Everything posted by davebugs
Ethanol Free Gas!
If you take into account the pollution, energy, and water used in it's creation ETHANOL POLUTES MUCH MORE. When you simple burn it it produces less than gasoline - true. Just depends on how short sighted you are. Or better put whether a person is argueing one simple fact or the overall impact. I'm more concerned with the overall impact myself. And all this leaves aside the whole disruption to all crop markets, and raising the price of food. I could go on. But I really am trying to resist.... "Ethanol is not your friend" It's a political statement really.
Just a EJ22 thought and request.
davebugs replied to MaddCelt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXKinda funny that you've come full circle. But honestly we were trying to help you all along. You just had to be willing to listen to answers broader than your question. In the end noone here makes or looses money on your decision. And the decision is yours to make. We're just trying to share experience - which is probably exactly why you posted here to begin with. There is lots of good info and posters here. Personally I wish you well whatever you choose. And folks here will continue to answer your questions. Although it's always a little better if you do some research before asking. This is your first Subaru HG experience. Many here have run into this situation many, many times. And that's where all the suggestions came from. To help with the learning curve and options.
Ethanol Free Gas!
Thanks for the link. Iowa votes first so the Ethanol is mandatory now most everywhere. They care about the first primary state. Not our cars, trucks, lawnmowers, weed wackers, chain saws, etc. Their answer is to force us to buy new ones that meet their new standards. Convenient - for them. Here in PA they are also forcing biodiesel standards. Not quite as harmful in small qty's (other than it'll start to eat lots of OEM hoses). But atleast they literally aren't turning food into Biodiesel like corn to Ethanol. Stupid! Stupid! Stupid! Unless you're a corn farmer especially in Iowa or someone running for office grandstanding there. I have always invested in alternative energy and related. CORN BASED Ethanol is plain old stupid! If you do any open minded research you're likely to come to the same conclusion. Appreciate the post. Unfortunately no stations near me at all. But I've bookmarked it and will check back.
OBW wheel question
davebugs replied to Allpar Mod's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPM'd about a set of standard Outback alloys I have here.
davebugs replied to MaddCelt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI do a lot of 2.2 swaps because often they end up cheaper than doing the HG's if someone is paying to have the work done. Actually fixing a 2.5 or swapping a 2.2 are probably within a hundred bucks of each other (after reseal. timing components, etc). The gamble comes down to whether you think the 2.5 has been heated to the point that the rod bearings will fail soon after you spend the time and money on the HG job. So if no rod knock and not overheated I do HG's on the 2.5. If rod knock or it's been overheated bad or multiple times I 2.2 them. If I don't know I figure worst case and 2.2 them. And you gotta admit the 2.2 swap is very easy - that and cost and reliablilty are why it makes sense. So we can all advise on the HG job, getting heads surfaced, timing components, oil pump screws and the like. But if there is evidence of it being "cooked" or already having bearing noise they should be aware of the 2.2 option. JY 2.5's are still over 1k and typically have the same HG isues and a 2.2 is about 350 and the prognosis is better on an engine that you don't know. FYI I fix about half and swap about half based on the above comments.
Did my 97 OBW 2.5's HGs Finally Go?
davebugs replied to rplumbo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm betting that unfortunately you could have saved 50 bucks. And put that towards the HG job or 2.2 swap.
98 S leg OB 2.5 replaced timing belt, gskts---HELP!
davebugs replied to amyksh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome to the USMB. Search for "burping". Odds are great they left a bubble in the cooling system. Now you're probably overheated it and possibly caused other damage. Some things can surface sooner than others. Head Gaskets, head warpage, and the longer failure rod bearings if it's been overheated. Please find a shop that knows Subaru's. It'll lead to happier times with repairs. The cliff notes version is drain the system, fill through top radiator hose.
Three Bond!!
davebugs replied to walczyk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI believe most of use Permatex Ultra Grey instead. But I could be wrong. Easy to find, easy to use, and reasonable price.
ATF Dirtier Than I Thought
davebugs replied to subsince77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere was my thread about the old GF's 06 Impreza ATF. I was shocked at the color as well. http://www.ultimatesubaru.org/forum/showthread.php?t=87092&highlight=impreza
Do I need a new crankshaft?
davebugs replied to walczyk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX2.2 it. Reseal it and drop it in and be good for another 100k. Reseal, timing components, water pump, etc while it's out. Miles ahead in dollars and time, let alone frustration. The 2.2 has been found to be much more durable and longevity is better. HG's on a 2.2 are rare and never seem to have rod knock either. And 2.2's are cheaper than 2.5's. Search here for the swap. You want a 2.2 WITH EGR 95 automatic (they have EGR and standards don't) is preferred because it's non interference and dual port exhaust. If you get 96 or up you'll need it's single port Ypipe.
