Everything posted by tcspeer
The simple solution
The simple solution and why it works. I know many people here have trouble getting the coolant full and taking air traps out of their Subaru's, they have been many people post about how to solve this problem and most work well. But why remove heater hoses or radiator hoses or loosen vent caps what ever they are. All that needs to be done is remove radiator cap, start the engine when it is cold and turn heater on. The open cap will let the air out just as well as removing hoses. As the coolant circulates you can add more each time it is sucked down. This has worked many times on my Subaru's and I have had two different ones.
Urgent help please. Temp gauge rise and fall quickly
tcspeer replied to vic's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI agree with the shop, I think it is air. Wait until car is cold and take radiator cap off, then start car with heater on and add coolant every time a little is sucked in. Be patient and keep this up until themostart opens.
Any guess what could it be?
tcspeer replied to halyva's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave your ball joints and tie rod ends checked.
Another "knocking" sound thread...
tcspeer replied to Renée96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI thought it sounded a little like a Alt. pully or power steering pully or some other pully with the whine that was there with the knock. Did you check the little adj. pully on the bar that comes down,I think from the A.C. compresser?
could it just be a thermostat
tcspeer replied to dave valiant's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn page three check out the posts that were made by gcleeton
tcspeer replied to dave valiant's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre the front and rear seals leaking? I had a 98 wagon the gauge goes to hot and the heater blows cold when the coolant gets low and air gets trapped. My 98 was very hard to get the coolant right after changing anything to do with the cooling system.
tcspeer replied to dave valiant's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like the common problem of air trap. I did not see your reason for thinking the head gasket was bad. Let the engine cool and take of radiator cap and start engine with heater on put more coolant in ever times the engine sucks a little more down. I would try this first or if you already have I would try it again.
Rear hatch shocks blown
tcspeer replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI replaced one a few years back and if I remember right I think it is called a rear hatch strut. Check with Litha Subaru in Or. for price their # is 1- 866-717-2512 they sell Subaru parts at discount prices. And I get most parts in two days from them and I live in Tx.
95 Legacy Front strut bushings
tcspeer replied to littlegto's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt does sound like the strut mount, it is not hard to change if you already know how to take the strut asmb. out. If you will mark your top strut flange bolt you should not need any alinement after. If you want to check the mount have someone turn the steering wheel back and forth while you look at the strut arm if the mount is bad you should see the arm jump a little while it is being moved. Just compare it with the other side and you will see. Also you can borrow the spring compressors for a small deposit at most auto chains like Auto Zone or O'Reily's. Be sure and mark the orination of the top hat with your spring with a paint marker it does make a difference how it goes back. The top hat is the metal plate that sets on top of the spring.The small hole in the top hat faces the outside of tire when you put it back into car, or the side nearest you if you are standing by tire and looking towards the engine.
1992 Legacy AutoTrans Swap Report
tcspeer replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou done a great job! I can not even dream of doing this in drive way with no help. Me and a freind changed one last spring in a 98 Legacy wagon and we had all of the fancy things to work with and it took us around ten hours, but we wasted around one hour trying to move enough stuff out of the way to get the torque bolts from the bottom which never happened, and we also done one wheel bearing. You are correct the torque bolts are the only hard thing, we poked a rag in the large hole to try and stop bolts from falling down in. You should be fine with the transmission with 116,000 miles I put over 300,000 miles of stop and go driving on a mail Rt. before the one in my other Subaru quit. If I remember correct I complained about those bolts on my post when I finished.
Cam seal / Timing belt mess
tcspeer replied to toni1595's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI see from past post you have a 95, that's good you wont have to worry about the interference of valves and pistons.
opinion on cost
tcspeer replied to rottenhead's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI do not know about the price you got, but if you have a local muffer shop close that has been in bussiness for a few years I would check with them. I have found that they are usually cheaper then the big chain places and the small shops that do lots of difference things.
Antenna Mast
tcspeer replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI unpluged mine at around 100,000 miles and it worked fine until I had way over 300,000 miles on it, with no noise at all. Now it has finnaly been broke from hitting to much brush and limbs but the same outcome would have happened if it was going up and down, because the only time it was down was when it was sitting. If you find a good deal on new ones let me know because I need one also.
Antenna Mast
tcspeer replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNipper, if the sound is the only problem just run it to the top even if you have to use your hand to help it get there, then remove the cover on the inside of back area and unplug the elc. connector at the base of antenna and you will have an antenna like everyone had forty years ago. If you go through a auto wash you can still push it down by hand. Of course if you want to fix it try the junk yard dog search for a junk yard antenna.
Heater stops, engine temp rises
tcspeer replied to gcleeton's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf this is the case then you do have air in the system, you should not have to do anything with the thermostat unless you just want to change it because of age.
How difficult is it to replace a wheel lug stud?
tcspeer replied to entidine's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUnless some of these Subaru's are different then mine, then you would have to press the hub out of the spindle. This would do more damage to the bearing then punching the stud out with a punch and hammer. If you removed the spindle then you would still be hammering the stud out with the bearing in place. However mine is a 97 year model and I dont know how some of the hubs are on some of these other models, so they may seperate from the spindle more easy.
tcspeer replied to gcleeton's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am in agreement with this, you probably need to add more coolant. When engine is cool take off Radiator cap and start engine with heater on, let idle and keep putting more coolant in every time some is sucked down. Their is other ways to do this but this has worked for me. This process will take some time.
How do you reset a CEL (Check Engine Light)
tcspeer replied to WANTONSOUPGUY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPull both cables + & - I had to do this on my 97 some times to clear the codes. Sometimes pulling the - will work some time I had to pull both. Wait about 30 min.
Engine Installations
tcspeer replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor those who might like to know I also checked CCR and found their have been no complaints in the last 36 months.
tcspeer replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo typo, the report is here, www.dallas.bbb.org/commonreport.html?bid=19000630&language=1
Question
tcspeer replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI dont remember where the EGR valve is mounted but CCR told me I would have to bolt my intake onto the new engine so maybe this will take care of that. Dont the EGR send the exhaust gas back to the intake? I still have a few days to change my order with CCR so I hope to have all of the information I need to make the right choice, I do not want the interference engine of the 97 if I can by pass it with no problems.
Question
tcspeer replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy 97 has the exhaust coming down on both sides of the engine also. I have been told by Litha Subaru and C.C.R. that I can make this swap from 96 to 97. Litha told me that there would be some issues swapping a 95 to 97 I did not ask them why, maybe someone here knows.
tcspeer replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey have over 80 complaints in the last 36 months, just think how many people they ripped off that didnt file a complaint.
tcspeer replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI agree, this was my thoughts on this and I dont have any problems going to court in fact me and Best Buy have a date for court within the next 30 days.
Question
tcspeer replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey said it would work, but I like to get second and third opinions, I figure someone here has already tried it and knows for sure.
