86subaru
Everything posted by 86subaru
84 brat blower motor question
86subaru replied to 86subaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
already tested for power at the switch , i just ran a wire from the fuse box to the greem/ white wire -
yes i have done that before -
changed the blower motor ,but still no blower ,in fact no power going to the blower , i checked all fuses , -
are ea81 blowers the same as ea82's ? and the location of the blower motor on a 84 ea81 brat
dont call it the TOD!_!
86subaru replied to archemitis's topic in Old Gen.: 80's GL/DL/XT/Loyales...
trying running 15w -40 motor oil , it worked for my 86 spfi a/t fwd sedan -
i am getting mine done as we speak , no big fat cat
pulling to the right problem
bump -
might get ahold of miles fox ,he will be in columbus ,ohio soon and could buzz down to your place and do some work for you
The tick came back the very next week ....
86subaru replied to Bubonik's topic in Old Gen.: 80's GL/DL/XT/Loyales...
as far as the ticking goes try 15w 40 motor oil , i did and it took the ticking away , may not be fixing it but it worked -
Fun At The Subaru dealership!
86subaru replied to Bucky92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the dealer i call wanger subaru , always knows what i am talking about + most of the time will tell me what size of wrench it takes or how to get to it , -
well replaced both sides wheel bearings [seals], replaced both ball joints, [were bad] found out both inner boots of the drive axles were split .[replaced them both ] but the car still pulls to the right , not when the brakes applied , so i guess it needs a aligment ? -
catalytic converter question
ok thanks pat -
i have a a 88 TURBO full time 4wd a/t wagon, if i was to remove the catalytic converter ,the one right at turbo [ football shape] and put 2 in or larger pipe there ,and run 2in pipe all the way back to exhaust , how much more hp would i get ? how about mpg ? + make car run alittle cooler ?
it is a 88 full time 4wd a/t wagon , tires are balanced, all the same size, proper tire pressure , the car pulls to the right going down the road ,not when the brakes are applied , not real bad , thinking it might be a bad tire switched fronts to back ,still the same problem , any help suggestions ? thanks
thermostat / cooling problem
are you sure that your thermostat is working like it should? mine went bad and it was 1 month old or a air pocket some where , but it could be a hg problem also -
i just got a xt6 awd 5sp , paid alot less for mine
talking to me or the other guy ? mine seems fine now , changed out thermostat , -
i forgot to say also, both my belts were alittle loose , and they are not oem belts , both are tight now , today i will start it up again and see what she does , thanks -
well after it cooled off a few hours it seemed to work alot better after i replaced the thermostat ,thanks -
new water pump, in fact oem , gasket, o ring -
i posted it before , can not find it anyways, changed thermostat , coolant set at -15 , all fresh, changed cap, all air pockets gone, but it still seems to have the same problem as before, temp gauge goes up 3/4 way , thermostat opens ,goes to 1/2 , this seems good, but some times it will not open until it gets close to the red , but after a half hour on the road it will stay in the middle, all ok,
another opinion would be a weber carb, yes they cost some $ but worth it after it is tuned up right , they say more hp and mpg , i have one 1 on my 84 brat , but not really drove it alot yet
yes i did , it fits into like a slot, but will double check tomorrow
