Everything posted by svxpert
Air in Cooling System
svxpert replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<Today I drove 35 miles without any coolant circulating. If it was not for it being 40 degrees outside I would of overheated. >> there had to be some coolant circulating or you would have overheated, no matter what the temp is. lets start with the basics: how did you fill the coolant system (steps)? did you use an OEM water pump? 50 / 50 coolant water mix?
95 or 96 Sedan/need help Identifying Rear diff
svxpert replied to Gloyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<Wait. I've seen SVXs at the Junkyard that had Viscous LSDs. And surely it was optional on Turbo Legacys and GTs and Impreza RSs?>> yeah, the SVX's had them. they had the 3:54 though, so they wouldn't fit anyway.
EJ25 missing on 2 and 4
svxpert replied to e4620's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<Took it to the dealer for a head gasket job after finding black particles in the coolant, dealer confirmed the gaskets were blown. Drivers side head was warped out of spec, too far to mill, so it was replaced. The passenger side was milled down and put back on. Oddly, the block was almost perfect. The cylinder walls still have the hatch marks from when they were honed. Got the car back and it ran rough and missed on 2 and 4 (the new head). >> how much did the work cost and what dealer was it that messed up your car?
svxpert replied to Gloyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<So now the question is, would this be a VLSD?>> no, LSD's went out in 1991 and came back in 2000
HELP..! 96 OB HG job--solved...!
svxpert replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<I filled coolant per instructions on this forum>> how exactly did you re-fill with coolant?
what would you pay for a twin turbo legacy
svxpert replied to scrapdaddytatum's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<are we all just to poor to have a hot rod.........>> your building a RHD car for someone in the U.S.? i hope its for my mailman, as he's dam slow when delivering my mail!
92 legacy water leak
svxpert replied to vinder1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<The surface was cleaned and perfectly smooth. I only used the copper cote to make sure it would seal good. > on subaru's it either a gasket or a sealant used. not both.
96 EJ22 overheating after tbelt change
svxpert replied to tuner-automotive's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<Pulled in the garage and drained the fluid again. This time I followed the directions found here in USMB.>> theres alot of bad information going around. can you be more specific on how you re-filled the coolant?
External trans filter
svxpert replied to billyfrank's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<Cool. Do you think those filters are the same as the fuel filter just without the hose barbs bent? They look very similar anyway.>> no, i wouldn't. this filter is specifically designed to be an auto trans filter.
oil filter question
svxpert replied to cls1000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell, the two engines you have mentioned are different in some ways. i would use the oil filter that was made for your year engine.
svxpert replied to billyfrank's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<would this hold true for the 1990 external tranny filters as well?? Have a 90 LS wagon with the external tranny filter and would LOVE to give it a fluid & filter change but have not been able to find any part info....filter itself is in pretty rough shape so no numbers to be seen there.>> i have a few new OEM Subaru external tranny filters left. they fit the SVX and the Legacy. $15 shipped to the lower 48. pay-pal accepted. here is a pic:
Temperature guage flakiness
svxpert replied to crazyhorse001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<Symptoms: When in park, idling, the temp guage pegs out within 30 sec. >> you really shouldn't let it get that hot, its not good for the engine.
Good Subaru mechanic
svxpert replied to JREN's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat do you need done?
cleaning an engine on a stand
svxpert replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcover the head / manifold holes and buy 4-8 cans of brake cleaner and have at it. tilt the engine so the residue runs off.
I Need A Read Diff For 97 OB
svxpert replied to subsince77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<I Need A Read Diff For 97 OB >> I have a new 4:11 ratio rear diff. $150 shipped. pics below...
Educated Guesses Needed - Vol. 1
svxpert replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat services have been done to the car recently?
Rear differential question
svxpert replied to '92legacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<< Originally Posted by johnceggleston when removing the rear diff, does the 'front member' have to come out?>> I never have??? One tip for removing most Subaru Rear diffs. It actually makes it easier if you don't use PB on the rear nuts. This will sometimes cause the nut to turn the stud out of the case. Then you don't need to slide the whole thing forward 2" to clear the studs.>> me too. i remember a day i went to a u-pull-it and pulled 4 LSD's out. never once touched a "front member"
Legacy SUS and sedan differences
svxpert replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi think the ground clearance is higher too.
2000 Impreza.... give me the lowdown
svxpert replied to wondermoose's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<Seems like a pretty good gig to me, although I'm worried something must have happened to it for the price to be so low.>> could be: 1. odometer rollback (even though it has a digital one) 2. flood car 3. salvage title buyer beware
front differential part number
svxpert replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlooks like its 31331AA221 from what the fast parts has
svxpert replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat year?
Differential problem
svxpert replied to '92legacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<Insert a fuse in the holder under the hood near the fire wall on the passanger to deactivate the rear diff.>> well, the driveshaft will still move and turn the rear diff , and wheels as long as the rear wheels move, the rear is also turning depending on how much it smokes, it still will. the front wheel drive fuse only keeps the power from going to the rear.
Drive Shaft Center Bearing Replacement
svxpert replied to Phillip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<I manage a large municipal fleet shop and have access to a press, etc. Even though the service manual said the shaft wasn't servicable, I planned to give it a try.>> how many miles on the car? since the driveshaft never (rarely) goes bad, my diagnosis over the internet is a bad wheel bearing replacement. what kind of shop did you take it to? any idea how they did the wheel bearings? i have heard and seen horror stories with people replacing bearings at a shop that has no clue. they might have damaged the hub, in this case, every set of bearing that go in, go bad only after a short time. also, check the gear lube in the rear and make sure its: 1. gear lube 2. clean, no water 3. filled to the top hole
head gasket part number
svxpert replied to cls1000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<so i'm getting the head gasket job done on my 01 legacy>> hopefully the place your getting it done at has tried the coolant additive before jumping to the $$$conclusion of replacing the headgaskets.
need TURBO only fill up tank
svxpert replied to BoostedLegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe plastic coolant tank that goes on the top of the engine?
