Everything posted by EVOthis
Need advice: Looking at a 1996 Outback to buy
EVOthis replied to 952.2LX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs im sure others will mention...check for Torque bind...this is like kind of right at the point( age/milegae) where this starts to show up....I had this problem with my 5 speed in my 96...i have also seen more than a handful at work with this kind of mileage and symptoms of TB.....
n00b checking in...
EVOthis replied to dub81's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNice looking car man...Also a WRX owner here...
96 Leg OB overfilled transmission damaged?
EVOthis replied to paulivan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah...wow im kind of surprised that you didnt see any fluid coming out of the filler tube or anything...especially if you only drained the pan...
Clutch Cost
EVOthis replied to subegrl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthey should be fine....personally i wouldnt buy Sachs brand (bad experience)..you can get a Daikin/Exedy replacement clutch kit for pretty cheap...thats the brand Subaru uses anyway so i figure its got to be around the same OEM quality.....
Clutch Cost
EVOthis replied to subegrl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgrossgary- no i work at Matt Slap Subaru in Newark....i think the one in wilmington is Delaware Subaru....
2003 H6 Drive belt question
EVOthis replied to dbullen's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.subarupartsforyou.com Idler Pulley: 23770AA020 Tensioner Assembly:23769AA003 The only thing i have to add is when you get the belt make sure its the same one...there is one that is slightly shorter and one that is slightly longer..the parts dept. mixes them up sometimes...(i believe the smaller one is for when Subaru decided to go to the scroll type AC compressor....)
EVOthis replied to dbullen's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXon this topic...i do notice a clacking noise every single time i do an LOF on H6 that lasts a couple of seconds...i asked our master tech and he said its the timing chian slapping around...apparently most of the time its unharmful....but wow yeah thanks for the info fellas...i will def. be putting a little oil in the filter on the next H6 LOF i do....
Radio - no sound and heated seats not working
EVOthis replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWeve seen this a few times...prob. unlikely in your case because you have the Sub. package...but weve had more than a handful of these come in and all 4 of the speakers are blown...if its possible and you have a good speaker lying around it might be worth it to just take one of the door panels off and test a single speaker.....a long shot i guess...but it happens...
Extreme Dog Walking
EVOthis replied to subaruplatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyea man...it really puts a smile on my face when im driving in the snow and you pull up to a red light next to a Honda or something and the light turns green and you just look back and see them spinning...
EVOthis replied to dbullen's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXman..i did another one of these things today at work...02 outback...oddly enough the tensioner pulley felt pretty bad... and the idler pulley bearings seized and somehow the bolt for it ended up in the undercover...anyways Parts (as best as i can remember) Customer Price= Idler pulley:$40 Tensioner Assembly:$112 ( i checked with the parts. dept. on this and apparently you cant just get the pulley you have to get the whole tensioner assembly..what a rip...) Serp. Belt: $50
93 impreza fsm request
dave1rr put a posting up a few days ago about selling his FSM 4 volume set for 93-96 Impreza's.....maybe try and get in touch with him..he may have some info for ya...
EVOthis replied to dbullen's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhile the belt is off...take a feel/hear/look at the idler pulley...they are notorious for the bearings go bad....weve seen tons of them.....if it doesnt sound/feel to good it might be worth it to replace that pulley along with the belt....i believe its only 1 14mm bolt..and easy as pie to get to.....just a suggestion...
Clutch Cost
EVOthis replied to subegrl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe dealer i work at in Delaware charges anywhere from $800-$1000..give or take depending what is all done besides the clutch kit....
EZ30 H6 Spark Plug R&R
EVOthis replied to Skip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah..i know...expensive little suckers...i saw one of the other techs at work the other day do plugs on on H6 outback...he said it was so much quicker and easier with that little diddy....i did not know Gearwrench was coming out with one...thanks for the link Davebugs...
EVOthis replied to Skip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXweve had great success using this kind of ratchet.... http://toolmonger.com/wp-content/uploads/2007/08/post-snaponswivel.jpg
best trans gearing
EVOthis replied to dirtygst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell as im sure your aware....the WRX transmissions dont get the best rap when it comes to holding power....(yes granted its all about the driver)but weve seen more than a handful shear the teeth right off of mostly first and second gear....Im assuming you want a manual trans....in that case if is possible i think the STI 6 speed and R180 rear end would be a phenominal combo for the H6...i was watching something the other day about a guy named Jeff Perrin who swapped an H6 into his STI and turboed it.... http://mag.subiesport.com/index.php?option=com_content&task=view&id=23&Itemid=69
"Subaru Wants Wind Power"
EVOthis replied to Quidam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXintresting read...thanks man...
Low Pulsating Noise: Wheel Bearing or CV?
EVOthis replied to 211's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell first of all make sure your tires are inflated properly.....how are the condition of the tires? choppy? If i was in your position i would shake down the front end.....3 and 9 for tie rods...12 and 6 for balljoints...and if you have play in both directions well MOST LIKELY its a bad wheel bearing...and if you can get under there too look you could have an assistant shake the wheel and you can see the movement sometimes where the axle meets the knuckle.....
Oil separator Plate leaking, again
EVOthis replied to garthpro's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you replace the rear main seal while you had the clutch out?(not that they are prone to leaking like the Seperator Plate)...Also are you sure its engine oil your seeing? There is a possiblity that the front input shaft seal for the trans is leaking...that could easily get on your clutch and damage it.... I would get under there, clean everything off really well, and drive it for a few days...than pop back under there and see what youve got.....it would be a shame to pull the trans (again) to find out something else is the problem....
running on 3 cylinders
EVOthis replied to mattejb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok...so you already did a compression test.....0 compression?....honestly i would not be driving around like this....seems kind of dangerous to me....especially if the CEL is flashing...that means there is enough unburned fuel getting to the cat. conv. that it could potentially catch fire or blow..lol...is this an EJ22 or EJ25?...also explain when you say highway driving seems OK?
haven't been on here for awhile...
EVOthis replied to strat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlove the WRX the headlights and STI wing really give it that aggresive rally look.....any engine mods?...
Squeaky pump or belt? 07 impreza
EVOthis replied to Drunkmonkey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsupposedly most of the HG problems were gone around 03-04....personally i havent seen one from 05 up with HG problems yet..... 15,000 miles....as you said you did take it to the dealer and they said everythings fine...i wouldnt worry about it to much....the only thing i can think of from the info. you provided is maybe the belt stretched a little bit....we get those comebacks alot....even when you put the new drivebelts on and they feel tight...they loosen/stretch after a few hundred miles or so and need to be readjusted sometimes.....is the steering hard to turn?..also the weather might play a part on the belt noise...
XT model question
EVOthis replied to 2000outback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcant really answer the gas mileage question for you.... check out http://www.cars101.com maybe some info on there.. As for the longevity....as any car it depends how you drive it......most of the blown turbos we see are out of WRX's (kids street racing and such) ....ive seen a few of the 2005 Outback XT's with around 80-100k and to my knowledge havent needed a turbo yet.....it does help that all of Subarus modern Turbo's are water cooled as well as oil cooled.....
1996 Impreza axle nut
EVOthis replied to dave1rr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXman i hear both of you...i think some of them think that just becuase they work at a "Subaru Dealership" they know more than ANYONE that comes in off the street....
2001 Forester P0304, Cylinder 4 misfire?
EVOthis replied to yuba49r's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXalso...not very likely but check the connectors for the fuel injectors are plugged into the correct injector...chased a misfire for months only to find this was the cause....i guess with such a problem one can overlook the simple things....lol
