Everything posted by tractor pole
Will this fit an EA82/Loyale?
tractor pole replied to bratman18's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have the Yakima 1A towers on my wagon. If you have the plastic gutter trim you have to place tge tower over the b pillar and rear side windows so the windows don't hit when you close the door. -
D/R Swap + New Clutch (Pics)
tractor pole replied to jj421's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It's engaged as soon as the lever is moved. The lo indicator should be there, I got a center piece of the instrument cluster from a s/r and d/r to swap over on my a/t instrument cluster and both had the lo indicator you just have to hook it up. Give me a day and I can dig up some wire diagrams for you. Take a bright flashlight and shine it on the center of your instrument cluster and you should be able to see the lo Ind. -
Just make sure you are on a loose surface when you test it out. The d/r like to bind up if you engage them on pavement even if it is wet. At least that has been my experience. -
MagnaFlow Y-pipe direct replacement
tractor pole replied to r81gsr95's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I am not sure what part of seattle you are on but airport welding and exhaust in snohomish did my cat back and they were a fair price and really good work. Ben -
who/where do i get ea to ej swap parts?
tractor pole replied to TOI's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Http://www.infernofab.com has adapter plates also some very nice headers. Ben -
Most good automotive machine shops will be able to resurface it for $30-40. As long as it is not cracked or scorched too bad, I say resurface it, just make sure they machine the step properly. -
check this out... MilesFox has some great videos -
It's a really good feeling right after the first start. I really like how your wagon has turned out! Keep up the good work. Edit: bad grammar, auto correct.
Oh Man, i think im gonna keep it (84 BRAT)
tractor pole replied to Subruise's topic in Members Rides
Nice work! Looks like a good project. -
Did you swap it from an automatic? I did that it was the second best thing i have done to my wagon next to my ej swap.
My '87 Hilux: Safariwagon-IV
tractor pole replied to TheLoyale's topic in Non Soob Cars and Bikes Discussion
wow that didn't take long -
Ok... Caliper piston spinner tool made easy....
tractor pole replied to obk25xt's topic in Shop Talk
Nice! +10 points! -
this is how I tow... I would have no problem towing under 1000lbs properly loaded with my wagon... however you have to consider that since the manufacturer has not set any limits and basically advises against it your insurance could possibly deny a claim if you are at fault in an accident that was towing induced (either improperly loaded, brake failure, etc...). So be careful even if you don't have full coverage the insurance company might try to deny your liability claim for exceeding mfg GVWR. I am not at all an insurance law expert, just my .02
nice! good to hear that it was not harmed.
has anyone swapped a ej25 turbo into their ea82 car
tractor pole replied to tandm1999's topic in Subaru Retrofitting
look here http://www.ultimatesubaru.org/forum/showthread.php?t=130943 -
I tried for hours and was not able to get the pedal box our with the steering column left in or even dropped down, save yourself the pain and just take it out.
EA82 Fan Power Selector Fix
tractor pole replied to ystrdyisgone's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have the same problem. Does anyone know the resistor values? So you could rebuild the resistor pack. Wait i just read tommba's post again... going to radio shack on the way to work. -
Nice M37! My friends is a radio truck version. the hard top is really cool too Ben
Nice Power Wagon! recently I helped a friend of mine pull the motor in his M37 (the military version of that truck). I really would like to have one one day. I also agree that the stock loyale headlights are garbage.
Weber carb refusal to idle?
tractor pole replied to 92_rugby_subie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Fuel pump on it's way out? -
I'll keep an eye out up my way.
Merry Christmas! Already received some stuff for the wagon!! Ben
5MT D/R difficult to get out of 4hi
tractor pole replied to tractor pole's topic in Old Gen.: 80's GL/DL/XT/Loyales...
so I have went to the practice of just using 4wd on snow or mud. dry/wet pavement still binds up and makes it difficult to get out of 4hi.
