el_freddo
    145
  1. We never got the carb'd EJ engine - only fuel injection over here UNLESS it was a grey import which means that it was not shipped to australia by subaru australia... That's awesome! Cheers Bennie
  2. I would suggest you look at either a new/reconditioned alternator or work out how to pull the one you've got apart and replace the bushes in it. There would be plenty of options for upgrades available if you need a bigger alternator. Cheers Bennie
  3. TOTALLY worth it if you can find them! I don't think they're much of an issue in the US in terms of availability compared to over here... If you've gone the EJ22 route they're a must in the braking department at the very least. Best brake upgrade is the crossbred kit produced by a local fella over here. Yesterday I did the honda front spring conversion on my L's rear end. Here's the before and after: ^ currently got her "small boots" on for around town trips. Those springs pick the rear up quite a bit and I'm thinking of cutting a loop out to maybe drop it down a little bit. Either way the drive is much better and the rear end handles itself very well over speed bumps. The aim of this conversion was to keep the rear up and handling loads better than with the standard springs - particularly when offroad and the only way up a dune or something of the like is flat footed... Things are looking good so far, just have to get used to the new look and feel while driving. Cheers Bennie
  4. If it doesn't work, pull it a part and soldier any dodgy looking joints on the board... works a treat! The rare sort after part in oz for the offroaders is the L series AWD locking centre diff gearbox! AWD onroad and true 4WD offroad... The RX 4wd rear discs are rear too but the Crossbred conversion kit has changed the demand for this setup a little bit. Crossbred brake kit is the way to go for better brakes on the old 4 stud'd subarus One good one that I've only seen one example of is factory climate control in the L series - I'd love one of them for my subi but would't have a clue as to where to look for a unit for a subi with the steering wheel on the correct side of the dashboard, also known as the right side Also the R160 detroit locker - an aftermarket part that was made by some of the subaru rally teams here in oz. Dunno if they made it to the US. I'd seriously love an air locker for the R160 but am currently dreaming! Cheers Bennie
  5. Mate your subi's come a LONG way! Looks awesome! You'll have to tell me more about it - and yep, I've finally pulled my finger out and joined up on this massive board! Cheers Bennie
  6. I disagree with the bypass comment - the heater is a radiator, it gets its coolant from under the thermostat that is then sucked through the heater core back to the water pump to then cycle through the engine block again. This helps for a quick heater, even engine warm up and opening of the thermostat. Thus during cold engine operation the only coolant being cycled is that of the heater circuit - the radiator out front is blocked by the thermostat until the thermostat is warm enough to start opening. The EJ takes it differently - having the thermostat mounted upside down before the water pump on the inlet side of the engine! But the same principal applies really. Cheers Bennie
  7. Wow mate, breaking a control arm is pretty serious! I've got a 3 inch BYB kit in my L, I've been bouncing around on many things but have not broken a control arm - or heard of it being done, you'll usually bend the radius rod or rip out the captive nuts that hold the radius rod's plate to the underside of your subi! As for your camber I'm not sure where the issue is as I don't know the details of your subi's build. Are you running a 2 inch body lift or only a strut lift? I'm sure they would have built the kit with some kind of offset on the strut tops to change the camber to something near normal for these subi's... Add some pics of your front end lift blocks - this might help us work out where the issue is. No other suspension mods we should know about other than the lift? Cheers Bennie
