bajavwnsoobnut
Everything posted by bajavwnsoobnut
  1. to say it for Snowman it is worth it I had one that was in 4 different vehicles before I did something stupid and left it in the last vehicle when I traded it for my 76 but I am gonna start gettin them when the batts finaly die in the cars and if you can afford it the yellow tops are good if you use aux lights and such cause they are automotive deep cycles that you can use for cranking and also for high drain appliances like lights and Stereo systems etc.
  2. and actualy he doesn't drive that all the time and it has oregon temp tags in the rear glass cause the tags on the plates are expired and PRE is here in the portland area I just forgot the name and thought it was that other one I have also talked with that guy alot before and also seen the car at PRE in Gresham on Division St before but hey try finding the exact name of a place with what I can remember as being just performance in the name lol
  3. well you guys don't remember the Corvair much huh the motor ran backwards from what we are used to for the flat 4's/6's and back in the day for to mate it to a vw tranny is to get the cam replaced with an aftermarket one to make it work right for the tranny as for reversed tranny's the only one I can think of if you adapt it to another vehichle is the early VW bus tranny's cause of they used reduction boxes so the diff was sat up to run reverse and to fix that all you do is rotate the diff in the case 180 deg by unbolting both plates on the sides of the tranny and just flip flopping them around to make it rotate fowards in a bug or squareback
  4. hey Skip is it that one that you did to eliminate the slop and posted it on EXboard?
  5. sorry Rob but I didn't see page 2 and also there was a Official Recall on that not a dealer call back
  6. yeah even though I havn't seen one yet in person I do know a lil bit
  7. well I know who you are talking about he has an interesting setup for his IC and also has a bent rear subframe and I think it is this company I am not sure exactly but might try callin them: Superior Performance 6834 NW St Helens Rd Portland, OR 97210 - 3643 (503) 285-4667 of course it was interesting when I was searching dexonline.com for the ph# that I found this too: Pleiades Performance Motor Sports 7000 SW Borwick Rd Hillsboro, OR 97123 - 3692 (503) 642-1275 and we know what they do don't we?
  8. what caboobaru said and yes it will work with the EA-71's and I think also the EA-63's and such and even my EA-65 cause I should know cause it has one from a ea-81 when I got the car (the 76) and the boardmember that I got it from told me of this and then later on I told Andrew and Russ about it cause of they asked me about it when they saw it
  9. yes the 83 and newer ea-81 disty's are the way to go and all you do is hook the 2 wires to the coil and your good to go and if you want a lil more power get a 2wd disty while your at it
  10. Northwet just wait till you see what he has in mind for the ring setup it is gonna be nice to say the least
  11. Turbone I think there was a recall on the non-watercooled turbo's and they just replaced the centersection with a the one with watercooling and CHIM the difference is a lil bit bigger turbo and also you have an easier time finding a turbo if that one goes bad and also better exhaust choices sorta
  12. wait till I am done with the 76 1800cc's of what Oddcomp said and not coke but crack or speed (or is that the same I forget)
  13. might talk to Corky (Dr.RX) about that and where at up here are you looking at moving to?
  14. ewwwwww umm why were you searching for a EA-63? they had problems with being open deck and blown headgaskets and Craig I have a EA-65 which is different and better than the EA-63
  15. oh yeah I still need to take that pulley into work and get it through the CMM and I was warned that the CMM that they have is not VERY accurate but hey it will suit our needs cause who cares about a lil dust lol (sorta inside joke)
  16. hey Brad if you do go this route I might be of some help and also if you pay for his gas and a lil bit more Oddcomp might just might come down to help
  17. what I remember reading is yes they can as long as you have a design or a HG they can use as a template
  18. or here is a challenge bucky try making the web in the shape of the stars and 3-4 hours is about what it takes me if I am doing wire for the web (very tricky stuff if you don't do it right ) of course your quality dreamcatchers too would take me that long too and don't worry relax it will all work out just fine and you might just get that coupe afterall I know if I was the one selling and noone else offered I would sell it to ya
  19. Craig Craig Craig..... you better be lucky I remember what I see on the ORG board emails I get: Date: Mon, 15 Nov 2004 15:50:41 -0000 From: "pwhitman2" <pwhitman2@yahoo.com> Subject: left luggage Someone left the Washco Fairgrounds a little light on Sunday. A green tote was left near a garbage can, is it yours?
  20. hmmmmmmm I have some good caps floating around and some gen 1, 4 hole alloys floating around........ I like your idea Skip!!! now I can replace the awful centercaps on those things cause they aren't the original caps!
  21. and for another source is www.paeco.com cause in their catalog they say that they can do copper HG's
  22. yeah same here and if you could only find a 76 4wd for that price and if only I could afford the gas to drive it home afterwards......
  23. yeah that course was VERY VERY Technical............... a lil toooooo technical for my likes the only rigs that were doing good was basicaly a baja bug cause of the rear e-brake, short wheelbase, Weight, and turning radius
  24. I have mentioned it to a friend from work that is about as nuts for Subies as I am but he has the fundage so who knows there might be a STi eater here in Oregon (I hope)
