Everything posted by subaru360
Not easily. There are many differences with the phase 1 vs phase 2 in the sensors and wiring. You can't just swap the engine harnesses over either. So it could be done, but you'd be cutting and splicing wires, the IAC would be a major problem, it's not the same at all. Oh and the last 2000 I worked on used the older style cam and crank sprockets still. The bellhousing bolts are a non-issue, just leave the 4 extra ones out.
A header listed for a 2.5 will work on a 2.2 dual port.
You could try a header and some cams. Non-turbo subarus aren't exactly known for power.
If the only reason you are doing this is for more power, you will be unhappy. I have driven many 2.2 and 2.5 legacys. I have done the 2.5>2.2 swap many times. You don't even notice the difference in power.
The phase 1 EJ22 intake manifold does not fit Phase 1 EJ5 heads.
Turbos smoke when they go bad from leaking seals, noise is usually the wheel hitting the housing. The forester xt uses the same turbo as the wrx. Lucky for you a good portion of wrx owners upgrade to bigger turbos. You can pick up a low mileage used turbo cheap, the going rate is about $100. Look on http://www.nasioc.com for one.
I've got pretty good at solo trans swaps on the ground. I have a garage with heat and a/c but no lift. To tilt the engine, use a ratchet strap from the pitch stopper mount on the firewall to the a/c bracket. I usually pick the front of the trans up by hand and rest it on the cross member. Then slide a jack under from the front with the handle hanging under the front bumper and start jacking the back of the trans up while holding the front in place, then slide it on the studs. I'm a tall guy with long arms so I can reach both, this might not work for everyone.
The DOHC engines are several inches wider, the heads are a lot bigger. I have had them out of the car sitting side by side. I have also seen an EJ22 in a brat and it is tight, no way a dohc will fit without major cutting. I had several of both sohc and dohc, but we did a scrap run yesterday and got rid of all of them, so I can't get exact measurements for you.
The WRX engine or any DOHC is too wide to fit between the framerails of a gen 1. The EJ22 phase 1 just barely fits, most people even notch the frame for that. For a wrx engine, you'd be cutting half the framerail out. Just something to think about. An RX is the grandfather of the wrx. But forget the rx transmision or any other EA trans behind a wrx engine, it will break. You would have to use an EJ 5 speed. If I was doing this I would buy a complete older legacy or impreza with an EJ22 and a 5 speed and swap the engine, trans and harness in.
I just take the whole spacer off. If you want to plug them, take the pipe out, cut it off flush with the fitting, put a quarter in the hole in the spacer and put the fitting back in.
Murphys Law Strikes Again!!!! Motor Blown
subaru360 replied to Bucky92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I was just thinking that somebody on nasioc in CT is selling an STI wing and trunk I want for my wrx. Maybe somehow we can figure out a way to work that all out, I get the wing you get my engine, meet halfway or something. Might work out somehow. -
I have an EA81 and a subaru gasket set I was trying to sell for $100. I will just give it to you if we can find a way to get it there. Or if you can get the car to me somehow, I'll put it in for you. I can't install it free, but it will be cheap. -
how to install
subaru360 replied to ()__1337_CRAYOLA__()>'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
I did one with pipe like that for somebody, it came out fine. I think he switched to PS eventually and used a combination of u joints for the ps rack.
