Everything posted by Redcap
ok so im lookin at a justy
I think lots of Honduhs use 4x100mm too.
- geared hubs?
geared hubs?
Like a portal axle setup? I didn't know VWs had portals!
Seafoam question
You must be slow.
5 Lug Swap...yes I looked
Shipping will likely be the killer.
WCSS11 Off Road pics from Friday
Very cool pics!
OverHeating EA82
This is my exact problem. Looks like I'll be doing headgaskets in September (or finding a decent EJ22/wiring harness/ecu).
I got a brat!!!
Uh...
ea82 oil preference?
Someone told you a load of crap, then.
another noooooob!
Welcome!
I got a brat!!!
SWEET! You still need that caliper? My Soob is no longer distance-capable (needs headgaskets), but I can meet you in Chehalis whenever you need. I have a phone again, same number.
Is a 1980 Brat with 64000 miles a good buy?
I would hold out for the AWD, if that is truly what you want.
Radiator Fan for EJ Swap
I don't have an EJ in my rig yet (definitely on the short-track plans), but these are cheap and work well... http://www.kmjent.com/cart/product.php?productid=426&cat=20164623&page=1 I use two of those on my EA82, though one would probably be more than adequate. They move a LOT of air. http://www.kmjent.com/cart/product.php?productid=427&cat=20164623&page=1 The 12" version is only a few bucks more.
New Thread: EJ wire strip class at WCSS11
Damn, wish I could make it to WCSS11 for that!
New member, veteran subaru owner
Welcome aboard!
EA82 Weber Questions
I have absolutely nothing constructive to say and zero Weber experience, but a lot of guys run them here and someone should be able to answer your question soon. Welcome to the board!
Best way to wire back up lights
If it were my project (and I wanted automatic backup lights), I would splice into the original backup harness and use the hot line to trigger a relay.
88 GL wagon..need idler pulley, worth buying?
AC is unnecessary.
I got a brat!!!
PM returned.
I got a brat!!!
Nice score, man!! If you need a hand with anything, give me a call.
electric powerd suby?
A couple of 9" DC motors would work pretty well. You would need an adapter between the motors and trans...the motors would also probably need to be re-phased. They would require a motor controller and charge controller, since you would probably end up running around 96-144VDC to the motors, but keep 12VDC to all the accessories. Of course, there would be all the nickel and dime stuff too. It would be a large project, but pretty cool as an end result.
aftermarket Gauge Q's
Interesting. I guess I'm lucky with where I live then. Every time I've needed something out of the ordinary, there is a little shop called "Industrial Specialties" in the next town over that seems to have or can get what I need. They have a TON of metric stuff.
Try your local industrial supply houses. Most places that build hydraulic hose should have a vast array of fittings, many metric.
Different kind of rust repair.
I like this. A lot.
WA junkyard info!
Sounds like I'll be headed up there sometime between tomorrow and Saturday then.
