hooziewhatsit
Everything posted by hooziewhatsit
To make it easier to put the cam tower on, spin the camshaft so the key is straight up. That will put it in a postition where none of the rockers are being depressed. Much easier to align and bolt together then. -Dave
Replace your PCV valve!
hooziewhatsit replied to GJTaranto's topic in Old Gen.: 80's GL/DL/XT/Loyales...
www.1stsubaruparts.com Just give them the part number from earlier in the thread. -Dave -
Timing Belt without discharging AC???
hooziewhatsit replied to GBANGER's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You shouldn't need to move the AC compressor at all. Only time I've had to move it was when I pulled the engine. But for t-belts and seals, nope, don't need to move it. -Dave -
Puh-leese, Hep a bruthuh out !!!
hooziewhatsit replied to HiPlainsShifter's topic in Old Gen.: 80's GL/DL/XT/Loyales...
just to double-check, here's the timing order (haven't seen it posted yet) 1, 3, 2, 4 transmission 3 4 1 2 front bumper #1 on the distributor cap should be nearest the brake master cylinder. Rotor then spins CCW. Also make sure the rotor moves when you crank the car. If it doesn't, your drivers side timing belt decided to blow (just happened to me). -Dave -
A Tale Of 2 Vacume Hoses
hooziewhatsit replied to The Dude Abides's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If you get the vacuum lines to the diaphram hooked up backwards, it just means the switch will work backwards. In that case, just switch them around again. IIRC, vacuum from the vacuum canistor should split into two lines, go into the solenoids, then off to the diaphram. Start at the source and see how far the vacuum makes it. -Dave -
In theory, the hill-holder should release after you have barely let out the clutch, and before the clutch starts to grab. Find a hill you can sit on safely, engage the hill-holder, then slowly let out just the clutch so you can see where the HH disengages, and where you start to roll backwards. It sounds to me like it needs to be adjusted, since it appears that it's holding the HH much too long. If the clutch starts to grab, and yet it's still holding the HH, I'd say the cable needs to be adjusted -Dave
EA-EJ Engine Adapters , new design
hooziewhatsit replied to Scott in Bellingham's topic in Products for your Subaru
Too late. Ohwell, I'll be back later -Dave -
Distributor rebuild places?
hooziewhatsit replied to hooziewhatsit's topic in Old Gen.: 80's GL/DL/XT/Loyales...
ahh, ok. Didn't know there was that much difference between FI & carb. Guess I'll call them again tomorrow and get a new quote. Thanks, -Dave -
Thanks for the replies. I found a thread from Russ about replacing the bushing. If I can get it apart I'll see if I can go that route. Not much else to lose at this point. http://www.ultimatesubaru.org/forum/showthread.php?t=54746 <cue 'The more you know' music> Good to know I can remove the drive gear and pull the shaft out. -Dave -
I have an 85 EA82, carbed, automatic, with wayyy too much play in the distributor shaft. Got another disty from the junkyard that felt fine until it drove for a while. Now it has slop in it also. GD has mentioned the Philbin Group in portland can rebuild them for ~$50. I just called them, and they quoted me $245 Anyone know of somewhere else to get it rebuilt? Thanks, -Dave
Left headlight burns out, explodes in lens
hooziewhatsit replied to MR_Loyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
To get rid of the moisture, a hair dryer should work, as would putting the entire housing in an oven at ~200* for a while. Personally I've had luck facing the car towards the sun (in the summer) and pulling the bulb out for a few days :cool: -Dave -
92 loyale starting issues?
hooziewhatsit replied to 92justy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
also, connect the green test connectors under the hood and turn the key to on (not start). You should hear the fuel pump click on/off in 1 second intervals along with some solenoids under the hood. No fuel pump, no start -
I need tips on searching the forum
hooziewhatsit replied to ferox's topic in Old Gen.: 80's GL/DL/XT/Loyales...
hmm, just played with that for a few minutes, and searching with the + didn't return any different results than without them. I've found the most relevant links are usually at the bottom of the page under a thread. So if you find a similar thread while searching, be sure to look down there also. -Dave -
if it's coming from the sides it could be the cam seals. From the middle could be the front main. On my BILs loyale one of the cam seals was so loose I could just grab and pull it out Needless to say, once I replaced the seal it stopped losing as much oil. -Dave
During the summer I'd measure the temps on my engine at around 190*F, ie, just right. Since it's been cold here (20's), I only measured ~160* in the same places as before. Last time I filled up I barely got 20mpg Granted that's around town in 4WD.... I'm planning to either remove the clutch fan, or block off some of the radiator. Not sure which I'll do yet... In theory the thermostat should keep the internal cooling loop at the proper temperature, if it opens & closes quickly enough. -Dave
1991 Loyale Running To Cool?
hooziewhatsit replied to ()__1337_CRAYOLA__()>'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
That looks normal compared to my 91 loyale. My 88 GL however is normal 1/8" from Hot. Check it with an accurate gauge. Infrared no-touch thermometers work well. No real way to be sure otherwise. Since it's been cold out, my 88 has been running around 160*, rather than the 190* I measured the rest of the year. I'll probably take the mechanical fan out today before it snows again. -Dave -
Nothing missing, just gently hit it harder I've had to use a wonder bar to get one out. I was surprised how hard it was stuck. -Dave
fuel reserve question
hooziewhatsit replied to rick_hake's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I now know two things about my 91 loyale. - The low fuel light does not work - The useable fuel tank capacity is 15.1 gallons, not the rated 16 gallons for the tank -Dave -
Brining the HEAT..more or less!
hooziewhatsit replied to SuperchargedRS's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yep, before you pull the dash apart to get to the switch, check the relay. Had a friends car with charred contacts causing the fan to not work. Note that I Would measure 12v at the plug to the fan, it just couldn't carry any current due to the bad connection at the relay. -Dave -
Checking the CAS Voltage.
hooziewhatsit replied to Cougar's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The disk inside the disty has two different sets of slots; one with 360 slots, for each degree, and 4 very large slots for each cylinder, I believe. So, I think the two remaining wires will have those two signals on them. Putting a meter in AC mode should read those signals just fine. -Dave -
The SOA part# for the PCV valve is 11810AA000. I believe they call it an 'air control valve'. First time I tried to order the valve, I got the plastic T in the hose system... -Dave
