Everything posted by EVOthis
prob. not the best thing to do...but i just rammed a monster pry bar in one of the notches in the center of the pulley and muscled the bolt out.....i had success using a strap wrench holding the crank pulley to break that bolt loose.....i believe the left side of the engine is usually the drivers side (obviously depends on how you look at it though)....
obviously besides the headgaskets.....i would def. thoroughly check out the transmission/center diff clutch packs......and the wheel bearings......than again at that mileage and sitting that long it might also need some of the "tune up" items.....so i would say if your looking for a good project pick her up.......the price is def. right.....
good stuff durania!... cougar-i was also kind of confused with everything (this is my first turbo car and i only have a limited amount of knowledge about the forced induction system but it seemed like it was built rather well......it has a 2.5 sti block with eagle rods and arias pistons.....the 2.0 WRX heads ported and polished with a three angle valve job....and the whole engine resealed and the list goes on and on....and he has the reciepts and everything to back it up....but i do hear what your sayin....not to mention i have 3 points on my license here in PA and my next ticket means i loose my job and my license......so im def. holding back the cars true power.... oh also is the 5 speed used in the 02 wrx the same 5 speed that is used in the legacy.....i was told it was only meant to hold like 140 HP? Sounds accurate......just trying to confirm....
from my experience most subaru headgaskets leak externally....so if you can i would get the car on a lift and take a peek around...if you cant do that take a look at the back of the heads were they attach to the block moreso at the corners....see any oil or coolant? i am assuming you did a complete coolant flush when you replaced the thermostat? air in the system? there is tons of info on here....do a search and you are bound to find something that is helpful......oh! and welcome to the board...
well its going on 2 years that i have had my 96 legacy.....ive replaced damn near everything except the engine and rear diff (which both still work considerably well)....at 195,000 i guess you can expect a few things to wear out.......anyways i got the privalege to obtain a 2002 Subaru Impreza WRX yesterday and i absolutely love it!.....boost is addictive! its got so much more pep than my old EJ22...although it is a cop magnet.....but yeah just thought i would share.....(i tried to upload a pic here....but nonetheless just take a look at my Photos)or avitar.......
WRX engine
EVOthis replied to j2coe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
i would hit up nasioc.com for tuning the stock turbo on the wrx.....alot of smart people on there and so much information..... -
Wax
EVOthis replied to subaruplatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
not that i have used it....but i have heard some very positive things about the new ICE by turtle wax..... -
2002 wrx
here you go....i came across this a few months back..... http://ken-gilbert.com/impreza-manuals .... -
i had a little prob. like this....prob. not as significant as yours though.... my rust hole was about 1 foot long and extended under the panel to the pinch weld....by buddy ended up cutting out all the rust...spraying it with a rust repellant and used some mesh screen with bondo and body filler and primer and all that good stuff....so far it has held rather well.....i cant see the damage but i believe the rocker panels are designed with some sort of safety factor in a collision....(i was reading something on here about that a few months ago).......
if i had this situation happen to me i would find the closest junkyard to just pick up a new hazard light switch(it sounds like something sticky like juice got inside of there and maybe messed with the contacts or something)anyways they are only a few bucks at a junkyard and even if it doesnt fix the problem your switch wont be sticking anymore and you wont have to pry it back out.....just my suggestion.....
what i did to clean my IAC on my 96 2.2 was just undo the hose, start the car (you will have to keep your finger on the throttle a little bit to keep the car from stalling) and spray a little at a time into the hose for the IAC.....(i believe grossgary gave me some pretty detailed instructions on how to do it.....check this out..... http://www.ultimatesubaru.org/forum/showthread.php?t=85247
the only thing i have to say on this subject is....i have had pretty good results with seafoam.....after i ran about 1/2 can through with my engine oil....i think my engine idles and runs smoother than ever......than again 6 owners and almost 200,000 miles i dont think my car ever had a service like that.....just my opinion....
