. if you decide to go that route look up Aaron's Auto Wrecking, its a subaru only wrecking yard and they are a vendor on this forum, they can get you set up.
exhaust
GD is right, the only thing you will gain with a new ca-back exhaust is noise, and maybe 1 or 2 hp, nothing you would ever feel.
EJ swap under way
well if it takes 6 days for me to get the wiring, then a day if the weather holds out to do the wiring. then ill get some video's of it running for the first time, then once i finish the exhaust i can get some of it playing off road.
Well shoot. moving from one problem to another Ea81 running hot
check the fan, and if you replace the thermostat put a subaru one in it, take it from my lesson of loosing heat in the worst snow storm we have had in a few years.
SubieTech Grounding Kits
i have the Hyper Ground System from japan on my impreza, it did smooth out the engine idle, lights are brighter, and windows are faster up/down.
EJ swap under way
this can only explain how i feel right now... dunno if thats work safe... but its safe in one way...
Feb 7th Walker Run Scott in Bellinghams Birthday!!!
its lookin like a no on this trip for me, first i don't think ill have the wiring lit alone if i do have it finished, but also i work saturday's
progress with the hatch
the proper way is to swap in the prop valve as well as the rear disk, simply because the factory set up with rear drums doesn't put much pressure to the back because drums have so much more surface area for stopping so the factory used lower pressure to the rear. swap in the prop valve, you have the time and space it looks like.
EJ swap under way
AHHHHHHHHHH I CAN'T WAIT yesterday i was bored and the weather was great so i went and pulled off my front bumper, finish welded and dressed all the welds down. then gave it a new coat of paint and got it remounted last night. i need to get the Hella's mounted and reaimed and that will be done. then this week i still need to fab up a exhaust yet and that will be it. matt does your harness come with the O2 plugs intact so i need to weld in a bung for it? if so that works because i just did that the other day for ************s and giggles. need to collect come more pipe from work today as well as a resonator, i got my muffler so i just need to run the piping and call it a day.
EJ swap under way
i had matt do mine since im kinda in a hurry, if you like i can build a harness for you, but it might take a month or so.
oil light on at idle
The Scooby replied to The Scooby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif it was shorting it wouldn't only do it when the car is warm and only at idle.
EJ swap under way
awesome, i can't wait to get it so i can drive my car again.
EJ swap under way
i hope so, i might have a LSD swapped into her by then, mainly im just waiting for the wiring, thats the big thing, that and to drive it for a few hours first to make sure everything will be ok. but i dunno its looking like i won't recieve the wiring until next week.
