- 91 ej 22 maxacy
1984 GL Wagon Fwd Build
Yes indeed, the EA82 tank is somewhat different, also the mounting bolt holes are different IIRC. Also the sending is on top vs on the back. Which is why I had to source an EA81 tank for my build. :cool:
My '83 GL: The Ski Wagon
Picked up a EA81 Chilton from Matt today, thanks man!
That'll be a fitting color for it! Can't wait to see it after paint.
Finally found the Dually Coupe'! Love this car. Madmaxish :cool:
what rims are on my car
Every Subaru 4x140 wheel, listed here with names and photos. http://www.indysworld.com/80s/general/wheels/wheels.html
Or just redrill the 4x140 hubs to 6x139 and run any 6-lug wheel on the market (Give or take) Write-up/How-to found here. http://www.ultimatesubaru.org/forum/showthread.php?t=132536
Kia Sephia Sporty
Good facts and thank you for all the info! That is pretty amazing it has 150hp, I am guessing torque it about 175ft.lbs? How many speed transmission does the sephia have? 4 with some type of overdrive? WOW! I am very shocked that Kia took over the Elan name from lotus, amazing. I liked the 60s Elans, fun tiny cars.
Here is my return spring set up! I also got the Hubcaps from Skylar today! These are gonna be temp until I get some wheels
Can i see a pic of your weber setup.
Here is my added return spring setup. Works perfect, and the pedal feels great!
Alright good to know.
Going over it with a sanding disc is what I had in mind. Was thinking 200grit, too rough? I'm pretty sure I can still get a new flywheel thru a parts house if needed.
TomRHere's '88 GL 4WD Wagon
Oh goodie! Off come the door cards again, boo!
Fly wheel resurface? Should I bother, or just toss in a new clutch kit? I don't think its needed? When I did drive it, the clutch felt smooth, and no noise. But the disc is indeed worn, 3/4 way out and than it grabs, no much to play with, plus it was slipping. Resurface; Yes/No? Things to know when/if I go to get it resurfaced?
Ah man, it was a Touring wagon too! I've seen that car for a few years, it pretty awesome!
Thanks for the feedback ya'll. We'll see what I do when I get that far, Have I let anyone down on the board yet? No matter which direction I take this car, it will be done well, down to the seams. I'm overly anal as you can see, Afterall, anyone who would wait 2 weeks for some rubber insulated spade terminals from Hong Kong because plain terminals wouldn't look as finished, MUST be an anal Mofo :-p
Those 3 relays on the passenger side strut tower have something to do with the A/C system, maybe one is stuck. I actually have another one of those relays and another one of those solenoid things. The only thing I don't have is an Idle up Valve. Let me know if these would be any use to you. -Tom
EA81 engine year?
1983 GL Wagon 4spd D/R MFG: 04/85 #259432
Correct, a small vac line runs from the red circle, to the idle up valve which is on the intake, its like a 1/8" hose.
the quick weber tuning guide.
Bump for newbies with Webers!
I am going to bump this thread, for good return spring ideas. This is my setup, without a return spring atm. Choke wire.
So just for topic, I keep going back and forth with the idea of going with the Trashwagon paint scheme on this car just because its easy and looks good. I can make it look great as I did the Legacy, I just dunno if I want to spend the time and money of re-shooting it in white and getting the decal remade, I don't know where I'll get the decal made anyhow, or what it will cost. Who will flame me if I were to paint this car like I did the Legacy?
Alas! I got the insulated female spades today. Choke wire complete. I removed the Charcoal canister, I just need to figure out what to do with the tank vent line, but I have a slight idea. Finished brake lines. Still need the soft line and need to make hardlines for each caliper. A better picture of this $250 helper. Dies Eastwood.
Wow! Yeah, the key that should have been with that would have an LED in it. Big square plastic head. Thats cool though and so is that keychain!
This is a cool thread. Vortex, with MX5 fronts and coilovers in the rear! http://www.ausubaru.com/forum/showthread.php?t=20236
