Everything posted by CNY_Dave
Red dust
CNY_Dave replied to skibumm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLotsa red dust under mine on my '03, and even a good bit on my wife's '05 forester with about 45Kmiles. Dave
Rear wheel not slipping when making a sharp turn
CNY_Dave replied to nuteeter's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf that year has the 'fwd' fuse position, put in a fuse and see if the problem goes away. If it does, the duty C solenoid is probably OK. Dave
How to remove really tight screws
CNY_Dave replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.centralhobbies.com/tools/jis.html Probably only needed for small screws (like on a carb) also: http://www.amessupply.com/products1.cfm?aid=1&cid=D&sid=DE&fid=1404070 Dave
CNY_Dave replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis may only be true with small carburetor screws, but japanese phillips heads are rumored to be 'different', and that an actual j-spec screwdriver makes a big difference. Dave
Loud gunshot BANG '94 Legacy
CNY_Dave replied to porcupine73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDon't forget to wash down the area under the carpet too. It's amazing what a little acid can do. Not as bad as mercury on an airplane, though! Dave
CNY_Dave replied to porcupine73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, that'd be pretty loud! I'd scrub the entire affected area with baking soda and water to neutralize the acid. Dave
Battery Terminal Corrosion...
CNY_Dave replied to heartless's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI remember reading that- theory was that the acid would build up on the engine and start eating the head-gasket from the outside-in. Dave
CNY_Dave replied to heartless's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt stays clean longer than you'd expect, is what I'm saying, even if you rinse all the baking soda off. It's as though it takes a fair bit of buildup to start the corrosion process, and if you get rid of all the acid-y buildup, you won't get any corrosion for a while, without using any spray or goop. Dave
CNY_Dave replied to heartless's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat amazed me about this method is how long it keeps the corrosion from re-forming, even after rinsing the area thoroughly. Dave
thumping when driving from stop
CNY_Dave replied to Suby Skier's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFellow at work has this same car, about same mileage, and just had to do the U joints. You can get the u-joints 'replaced'** and the driveshaft reconditioned with new center bearing for about $550, if you can find a driveshaft shop that knows where to send it. I did find an online shop that claims to do the same, they had various driveshafts in stock. You should be able to google it, or search here for the online shop name. ** replaced, as in it looks like they cut the yokes off and weld on new ones that accept replaceable greaseable U joints. Dave
Removing brake rotors on '01 Outback
CNY_Dave replied to beenaroo_01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLow-end napa pads did not fit well, high-end napa pads fit perfectly and came with new shims. I'd go for at least the low-end ceramic pads. Don't forget to check the wheel where it contacts the hub-rotor, I had a lot of hardened crud buildup that caused some wheel shake and could potentially have deformed the rotor. Dave
Heated mirrors???
CNY_Dave replied to pearlm30's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe mirrors fog when he pulls out of his air-conditioned underground subie lair... Dave
96 Legacy Wagon Hub Bearing or Trans?
CNY_Dave replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, rear wheel drive cars were easy because the big bearing always failed first, and always made more noise when more heavily loaded in a turn. Even my '80 toyota celica was like that. Dave
Rim Question
CNY_Dave replied to Seand's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've heard here there are lots of 15 inch rims that will fit, if you feel up to a little grinding on the caliper body. Dave
CNY_Dave replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe bad front wheel bearing on my '01 was the *opposite* one that I expected based on which turn made the noise worse/better. The bad bearing made *more* noise when I turned away from it, less when I turned towards it. Since the bearings are so close together it has a lot more to do with which race is bad (inner/outer) than which side of the car gets more load in the turn. I had to jack up both fronts, put it in neutral, and spin the wheel with my hand on the strut spring to be sure I had the bad one. Dave
Quick power window question
CNY_Dave replied to Gsir08's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes anything else work with the key off? Wipers? Turn sigs? Radio? Dave
Which bearing?
CNY_Dave replied to pwarcholik's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had a front go bad on mine- When I turned right, the noise went away, when I turned left, the noise got worse. *Normally* this would mean it was the right side, since in a right turn there is more load on that wheel, so you'd expect it to get louder. But (you knew that was coming) it was the exact opposite. Here's what you do- - Jack up both front wheels (or back, if you are checking the backs) - Put the car in neutral, engine off - Spin one front tire while holding the strut spring - Repeat for the other front wheel The bad wheel bearing will show more vibration in the strut spring when spinning the wheel. Putting a long piece of metal (long screwdriver, long socket extension) or long wooden dowel against the strut or strut spring, and against your ear (I like to hold the rod in my hand, fold my thumb over the end, then jam my thumb into my ear) to listen for which is louder if it's not apparent from feeling it. Are you thinking of tackling it yourself? Dave
Two mechanics stumped, anyone here have an answer?
CNY_Dave replied to twojtyniak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have seen descriptions on this site that sound like this- sometimes it's the cam position sensor, and is there also a sensor on the crank? Or is the one on the crank the CPS? Dave
legacy center differential
CNY_Dave replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXManual or auto? Dave
Oil is fuller not emptier ????
CNY_Dave replied to mulcheese's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf an injector leaks just a little, it won't make the car run rich, but will 'dump' into the cylinder(s) overnight. Checking how fast the fuel pressure falls after shutoff is an easy check. Dave
95 Subaru Legacy Wagon --4WD Question
CNY_Dave replied to rainman19154's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTirerack will do it on a new tire from them and ship it to you, or to a garage. Dave
CNY_Dave replied to rainman19154's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTirerack will shave a tire before shipping it to you. Dave
Where is the PCV valve on the EZ30?
CNY_Dave replied to subyfreak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCome to think of it, an H4 PCV valve will have the guts reversed from an H6. H4- threaded end to vacuum, H6- hose end to vacuum. Dave
Snow Tires: Worth it or overkill?
CNY_Dave replied to mrCharlie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLooks pretty good... Dave
CNY_Dave replied to subyfreak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNAPA gave me the wrong PCV valve when I tried to change mine, and the wrong one was too small. No idea what it was for, it looked right, was just too small. The stocker is a stout metal unit, and cleaned up fine with carb cleaner. Dave
