Everything posted by wentz912
HAHA! It's awesome that you made your own and everything, but they carry a 1/2-->3/4 adapter at Sears.
Still got your old set of wheels? The 17's i put on my GL, they're a bit much for my tastes.
Still anxious to see what you come up with in the back too!
Trimmed to clear the studs on the new top hats? Very interesting. Is it a one vehicle application, or did you have to mix and match fronts with rears so your car will ride level?
how are you doing your rear mounts? that's the only thing slowing me down from seriously considering c/o's on my wagon.
I'm running 205/50 17 iPikes on 08 wrx alloys, plus a 5mm spacer. minor rubbing on the bottom corner of the front fenders. 97 Impreza outback struts in the front with STi springs.
Intake Manifold Interchange
wentz912 replied to texasjack's topic in Old Gen.: 80's GL/DL/XT/Loyales...
So by that logic, a guy could put an EA81 intake on his EA82 to simplify things and install his Weber? -
Well, finally got the parts put on earlier this week. Only a few minor hiccups. Other than that, probably the easiest swap I have ever done on any vehicle. Now for the pictures.
I've had two with black interiors now
You could always just get a set of tires that are as close to the stock size as possible for your pugs. no need to go over size on the tires just because you have bigger wheels....
Thanks GD, thought I remembered that being an FI only fix. Looks like I will be replacing all my PCV stuff when I get home. The valve is a recommended dealer only item as well right?
Does this recall kit apply to the carb'd motors GD? I've heard of the PCV bypass bits for the FI cars, but didn't see a way to apply it to a carb'd rig. Figured it was more the nature of the opposed type engine, but I'd still like to find a way to at least limit this, if not prevent it.
So I took a LOOOONG sweeping right hand turn off the freeway yesterday, and it resulted in an oil-smoke cloud behind me thick enough that I could no longer see the car behind me. Also followed almost immediately by the return of TOD. So, what gives, and is there a fix for it? Car is an 85 D/R, Stock carb'd EA82
Wait, you actually think this is hard?Length in Inches x25.4=Length in mm
I think that point that GD was making is that you can save yourself an additional $65 on the parts if you have the time/ability to break up the components into separate orders.
Driveline issues on 2002 impreza transplant into 87 ea82t
wentz912 replied to ea2ej fingers x's topic in Subaru Retrofitting
Did you win? -
I'm not exactly in a huge rush.
