Everything posted by subaru360
Will a Outback bumper fit a Legacy GT???
subaru360 replied to ejmartin's topic in Subaru Retrofitting
The cover will fit. You might need the outback grille. The Outback grille is taller than the standard legacy grille. They both mount the same, but if you put a legacy grille on an outback, there is a gap at the bottom. The Outback bumper cover has a dip in the top for the outback grille. I don't know if the legacy gt has the taller grille, I don't think so. You may also need the outback bumper beam, not sure on that, if you are going with aftermarket foglights it might not matter. -
I checked out the pics. Really looks good. What do you use for a heater?
I could do either in a few hours, but, that's just me. I like the outbacks a lot more than leg wagons.
The ouback does have the spacers in between the crossmembers and the body, but you can just put the springs/struts in the legacy. Why not just put the engine from the legacy in the outback?
Need Report from Harry's in Hazleton, ASAP
subaru360 replied to Mikldom's topic in Meet n' Greet. Your USMB Welcome Center
I was at pennsburg today. They only have EJ subaru's. No EA at all. No dual range. I did get a nice 95 EJ22 for $75 plus tax. -
You can use http://www.photobucket.com to host your pics. Signup and upload your pics there and copy and paste the img link into your post on here. I'd like to see more of the car, it looks cool.
Documented: The 1970 FF-1 Project car...
subaru360 replied to Kostamojen's topic in Historic Subaru Forum: 50's thru 70's
Looks good. Hopefully whatever you get fits inside the fenders so you can have the car sit lower. -
Very nice work. I like it.
From a yard that will pull it for you, it's a little high but typical. If you have to pull it, it's way too high. I bet you can find one from a private seller a lot cheaper.
Can you redrill the hubs to a different pattern. I know some people have drilled them to 6 lug. What about other patterns? -
Either of those would look fine on your FF-1. -
Generally for the OBD2 cars 5 speeds didn't have EGR and automatics did. But there were some oddball ones that had the california, new york, maine etc emissions that were 5 speed with EGR. If you're putting the non EGR engine in an automatic, I don't think you will find an ecm for that setup, I don't think that was ever made.
It'll run. You will have a check engine light with an egr code. If you have access to the ecm out of the car you got the engine from, that might solve your check engine light if you install that ecm. As far as the canister lines go, I've done it the other way around. I put one that had the cansiter in place of one that didn't. I put the canister from the donor car in, so it really had 2 canisters, one in the back and one under the hood. Strangely no check engine light issues and everything worked normally.
It would look great if you could find a wheel/tire combo that lets you lower the car slightly, maybe an inch or so. The 185 55 14 kumho sounds like a good choice. I think a wheel that matches the time period of the car would be best, I'll look around and see what I can find. -
Should I get a 360??
subaru360 replied to Flowmastered87GL's topic in Historic Subaru Forum: 50's thru 70's
If we are going to share pics, here is mine and this is the parts car I have -
Ed is a good guy and has helped me out a lot. I would never have got my 360 to the point it is at now without Ed and the 360 club. Selling 360 parts on Ebay will get you kicked out of the club for sure, just the way it is.