Help with motor swap?
davebugs replied to lockcuff's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI wouldn't do it without the EGR. Unless the car is basically junk. You'll never get the light out, so unless you check periodically you won't know if you have another code. And you're screwing up any resale value. DOn't forget if it's not a 95 you also need the single port Ypipe off the donor. Searching will help you understand all of this.
where is # on 08 Outback engine?
davebugs replied to davebugs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm in a real delimma on whether to buy this or not. I have no use for it. But it's only got 2 miles!! Intake was off - along with plug wires from him trying to use it in a 2002. So it hasn't been run since sometime in 08 - for the whole 2 miles until the car was put on the car hauler. This guy had originally bought 3 of these. Sold one at the time, the other I don't know if he sold or used, kept this because he had an 07 which he recently sold. Tried to use it in the 02 and didn't wanna break down a new engine just to use the block assuming that would even work. Heads are different and have some sensors on them at the backs of the heads. Heck I can't even physically work in the garage at the present time. And don't work on stuff this new. But how many opportunities like hths come along?
head gaskets and more headgaskets
davebugs replied to logic23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe Subaru's with 2.2 and bad head gaskets that I've bought were mostly 97's and one 98. So this makes sense to me. And I've transplanted an awful lot of 95 2.2's without doing HG's with no issues.
davebugs replied to davebugs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust got back. Found an engraved # under the throttle body on the bellhousing. Has 2 miles on it. Seriousley. Not even dirty. He had the intake off it to try and swap. I beleive he has all the axles too. Car was in a transporter wreck in 08. Has the starter and PS punmp as well, he reused the alternator. Anyone need this?
engine swap
davebugs replied to swilde20's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it's the HLA'a usually MMO followed by a SPIRITED drive of 10-20 miles after it's warmed up solves it. That's what I'd try first.
Going to look at one tonight and the car isn't there. Where is a #? I'm guessing drivers side bellhousing? Looks like interchange is 08 and 09. Anyone here need one of these? Guy tried to put this into an 00 Outback. Says the heads are differrent. I don't know. I've never done any major work on anything newer that an 02 other than maintenance on old GF's 06 Impreza.
Carlise 2011 interest thread
I'll follow the thread. Haven't been to Carlisle in years but used to go every year. I stopped going the year before they broke out the shows so there was a seperate "kids" show. You know - lowered cars, stereo competitions, etc. Then the punks from what I understand got thrown out because they were also interested in fighting and such. I don't think that show exists anymore. I'm still recovering from an accident. I can walk o.k. but my back gets sore quickly. Carlisle is several hours from me in the car to begin with which didn't used to bother me but does now. If I attend Carlisle I'll be sure and stop in if the club has an area. But I wouldn't be attending per se as a club member. That said it would be good to see the club represented.
Wish me luck!
davebugs replied to 98ImprezaWA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood you found one. Did you find one Local and reasonable? Good advice above. The nut and the alignment.
engine swap
davebugs replied to swilde20's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIIR that MAP code is about the lines going to the little gizmo by the pass strut tower as already pointed out. Sometimes I'd get them reversed(sometimes someone would be here and "help"). Or if one is off, or I beleive if you somehow didn't install that filter/diaphram/whatever abotu the size of a quarter in one of those lines.
EJ25 Cylinder Head Bolt Replacement Qs
davebugs replied to walczyk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo new head bolts are needed. Some may show a little rust. And it you thought they "creaked" a bit on removal just wait until you reinstall them. Unless you're doing some kind of major performance build new head bolts are just wasted money. If you go to a parts place that sells Felpro head kits - guess what they'll sell you? A Felpro head kit! On Saturns they had a kit that was mostly a couple of tubes of Permatex and the Orings for the spark plug holes. It's what they have to sell you, not what you need. Or at the best quality/price.
EJ22 w/Manual vs. EJ22 w/Auto
davebugs replied to ericcroll's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf an auto the ATF lines can be a bit of a bugger to discinnect over by the battery. Some years the line has a bracket bolted to the underside of the drivers side head. Later the metal line and bracket was moved to the subframe basically under the battery. The ones where the metal lines are on the subframe are easier. I'd get some hose clamps for the ATF lines and rad hoses. If I remove the rad I usually buy new radiator hoses. I believe the pair are like 25 bucks from Dayco.
davebugs replied to ericcroll's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUltra Grey. It's all I use on Subaru's. At this point I've probably done over 100 engine swap and head gaskets with no issues. I have noticed that it seems to get "harder" after cured than a lot of sealers. The Anerobic stuff is kinda pricey. I don't consider Ultra Grey a step down in quality (if it were I wouldn't use it) but like all sealants you gotta be careful and not use too much. If so it finds it's way to bad places. Oil pump and cam failures that I've witnessed on teardowns.
davebugs replied to ericcroll's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlready listed in the previous post. That plate can be a bugger to get started with the engine in the car.
Parts cost to replace HG in '98 2.5?
davebugs replied to TheSubaruJunkie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI agree - just didn't see it in the thread. The 99's have SOHC. IIR HG's are about the same, but you have another 20 bucks in cam seals for the DOHC. I saw parts list and prices but just reread thread and still didn't see the year stated. But sometimes I "miss" things.
davebugs replied to TheSubaruJunkie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSOHC or DOHC? Price guesses from memory cranks seal 8-10 bucks cam seals 8-10 each oil pump Oring WP gasket NGK's Ultra Grey are a few other things that come to mind. I get my heads checked/surfaced too - about another 120.00
