Everything posted by svxpert
Changing Mileage
svxpert replied to (goldfish)'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah, just swap clusters. no need to open it up.
Replace What Else With A 2.5L-2.2L Swap?
svxpert replied to the_bard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhy are you only looking for a 95' 2.2 engine?
Crank Pulley Bolt
svxpert replied to jman11's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1. no need to take the radiator out, just take the fans out. that just sets you up for overheating problems. 2. don't need a 5' cheater pipe, the longer the pipe, the less torque you have to work with. use a 2' pipe. 3. use the meathod grossgary gave, "use a hammer and wail on the socket wrench handle". use a punch to jam the flywheel from moving.
problem with puting the new ej1.8 in the 93 impreza
svxpert replied to Dazed Dreamer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou have to turn the crankshaft to get the clutch/torque converter to seat.
92 legacy timing belt tensioner pully bolt break?? need help
svxpert replied to beatloyale1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<here the bolt for it broke off any suggestions on what to do i want some ideas on what to do before i get hacking away at it seems like i have a really big mess on my hands???>> how did the bolt break? was it already broke or did you snap it. please post pics.
Help! Losing coolant! - bad to worse
svxpert replied to lekmedm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<Well, my temp guage often, but not always, fluctuates, sometimes spiking completely to "H" and staying there.>> you let the temp get that hi? thats never good on an engine.
Thermostat Install ?'s
svxpert replied to Lawsonmh15's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<Just did a flush and don't want to have to do another one for a $12 part.>> <<Do I need to "burp" if I catch and re-use? If so, How do I do that?>> how did you do it the first time?
blow off valve
svxpert replied to carlos.is's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhe's "international" so who knows.......
Clutch from hell
svxpert replied to Slegacy96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwho did the $1100 clutch job and didn't replace the throwout bearing? $1100?
blow off valve
svxpert replied to carlos.is's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<does anyone know how to fit a blow off valve... i know its easy but dont want to %^#$ it up!! i hav a 97 legacy gt>> you have a turbo car?
Still can't get the cam sprockets off
svxpert replied to jfm2112's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<Because: uber-special Subaru tools < paying mechanic to use his tools. And if you screw up with homemade improvised tools = paying mechanic to use his tools + paying for parts you boogered up. Simple math. >> yes!
Legacy Turbo ECU Identification
svxpert replied to greggearhead's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXum, what are you trying to do exactly? there is only one ECU pictured there. the other one is a TCU. maybe that can help you?
Help!!!! Seized Camshaft Bolts!!!!!!!
svxpert replied to swingerfunky's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
02' 2.5 interferance question???
svxpert replied to kennyz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<< I do not have a manual for the car, it's too new, nobody makes one yet. >> i have a set of brand new subaru manuals for the 2002 impreza if your interested. $175 shipped. thanks
Total Engine Failure at 107k?
svxpert replied to snaffle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhen was the timing belt done? oil changed/checked at service intervals?
Coolent Mix 70%-30%
svxpert replied to wrongturninwv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<95 Impreza 1.8 holds 6.2 quarts in cooling system. So if I put in 1 gallon Prestone and the rest water I should be set at about a 70 - 30 mix right ?>> the correct way is a 50/50 mixed solution.
2.5 SOHC t-belt pulley advice....
svxpert replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi always tell the customer if it makes noise, replace it. new ones won't spin that freely and are silent. if you can hear them now, they will definently go bad before the new timing belt does (105,000 miles). and that engine is interferance so don't risk it. what are the subaru part numbers for the parts you need? pm them to me. did you ever get the tool?
knowledgeable Subaru mechanic in Jersey
svxpert replied to alexk02's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat do you need done?
What to change during head gasket repair?
svxpert replied to bustle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi would get a new mechanic. your not going to have a head gasket cause a severe oil leak unless the head fell off.
00 limited slip doesn't work?
svxpert replied to 000utback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<One way to find out is get under the car and look at the little metal tag on the cover, i think it says LSD on it. I know there is a post kicking around on how to identify an LSD via the tag.>> no tag on a 00'. subaru stopped putting tags on after the turbo legacy 91'.
All 2.5's need head gasket?
svxpert replied to jbsig2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<I think the number quoted was it involved 12% of the 2.5L (saw it qouted on here some place) .>> 12% of what number? the number produced or the number on some "poll"?
Timing Belt change
svxpert replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<I hope anyone getting this far into their engine knows how to burb the coolant, although I'll be trying it for the first time this fall. Standby for dumb questions...>> (hope) is the key word. if you look at the other timing belt post, you might see why!
High Pitched noises - Timing Belt?
svxpert replied to AlpineRaven's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<The timing belt is too tight? (I had 2nd person to help me to put the belt on but man it was so tight) Or Do I have to loosen the belt tension adjustor as its already on tight spot - I didn't touch that when I did the belt.>> you didn't remove the tentioner and re-set it? if you didn't remove that, then who knows what else could have been skipped in the process.
Timing Belt change
svxpert replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<I STRONGLY suggest you to remove the radiator!!!!!!!! otherwise one tiny mistake the core is damaged!!!!!!!!!!! learnt from experience mate!..>> no reason to remove the radiator. your just doing extra work. that will only give you more problems if you don't know the proper way to bleed the system of air.
Timing Belt change
svxpert replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<Do you believe buying the cam tool makes sense, if one has an impact wrench to remove the (nasty) bolt? Jack >> i haven't seen a impact wrench small enough to fit in between the radiator and engine. have you?
