vagen
Everything posted by vagen
  1. easy equation amps x Volts = Watts you might just scare yourself.
  2. As promised here are photos of the Suby with race decals applied
  3. had a scrub session with my enkeis today Before and as I got them and this is after 1/2 hour with steel wool and brushes I'll have photos of the race decals later (when it's light out)
  4. now if I can only make it's brother look as good.....
  5. tomorrow I will be re-oiling my struts so they will work with my race springs (a temporary fix till I get my 5 lug setup)
  6. The eg33 is the same bellhousing pattern as an ej. I know this because a friend has an ej wrx trans in his SVX with no adapter plate.
  7. surprisingly it did the rear never broke loose once I got going but in the really slow sections it sure wanted to.
  8. the stock airbox and filter will flow just as well as a K&N. If you are looking for more power look elsewhere like Exhaust.
  9. the spoiler is for autocross and yes it kills milage but creates down force at lower speed so the trade off may be ok. I will find out this week end when I race it.
  10. I am currently running full coil overs on re-valved stock shocks (heavier oil in stock shock) full XT6 sways front and rear on toyo RA1 Dot race tires. I am planning to convert to 5 lug so I can get wider wheels and more travel at race ride height. I'm looking at a set of 15x8 0 offset Rotas.
  11. this car is stripped out the only interior is the required front seats. even the sound deadening is gone
  12. I took mine racing and had a ton of fun I can't wait to have more power better shocks and a better driver.... well two out of three anyway.
  13. I am running a TWE 2.5inch bellmouth DP with 2.5 exhaust from there back. I found my missing HP I had turned the boost down to 9psi for some reason I think it was the clutch so there's my missing power. I will still work on more
  14. I do plan to swap the stock injectors for 280zx-t injectors along with the appropriate maf mod. The reason I am looking for power is I am being beaten by a civic in street modified.
  15. Here is the short list of what I haven't changed. Intake manifold, exhaust manifold, turbo, camshafts, ecu, injectors and turbo. I have on the shelf a decent size FMIC and I can get a header that will fit a td04. I know a larger turbo would mean cooler charge temps so that is high on the list.
  16. As many here know I am autocrossing my RX. I have a pretty fresh engine that has had a JWX rebuild and tuning. I have taken this engine a bit further with an intercooler boost control (set to 11psi) and a CAI. I am now looking for more power without turning up the boost any more. Any help is appreciated. I am not ready to do an ej swap yet.
  17. my apologies I was mistaken on the origin if my car. In future I will give credit where it is due.
  18. I think I'm getting closer to the Rally version all I need to do now is build the push bar
  19. If you can't get ahold of Will through nasioc try calling Steven (pleadies) at 42autosports.com. Steven has helped me further develop one of Will's RXs.
  20. That actually works Back when I was a Datsun owner I saw a guy with one of those on his 510 and on the track he was about 10mph faster than me and I had more power.
