Everything posted by AWD TURBO!
try to get a TD04 with an intercooler for best use
White RX w/ 5-lug conversion in Kirkland, WA
AWD TURBO! replied to Caboobaroo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
like this one? [ATTACH]7375[/ATTACH] -
seen this & was thinking of finding an older car [ATTACH]7371[/ATTACH]
Seven year storage GL10 turbo ideas
AWD TURBO! replied to swampbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yep something you should do :-\ -
[ATTACH]7370[/ATTACH] no not this one but i did get this one http://boise.craigslist.org/cto/1581642229.html don't know why its still up but it is one of his old Rx's
i have the black one from the private seller was a piece of s**t so lots of work to be Finished
map quest the meet point so every one that wants to convoy knows ware to go & what time
na block with turbo heads
AWD TURBO! replied to AWD TURBO!'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
got the car like this but thank you MilesFox. can i use the na pistons in the turbo block? -
well i have a 87 rx turbo with an n\a block with turbo heads it has a bad hg win i got the heads off i found a crack in the ridge of the cinder[ATTACH]7363[/ATTACH] i don't know if this is going to be a problem or not
well gl has a bad hg. going to take the rx so building the 18t dont know if i will use the na block with turbo heads or fix the one in the gl put in the rx go have hg's just need to do it convoy sounds good
Hill Holder Removal? '87 Brat
AWD TURBO! replied to 94Loyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i have one from a 88 gl if that works -
Driving with drive shaft removed
AWD TURBO! replied to Dr. Fresh's topic in Old Gen.: 80's GL/DL/XT/Loyales...
no i did in my gl10 with the diff lock on -
Transmission is on its way \ going to get an 87 Rx :banana:
EA82T Rear main seal install problem
AWD TURBO! replied to keppelk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
use lock tite and a subaru Rear main seal ... -
87 EA82T Ignition Troubles
AWD TURBO! replied to MysteriousXTC's topic in Old Gen.: 80's GL/DL/XT/Loyales...
mine did the same thing pop the disty apart & replace the cam pick up unit it was bad while your in there make shore that your baring is good -
just if he had a tent as well
good job enjoy the clean burn
some time in Feb sounds good i think i have 3 others going as well 2 gl10 turbo's & just may be a wrx if he does not mess it up.
OK do it! I want to see it I'm now interested
Let's see your LIFTED Soob off roader 2010 edition.
AWD TURBO! replied to ezapar's topic in Off Road
[ATTACH]7294[/ATTACH] it old its rusty but its my subaru -
as soon as i get 350 but yes i did
yes
