djmark7
Everything posted by djmark7
how to tell
djmark7 replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
belt is tight put in that lucas ps stuff it helped for bout 12 hours then got stiff again, im leaning more & more towards the rack -
how to tell
thnx all, no noise except when it hits a hard spot you can hear the pump 'strain' a little, fluid is ok -
you shouldnt be taking picture of the speedometer while youre driving :>)
ABS Light
as stated above '98 -
'98 leg 2.2 no vacuum to back pressure transducer, EGR valve does NOT move at all, when i disconnect egr (the side with one line) and suck through hose it seems like theres a hole but no hole in line? there is NO vacuum to either of the 2 lines that go to the one side? is that the norm? also there a electric switch? thats between the BPT and the EGR valve? thnx in advance
i just did my motor on a 98 leg wagon the wiper arm is def shorter than fronts and i think they changed body design in '94 so the bolts might not match up you have to remove arm, take off plastic cap, unscrew nut open back hatch cover (pop-outs) disconnect fluid hose and elec. conn. and reinstall , 3 bolts on motor just make sure you put the bottom rubber on the right way so you can feed fluid hose through it
