Everything posted by Olnick
EJ22 Extremely Low Idle (At Cold Start)
Olnick replied to TheLoyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would encourage you folks to actually remove the IACV from the car and give it a thorough cleaning--did mine 6 years ago and it's been idling perfectly ever since! And it's so satisfying to see the dirt and gunk flow out of it as you spray and turn the cylinder!!! Also clean out the air line feeding the IACV and replace the PCV. Happy wrenching.
Hello from south central ohio
That is so nice to hear, especially in today's world. Kudos to the dealer and congrats to you for "getting her done." Now get out there and enjoy that lovely Subaru!!!
Obscene Mileage for my 2.2
Olnick replied to 99lego's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCan't resist. I remember when gas was 18.5 cents per gallon!
1996 Right Hand Drive Legacy,Oil Leak??????
Olnick replied to N8NQU's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCongrats on the new car! A lot of us feel pretty good about "theimportexperts" kit--you can get the belt, idler pulleys and a water pump, all for a reasonable price. And all you need for the oil pump is one o-ring (I'd get it from Subaru dealer) and a tube of Permatex Ultra-Grey. While you have the pump off make sure you Loctite and tighten up the backing plate screws. Try a search on here--there are some good writeups from the past. Good luck Bill! Edit: Agree with porcupine--definitely do the cam and crank seals!
*Colorado Roll Call*
- Under-heating
Olnick replied to Ever Victorious's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou're such a super nice guy John. I hope your wife appreciates you.- Oil leak in cylinder block cast (Pics)
Olnick replied to dballs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAh, the wit and wisdom of USMB. It's why I enjoy this site so much. Thanks Fairtax for your spot-on logic.- Hello!...and my 1st Subaru question....
The search function can be a beast to control sometimes! But it's worth the effort--there's so much great information available here. It's often better to go to "Advanced Search," type in your keywords then, in the lower right, highlight "New Gen Subarus." That will focus your search on similar engines/models. Try it for "torque bind." Good luck.- Spark Plug blew Stripped Cylinder
Olnick replied to skelly's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs that insert copper? Kinda' surprised me when I saw the pic! Josh, maybe you could rent your tool out and recoup some of your investment!- Hello!...and my 1st Subaru question....
No sweat Mike--that's how we all learn! Basically driving with unmatched tires can ruin the clutch/viscous coupling (they're different between ATs and manual trannies) that delivers power to the rear wheels. That results in juddering/shuddering when you try to turn on paved surfaces. It's called torque bind. Try a search here on USMB, there's tons of information about it. Good luck.- Hello!...and my 1st Subaru question....
What heartless said! The common rule is less than 1/4-inch difference in circumference between all tires . . . that's circumference not diameter!- Starter on 06 Legacy
Olnick replied to soloz2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAssuming that starters haven't changed too much since I worked on my '95 Legacy, I suggest you remove the starter and open up the back of the solenoid. Take out the two L-shaped semi-circular copper contacts and carry them with you to a local auto-electric shop--there are a number of configurations so you want to make a visual confirmation! Contacts should be $15 or less. You probably don't need to replace the plunger (the large copper "washer")--just dress the face with emory paper. Ask a local mechanic what auto-electric shop he uses--there's usually a well respected one in every town. If that doesn't work check with Toyota or other major dealers. Or look online or maybe Ebay. Good luck.- 98 OBW radiator swap out
Olnick replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo? What's the trick?- Idle problem!
Olnick replied to abu3li's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome to USMB, abu3li. But you're in the wrong place! Post your questions in the New Gen Forum and you'll get the help you need.- How do I test my rebuilt starter?
Olnick replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust a heads up--there are at least 4 different configurations for the contacts (yes, the first 3 sets I received were the wrong ones!) If possible remove your old ones from the starter and carry them to the shop with you so you can make a visual match.- Subaru Newbe Here
Olnick replied to mwbean's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome aboard, mw. Sorry but there's no such thing as a stupid question! And thanks for your patience--if you work on 777s I suspect you'll be teaching us tricks before long! Now get out there and enjoy that Subaru. What year/model did you get?- 1994 Legacy GT - Repairs & Upgrades, A Build Thread
That's great--YOU get to cast the deciding vote! Sure do! Gold looks a little too gaudy for my taste. A more subdued bronze looks better to me. Pure white is great on the old flat wagon wheels but not on alloys. Black is just plain boring. Silver, charcoal or gunmetal are the proper colors for wheels! (You asked!)- Another What plug thread
Olnick replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo need to apologize! Trying to help you solve the problem helps us all. (That's what's so great about this place!)- Show me your new gen Subis, please!
Olnick replied to Lukas's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhere do you live in Austria, Lukas? We were there last month--stayed in a B&B in Golling, south of Salzburg. Absolutely beautiful. Every morning I'd step outside and felt like breaking into "The hills are alive . . . with the Sound of Music!"- Kinda a silly question..but.
Olnick replied to subie94's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThats probably due to worn bushings in the shifter linkage. PITA job but well worth the effort to replace! Good luck.- 05' forester with disappearing coolant
Olnick replied to whistler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd recommend Roopair Specialties. Dan and Ben are good guys and were very helpful when I dealt with them a few years back. If you do go there tell them "Nick from Hawaii" said hello!- Engine Cuts out exactly at 4,000 RPM after 1st gear. Whats wrong?
Olnick replied to kxracer741's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo way to know 'til you try it. But generally Subarus run much better with the proper new plugs & wires. If they haven't been changed in a long time it's a good investment. Hope it solves your problem.- exhaust vibration sound
Welcome 03Outback. You'll probably get more response if you post your question in the New Gen Forum.- Rainwater leaking out of heater box
Olnick replied to foxgap's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's a heckuva test! Congrats on the fix.- 2004 Impreza Wagon
Olnick replied to methusalah's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHey Ed, I thought you liked the Red Line 75W90ns in the tranny? - Under-heating
