86subaru
Everything posted by 86subaru
new weber, but what about the oil in the weber ? i must have screwed something up ,thanks
i could be wrong, either tps or coolant temp at autozone
replace, if i remember ,autozone has them like 17 bucks, but look up something for a nissan , miles fox knows which one it is
i finally got around and looked at my 84 brat, marked timming ,set timming, , looked in side weber and the front parts ,looks to have oil down in side , what gives ? still having surging problem , but no back firing , did i mix up a vacuum line causing this? , also would the acell coil cause the surging problem , ?
there is another board member that has the same set up 18-`19 mpg, my a/t full time 4wd turbo gl-10 gets 22-23mpg city and 24-25 hi way , depending on how fast my wife drives 70-80 mph or 65 mph
Anyone charted performance mods?
86subaru replied to Todd in Seattle's topic in Old Gen.: 80's GL/DL/XT/Loyales...
well this is no crap , do not change your coil to acell , , 2 in pipe from cat back , no big cat, air box cut out, k-n filter , ngk plugs, 8mm wires , , all adds up to good mpg, all this is on my 88 turbo a/t full time 4wd gl-10 wagon , 22-23 mpg city, 24-25 hi way , remember the full time is a 4 speed a/t -
found a pretty nice awd a/t legacy w/ 122,000mi owner says it has a bad noise coming from tranny or drive line , i could not hear it run because there is no key , but owner is looking for key, could this be a bad u- joint in the drive line ? or bad tranny , owner says it will shift ok and drive but just the loud noise , can be had for 300 or cheaper , owner is just about ready to junk it
the 120 psi was before i added the xado , , the car has to driven another 60 miles aleast so i can add the 3rd tube , + fill it back up and see any difference in mpg
ok, added another tube , seems to idle better , my wife drives it soooo she will be the one to tell any difference
the fine gentlemen is kansas sent me 3 tubes of xado , , i am following all directions ,it is going into a 88 turbo a/t full time 4wd wagon , w/ 103,000mi , here are things i have done to the car, air box mod, k-n filter, ngk plugs, no big fat cat, city mpg is 22.3 , highway 24.5 without air running , compression on all was average of 120. lbs , i still have 2 more tubes to add , + fill the gas tank and get a good city mpg reading, and no i am not getting paid for any results good or bad
no tom it was not , i have all ACCELL coil's on my subaru's , , so just a warning they will go bad , here is a question , by putting the oem coil back on will i have to regap the plugs ? right now there at .45 ? car seems to run just fine
took a small vacation , 160 mile 1 way , on the way back we stopped at a rest area ,the acell coil went bad , the car would not start up and the coil was real hot , good thing i took a oem factory one along , 10 min job and back on the road , thanks to all the members that said take a extra one along , because where would i have gotton on at ,the coil only had 21,000mi on it
XADO - anyone ever heard of it or used it?
86subaru replied to KStretch55's topic in Old Gen.: 80's GL/DL/XT/Loyales...
bump -
backing firing problem /84 ea81 brat
86subaru replied to 86subaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
no doing outside house work , will look at it monday - tuesday 27th -28th, i did notice that one of the steel ends are not hooked up ,close to the dist -
ok, will call you , when is a good time to call ? i work 10-12 hour days , -
what is the price of 1 tube ? if your willing to send out a sample ,i will try it in my 88 turbo a/t awd wagon w/ 102,000mi , and of course i will post all results , good or bad
