Everything posted by AWD TURBO!
One last rallycross for the year by ORG
wow this was right in my back yard almost i wish i had good rubber for the rx i would have had some fun i hope to see it there again soon
98 subaru legacy 2.5
AWD TURBO! replied to AWD TURBO!'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah trying to do the not expensive way single mom and looking for work lol story of my life. And i will deff. take GD on his offer just i dont drive in OR so i have no clue as to where im going i know how to get to Jazen beach and thats bout it. And the other thing i found out is the ground wire for the fuel is not connected properly and everything on the car is still stock........ gggrrrrrr..... I feel helpless sorry bout this guys...
AWD TURBO! replied to AWD TURBO!'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXrack, shocks and struts, muffler needs fixed (got leak and rattle), accelerating has dead spot, check engine light on had it fixed now its on again, and when its half tank and under going around corners it kinda stops like the gas is not getting to or through the lines. dont know if any of this makes since these are my observations lived with mechanics my who life but they never had the time to teach, now im stuck. needing help.... so any clues?
What years and models of subaru's can i use on my 1998 subaru legacy GT 2.5, I'm having some issues with it and my man is not here to fix them.
1987 XT: No spark, except one spark while turning off? WTF?
well i had the same problem the crank pickup unit under the metal plate in the disturber cap went bad on mine there junk yard parts there not cheap new i would be cranking the fule pump primed win key on but didn't run win i stopped cranking it would spark all so see it your gutting power at the coil win cranking
Suggestions on Fuel Pumps for EA82T
I would just buy a Walbro 255 o hold on i did $110 the e bay and the parts place pumps are junk! unless there oem i lost an mooter to a faulty pump
Rear Main Seal... What Tha??????
photo??
Ethanol Free Gas!
I found power & cooler egt's using clean gas from the Washougal Mercantile Store & its only the first tank but need to finish tuning good thinking bring up the Ethanol Free Gas thank you for looking out for the rest of us
"New" RX.. uh oh..
i wood toss the rx turbo there junk td04 or td05 is the way to go
Ethanol Free Gas!
humm ive wanted to know if there was Ethanol Free Gas & now i'm going to try to go for a drive to get gas now :-\
Good EA82 headgaskets?
http://cgi.ebay.com/ebaymotors/85-94-1-8L-SUBARU-SOHC-8V-LOWER-GASKET-SET-EA82-EA82T-_W0QQcmdZViewItemQQhashZitem5d2d208d6aQQitemZ400189066602QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories it has the the o rings & other gaskets
EA81T starts then dies; video inside
my bud's ford did something like that he drove all over town tuned out the cam sinner was faulty what kind of FI system does it have could it be the sinner that is under the wire cap?
"New" RX.. uh oh..
well first off good job on the rx you'll love it the 2.2 I like:banana: 5 lug is next or good 13" tires i've found http://www.tirerack.com/tires/tires.jsp?tireMake=Hoosier&tireModel=Radial+Wet&partnum=06HR3WET&vehicleSearch=false&fromCompare1=yes i think the 185's don't grab na turbo you can do with work.... but your not haven a turbo will be a bummer but the ea82t like what i have in mine can be a pain in the butt
Boost
i was running 15 psi & wrx top mount in my turbo 88 gl10 it went 9 months the ring glands gave up from pre det & cheep gas i also have a pile of bad turbos i'm now playing with a modded hi comp ea82t @ 12 psi low with 380cc injectors td04..... its been going for over a year now and i like what it has to give me
Very necessary. NEED ECU from Leone RX and Kruise
hey i have a 88 gl10t ecu & wire harms i can ship
ea81 burns through alternators
just do this there about 15 bucks used at the junk yard or new for under $100 http://www.ultimatesubaru.org/forum/showthread.php?t=100559&highlight=Nissan+Maxima+alt
ea82T injectors
well still tuning but :grin::grin: wow that was worth the $ so i'm fished with the up grades on the rx now i'm going to work on its looks
EA82 Cooling question
a T-stat from Subaru. or your car will overheat
ea82T injectors
well 380cc injectors are in but it runs like poo
my new 98 LGT and the lights are flashing
AWD TURBO! replied to AWD TURBO!'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhahaha but i found out that if i have the key in the run then connect the batt the Subaru alarm will reset and not flash the lights:Flame: ps my 87 rx has more balls then my 98 lgt25 but not for long I'm going to have lots of fun with this car
AWD TURBO! replied to AWD TURBO!'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX& i do not have a remote :banghead:
hey so i have a 98 LGT 2.5 the fuel pump was bad new now but i don't know why the haz lights are flashing win the car is off and win its running with lights off can you guys help
can I run a msd 6AL
yep rat nest i just used the 4 wires +- to the coil & the +- from the harms this box is the digital with the built in rpm limiter set at 5700 i like it
can I run a msd 6AL
yes they work I'm using one
Oil leak fix in a can...
if you have the time I'd tell you to get new valve cover gaskets & cam seals for about 25 bucks wash under the hood really good and if it still gets oil on your muffler you'll need to pull the cam tower to re seal clean it really good i use permatex red hi temp rtv in the big silicone tube caulking gun & put it back in with new o rings most parts people don't know what o ring your asking for and give you one that will be sucked in to the oil hole for the cam & lifters :-\ or you can go for it & use your fix in the can and you can get one of us to do an ej20 swap for you after your lifters stop working:eek: so that is my 2c about that fix in a can
