Everything posted by EVOthis
or you could try http://www.clubwrx.net .... I find it extremely hard to believe that the difference between rear drum/disc brakes determines if a Sway bar link will fit or not??..However I could be wrong...the brackets for the links should be in the same spot wheather disc or drum brake...at least on all the Subaru's Ive seen....
Im not sure if you bent the P/S line at all..or even moved it slightly...those lines are extremely touchy...example..I did a radiator and thermostat the other day on an 04 STI and all i did was bend the PS line out of the way a tiny bit...threw the rad. in and started her up to take her for a cruise..the PS was whining like theres no tomarrow...what i found out was there is a small o ring on top of the PS resevoir that ruptures somewhat if that line is even moved the slightest bit...obviously this lets air in the system....personally I would have def. replaced that little o-ring before purchasing a new pump....We see this ALOT.....Just mentioning for future reference...
Did you install a new OEM thermostat when you replaced the H20 pump and t-belt?...personally i would wait for the car to get up to operating temp (according to your dash gauge) and the fans to come on....and than see if they turn off....If they dont turn off....and your 100% sure youve properly purged the system of air...i would look into either a stuck thermostat or clogged radiator...but you said you had clear water flowing out of the radiator so my bet is you have a stuck thermostat...also make sure the upper and lower hoses are hot....How many miles are on this vehicle?
end link ???
EVOthis replied to mike97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
This could also be worn/damaged trailing arm bushings.... -
new subie
EVOthis replied to reelist's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
ah yes..there a few excellant threads on adding a tach to the brighton model..do a search i know youll find something...I just replaced the tach head in my legacy and went soley off the instructions on here...ah here we go... http://www.ultimatesubaru.org/forum/showthread.php?t=2529&highlight=tach+head..as mentioned mileage would be helpful...What kind of upgrades did you have in mind...power upgrades? audio upgrades? etc... -
Where you replacing the struts or something also?...I guess why Question is why did you have to unbolt the strut to remove the trans....when it comes to the axles i find it easiest to undo the castle nut from the ball joint and unbolt the 14mm bolt on the sway bar end link...you can knock the control arm loose and pull the axle out that way....but sorry...as to your question...Personally i would get an alignment for $70..its worth it to me to have proper tire wear....
If your looking into a dealership....I hear rafferty subaru in Newtown Sq...gets a pretty good rep...Personally im a tech down at Matt Slap Subaru In Newark....and not to sound arrogant or anything but from what ive read we get a pretty good rep too...other than a dealership i cant really think of anywhere.....
Man...You have a good selection of cars...a 360, WRX, 91 SS...Id like to see that legacy all hocked up...here is something you might find intresting....was poking around a while ago and thought it was pretty cool... http://video.aol.com/video-detail/drag-race-subaru-legacy-supercharged-turbocharged/528780576/?icid=VIDURVAUT08 ...Romraider is definately the way to go..Thats what i use on my REX...It kind of worries me every time I flash the car with a new MAP....Ive read all i can on Romraider and every tuning aspect of it...Its just you know one wrong move and your looking into costly repairs...especially with a freshly built hybrid 2.5 in it.....any websites or anything you used to brush up with tuning? I absolutely refuse to bring my car in to someone else to tune it...I at least know if I screw it up its in my hands.....
Next time you hear the sound...try and figure out which area of the vehicle it is coming from...Is your ABS light on?...I believe there was a TSB for some of the Valve Relay's sticking in the ABS system for the 96 Legacy..not to sure if that applies or not here...even if it doesnt some of those relays have a tendency to stick...That should throw the ABS light on though...How many miles are on the car?
If your asking my opinion...I would keep the H6...phenominal engine...and only those two problems....well if you had a standard 2.5 03 Legacy I can def. say you would prob have had many more severe issues than a FP and a Belt...HG cough cough...But yes sorry dont mean to get off on a tangent....I would keep the H6....
You should be able to do this yourself...You have to pull the instrument cluster...i believe there is only 1 bulb for the tachometer...however if your going to be pulling the whole cluster i would replace all 4 (1 for each gauge)...Your local dealer should have the bulbs you need...Its a pretty simple job...do a search on here if im not mistaken there was a pretty good write-up about removing the cluster to put a tach head in...that should be of some assistance...
http://www.ultimatesubaru.org/forum/showthread.php?t=90182&highlight=input+shaft+seal Was this the thread you read?...I thought this was a great tutorial...The only thing i can tell you about the bolts on the case is this....i have personally never done this job but i have done countless viscous couplers by pulling the tailhousing off...as for the torque spec ive never really looked one up...for the 14mm's that hold on the tailhousing I just use my 3/8 impact and snug them up...have never had a comeback from one yet...knock on wood...hope this helps....good luck with the job...
