Everything posted by EVOthis
Leaking Engine oil@ Oil Filter area when cold
EVOthis replied to pearlm30's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi belive is should be a rubber o-ring.....i found it on http://www.1stsubaruparts.com ....i tried to link it but i couldnt.....go to the site go to OEM parts catalog and type in your car 98 subaru forester..... go to cooling, oil cooler, oil cooler (again),gasket....you can view the illustration to make absoultely sure its the right thing....
EVOthis replied to pearlm30's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif its not the oil filter gasket itself....i would suspect the o-ring between the oil cooler and the block....i have a small leak from one of my lines to the oil cooler on the WRX...which i origionally thought was the sandwhich plate o-ring so definately take a look around under there to be sure that is what is leaking....
2004 Subaru Legacy 35th Overheating
EVOthis replied to danko2000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhenever i burp any cooling system i wait for the fans to cycle on and off at least once and make sure both the upper and lower rad. hoses are hot and pressurized..this insures that the thermostat has opened.....sometimes when i get a stubborn air pocket i sit in the car and give it a few high revs and that usually works to get the pocket out....or i turn off the car for a few minutes and let it sit than start her up and that also works sometimes too....
EVOthis replied to danko2000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFirst of all Welcome to the USMB....... as for your vehicle first off make absouletely sure that all the air is burped out of the system......as for your head gaskets...yours should be a SOHC engine..the SOHC are not to difficult to do with the engine in the car...
How to prepare for your Driver's test
EVOthis replied to PAezb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat a carrier that would be...
rear wheel bearing thoughts
EVOthis replied to mellow65's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhen it comes to that lateral link bolt that goes through the knuckle and you dont have air tools available....i have found it much much easier to remove the nut than try and remove that bolt...after the nut is off you can usually just kind of knock the bolt out with a hammer....after you coat the whole thing with PB of course...
Forester Oil Leak
EVOthis replied to subegrl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe seperator plate is behind the clutch and flywheel on the back of the engine...you will have to pull the trans or engine to get to either the rear main or seperator plate...they are literally like right next to each other behind the flywheel....if you do end up pulling the transmission to fix this oil leak i would definately replace the clutch assembly it has to come out anyway.....
How to pull codes from 98 Legacy?
EVOthis replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi bought a cheap one from harbor freight on sale for $39.95 i believe...just enough to pull the code...it came with a book to say what the code was....good enough for now....
Forester Oil Leak
EVOthis replied to subegrl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWow the original clutch at 200k miles? im impressed....if the leak does happen to be coming from the rear main seal...they will most likely pull the transmission....while you are in there i would replace the clutch assembley and also reseal the rear seperator plate and replace the plate with an updated metal one....however i would prob. put money on the leak being the seperator plate and not the rear main seal...they rarely leak on these cars....
Tach. Head 96 LEgacy
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks for all the help fellas...pulled the cluster from a 95 Lego.. and swapped the tach head out...easier than i thought....now im back to cruisin at 2500 RPM in 5th at 60mph.....again thanks!
98 Legacy has a miss between 2-3 speed
EVOthis replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you sure that it only misses when your driving under load? not at idle or anything? is the CEL illuminated? have you seen the CEL come on when you feel this problem happen? if your posative that the plugs are good...than with the vehicle running you could try and spary some water all over the plug wires and see if you notice any sparks....
getting sparkplug wire off of plug sonofa%$#%@
EVOthis replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX+1 ^ also if you can get them down there...i use the boot pliers frequently for this and they work well for me.....
Bought a new Sub!
EVOthis replied to akafriday's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmight be a good time to do like a 60k mile service if no maintaince records were available with the vehicle.....
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks fellas....ive already considered just swapping the cluster but i dont think im going to go that route...im just going to do the tach..the directions i got earlier in the thread are phenominal....thanks again for all your help...hopefully it will be a successful swap...lol..
Several questions
EVOthis replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXusually there is a pin spanner tool that the dealerships use to hold the cam sprocket in place while you loosen the bolt...however i personally have had good luck holding the cam sprocket with a metal strap wrench or (not the way i would recommend) but you could jam a huge screwdriver or pry bar in between the cam sprocket spokes (this has worked for me also but not recommended, try the strap wrench method first) as for the crankshaft bolt....yes there is a special tool to hold the pulley also.....try to look again on the passanger side rear of the engine block near the bellhousing there should be a little access plug which when removed exposes part of the flywheel.... in your 03 you have the new tensioner assembly compared to your 96........with the t-belt still on stick a small pry bar or large screwdriver under the tensioner pulley and rest the end of the screwdriver on the part of the oil pump which sticks out and pry up...as your prying up install a small allen key into the hole to hold the tensioner compressed..... not to sure about trans fluid....but as for the diff....icurrently have valvoline in my 02 WRX and castrol in my 96...i believe both are 75W-90
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks fellas....so a tach from a EJ22 or EJ25 will work 95-99....not that it should matter but does it matter if the donor car is auto or standard?
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXanyone?...lol
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks frag..i managed to find the thread i needed.should have done that first...duh...lol...i do still have two unanswered questions....does it matter if i get the tach out of a manual or auto car? what year legacies will work? thanks again...
Hey guys....well i finally need to replace the tachometer head on my 96 legacy....i believe i read a thread a while ago about how this was done but i forget...my question is is this job pretty straight forward? do i need any special tools or anything?....i will hopefully be picking up a used tach. head from the JY and just wondering what all the tools i need to do it are.....the tach still reads but you can. def. tell it has the wrong RPM's....thanks for your time and knowledge.....also what other years will work....95?97? Just to specify this is just the head not the whole instrument cluster...
gas smell at startup
EVOthis replied to eventoday's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX+1...we had about 3 or 4 of these the other day at work with the temps getting ever colder.....on the p/s or d/s you can kind of see the line between the two intake runners....thats the most common spot they leak, but of course do a visual of the whole system if you can...a little tricky to get to but replacing the hose between the runners( if that is truely the source of seepage) shouldnt take more than about 20-30 min....good luck.. OH, also you can try tightening the clamps but from what ive seen and heard usually you will have to replace the line.....
Subaru won't back warranty or car
EVOthis replied to sdycus10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwow....really sorry to hear about your bad luck....i cant believe after almost 800 miles of driving to diag. they couldnt fix the problem...maybe one day down the road when your Honda dies (not likely..lol) youll pick up another Subie....
Lookie!!!!!!!!!!!!
EVOthis replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthat is wonderful...thanks for the link Nipper!
Oil stop leak?
EVOthis replied to deks69's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat year is the car? mileage?...did your mechanic check the seperator plate on the back of the engine....the plastic ones are prone to leaking...
Ever used a split cv boot repair kit?
EVOthis replied to 95LEGOBW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnot that i would recommend this....but i once new a guy who wrapped like a half of a roll of duct tape around the whole joint because the boot was torn....he said it worked until he could get money to fix it properly......
ABS sound while stopped, problem?
EVOthis replied to eddyj's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmaybe 1 of the systems is the Subaru ABS 5.3 and the other is reg. ABS.....i have no idea the difference.....but ive looked so many parts up for my car and i needed to know what kind of ABS i had....
