86subaru
Everything posted by 86subaru
problem w/ 88dl manual 4wd wagon
86subaru replied to 86subaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yes after i warm it up it will not do it as bad , -
after the car sits for awhile like over night, it starts up fine idle is fine , i 'll put it into 1 st gear and start moving and push on the gas it will almost stall or buck and run real slow for a few feet , after it is warmed up it is fine , timing is set , new fuel filter, acell coil, 8mm wires, new cap, but i did not change the rotor , or is it something else ?
Sheet of Plywood hits my soob on the freeway
86subaru replied to subieman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
well something like this happaned to me ,but i was in the semi and some how through a good size rock from the rear most trailer tires and hit a chev -s-10 , and i did not not know i did it ,until the guy waved me down , but in your case improper load [ not tied down] in my case it is called a road hazard -
ea81: replace ? when engine is out
86subaru replied to subiemech85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the answer to your question , you could stop by any auto parts store and ask them -
i my self have been using 20-w50 , use a dura- blend , about 9 bucks a-gal and a good filter [ castrol , ]
go to any auto web site -
i was just asking a question , if you do not know the answer please do not respond
i asked this before but can not find the post, will an 88 xt 4wd fuel tank fit into a fwd seden or 4wd wagon ?
i have an xt fuel tank from an 88 single range will it fit onto a turbo 4wd wagon or fwd sedan , since i am stripping down an xt it might be a good to keep a spare fuel tank , i can get it check out for free and cleaned out etc...
i have a fuel tank from a xt , the xt was a single range 4wd , will it fit onto a 86 spfi a/t fwd sedan ? or a 4wd a/t turbo wagon ?
mine does almost the same thing, at 65mpr , when you brake hard the steering will shake alot back and fourth but i am thinking the rotors are warped or pads
ok, thanks
Head gasket or Replace engine
86subaru replied to bigtrout's topic in Old Gen.: 80's GL/DL/XT/Loyales...
well a full gasket set from napa is 200 bucks , it took about 14 hours with 3 guys , well 2 guys new what they were doing and i did not , if the body is good and no rust , and what you will have it after everything is done ., and a place to do the job and tools -
when you switched the coils did you by mistake pull on the coil wire ? did you hook up the coil wires right ? check the fuse under the dash
my wife would really like that on her turbo wagon , man you make them and sell them , my wife's car would be the only car in the area like that
the xt is a manual single range and the turbo wagon is a full time 4wd , will they interchange ?
will front struts from a xt work and fit on a front 88 gl-10 a/t turbo wagon ? my air struts on my turbo wagon are a pain and i am going to replace them
i would use napa complete set around 200 bucks ,it comes with alot of gaskets all possible needed and then some
