Everything posted by EVOthis
Impreza TS or RS?
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah i appreciate that.....we were working on a 2001 impreza sedan the other day and it bore the badge TS..........
evap code...
EVOthis replied to river rat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi would just take out the bulb for the CEL if that is what your concerned about.......obviously though if something else went wrong you would know it........
Impreza TS or RS?
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks.....just wondering
So, finally we got some snow...
EVOthis replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXah colorado winters.......thats the kind of stuff we need here!
Impreza TS or RS?
What exactly is the difference between these two model lines? the Impreza TS and the Impreza RS......
EVOthis replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi felt great this morning when i was taking off from a light and the maxima next to me wasnt moving.....ive got some great traction with the bridgestone blizzaks .....
EVOthis replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know man wasnt it fun......
evap code...
EVOthis replied to river rat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell im not sure your emissions regulations were you are..but here in PA you would fail the state emissions test if you bypassed the EVAP canister..... come to think of it if you go by the book i believe you will fail state inspection also......
One of the coolest Subaur videos I've ever seen!!!
yeah isnt that insane.......that would be fun!
wiper issue
yeah chances are its the switch.....
Gotta love craigslist
EVOthis replied to Bigbusa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgood deal.....yeah they got some good ************ on there......
IAC Valve?
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok.....i got home got my multimeter and found out i could use an inductive pickup to measure my RPM's...so i clamped the pickup around #1 cylinder plug wire and got a reading fluctuating from about 650-850 PRM's fully warmed up in neutral....i dont know how good inductive pickups are for measuring RPM's.....the meter was kind of running around from 650 to 850....my pics wont upload for some reason but my Tach on the dash is in the same exact spot as the pic. i took yesterday......
Trade-in values and advice please
EVOthis replied to terryb52's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno idea about prices but CCR (colorado componant rebuilders) are out there in Denver......from what people tell me they do excellant work and i think they have like a 3 year warranty.......
Tachometer?
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXis it safe to backprobe the igniter connector with some T-pins just for a few moments while i monitor the RPM at idle?
IAC Valve?
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks frag....i know i posted that a while ago....i guess i kind of overlooked the post that explained that.....ill give it a whirl...
IAC Valve?
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks porc....yeah i vacuum gauge showed a healthy engine but idle seems a little high.....im still trying to figure out how to hook up a DVOM on the tach function.......any input would be great.....
IAC Valve?
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks alot porc......i just did a vacuum test and the needle had an almost steady reading at 20 in. hg at idle.....so according to that everything is good.....i also called subaru they said my gasket will be in tomarrow.......if my IAC was having a problem would it have shown up on the vacuum test?.....
IAC Valve?
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdid you get a chance to take a look at engine RPM at idle?
Subaru wallpapers
EVOthis replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXpretty cool pics.....they beat the ones i find on google image search.....
high pitched squealing at startup when cold.
EVOthis replied to mcbrat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
- Tag light replacement on Legacy sedan
EVOthis replied to VT Hokie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell you could give it a try....it may take a while but at least you will know how to do it if it happens again....at least that is what i would do......- high pitched squealing at startup when cold.
EVOthis replied to mcbrat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah i have heard chalk is only temporary......- cel- idle control system failure
EVOthis replied to Wicked_36's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcold can have an effect....what i would do is clear the code and see if it comes back....thats a pretty low mileage car.....- high pitched squealing at startup when cold.
EVOthis replied to mcbrat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXalso you could run some chalk on the belt to quiet it down.....worked for me....- Dukes of Subaru?
EVOthis replied to dwarven1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdefinately broke something...... - Tag light replacement on Legacy sedan
