CNY_Dave
5
Everything posted by CNY_Dave
Some 2001's had to have the chain guides replaced early, making the '01 a little less desirable. Unless you are after the trim package or do a lot of highway miles, I wouldn't say chase an H6, but if you do a lot of freeway/over 60 driving it's a useful upgrade. Mine sees almost 100mi a day, and it cruises a bit over 80 still under 3k rpm. Smooth, baby! Dave
Hmmm, if it needs to fit tight against the end of the crank and the face of the sprocket, but could only fit tight against one, I'd pick the sprocket. Filing the nose of the crank might move it back far enough you don't get a good tight (face) fit. If the face of the sprocket is munged, I'd def. get a new sprocket. Dave
I had a situation like that but quite a bit worse- I stuffed a silver metal exhaust donut into the gap and slathered it with that hardening exhaust-repair goo (which is actually contains the stuff they put into the clunkers to ruin the engines). A softer composition exhaust donut would probably not even need the goo. If the flanges are toasted by the time you have to re-do this, those flange savers are like magic. Dave
I would say the global misfires and the lack of good ground are consistent with it being able to idle but not take any throttle. Tracking down a bad/missing ground connection without a wiring diagram will be tough- you are going to have to check all the grounding points that are anywhere near the injector loom, and work backwards into the loom until you find the bad spot. The problem with the ground (if this is the problem) is likely right at the grounding point, very close to it, or where the harness gets chafed/pinched by something. And, you really need to get a working fuel pressure gauge on it- there could still be a problem there. Dave
Carb cleaner dries about as residue-free as brake cleaner, and if you're cleaning just unpainted metal parts, that's about all that matters. But as said, carb cleaner is worse for you and might chew the heck out of rubber, plastic, paint, skin, maybe pads and shoes, and sure as hell will wreck your eyes. Dave
Fuel pump could be giving flow with no real pressure, or pressure with no real flow. Really need a gauge on the rail while cranking. I thought on some subies, if the MAP/MAF went bad it might not run at all, but would run in limp mode if it was disconnected. Also, is tapping the cam (crank?) sensor one of the tricks? Dave
