rllywgn
Everything posted by rllywgn
  1. from what i understand, its supposed to make your car run like its cold all the time, they usually plug into your temp sensor and create a signal that makes the car "seem" cold. hope that made some sense i know theres others out there but the cheapies usually just hijack/alter the signal.. your just tricking your computer.. rllywgn
  2. im guessing 2 will break.. thats the least ive had break when removing the manifold. 5 out of 6 is the best (or worst) ive managed to have. good luck! rllywgn
  3. im in vancouver, wa if you run into any trouble in sw washington. 360-798-0649 rllywgn
  4. i had a supra that would tick quietly at idle then as you revved it it would turn into a symphony of shredded metal bits... it was awesome, magical almost I really shouldnt have turned up the boost that much.. rllywgn
  5. id like the rest of the rally mod sheets... i have some more projects to do now... freakin rad gonna blow them up and make the a lil more legible.. should keep me busy for a couple days.. some will have to wait until after emissions.. rllywgn
  6. you can change them, but finding them is the hard part. you can add a spacer to almost any car as long as you dont go to extreme by not leaving enough stub to get the bolt over.. what effect are you going for? tllywgn
  7. er27 has been thrown in a few different rigs.. i know theres a brat around with one also. I know one should show up in the search.. rllywgn
  8. problem with the alternator perhaps? i had a similar problem on a ford explorer.. turned out the alternator was shot. rllywgn
  9. I really wanted to keep the key from my last wagon as they can be modified to switch the keys around and keep the neat light. basically looked like a rubber head but it was plastic and had a led flash light (near worthless) and from the factory they came in a jewel box. good luck finding one.. ive never even seen one on ebay.. if you do find one you can modify almost any standard key to fit in it. rllywgn
  10. anyone notice that it had a 7.7:1 compression ratio! 180ps ( is that about 260hp? cant remember the conversion for sure). i want it so bad it hurts rllywgn
  11. those turbo legacy's are fun.. be nice to your tranny if its an auto.. they dont like alot of abuse.. welcome to the board.. you'll find a ton of info from diy to off the shelf.. good luck rllywgn
  12. is it blowing gaskets at the head? if so you can use the xt turbo header. you may have to jack the engine up a inch or so... tkaes an hour or so to do the header you have may be warped? i had to replace a header a few years ago for the same reason rllywgn
  13. i hope this doesnt sound moronic, but I've heard of folks doing there own prot and polish jobs. I havent done this myself but why not. from what I understand you can do it with a dremel tool and some patience. you may not want to do it but its an option, Also with as cheap and readily available as subaru parts are that should make it easier this site may give some some useful information http://www.sa-motorsports.com/diyport.shtm rllywgn
  14. So I've done my fair share of head gasket replacements in my day.. and i had a thought today (why it didnt come to me sooner i dont know) i have a 1989 toyota supra turbo that ive been tinkering on for years and one of the first things i did was retorque the head an extra few pounds as per suggestions from the supra community. Anyone done this or have any thoughts on doing this? I dont wanna do any more headgaskets on a ea82t for a while. btw the supra 7M-GTE has a tendency to blow headgaskets also.. aluminum block and head and crappy headgaskets (metal is an option but pricey) rllywgn 88 GL-10 turbo sedan ft4wd~5spd~lsd
  15. starters will click usually when theres not enough voltage to get them spinning or it is going bad. like stated above check your terminals for buildup, that will slow the flow of electricity. if you havent replaced the battery in the year that you've had it, chances are good its on its way out. rllywgn
  16. my kids are gonna love subaru's... or else.. these cars are just to dang easy to like... i found a rusted out early 80's coupe in a junkyard in arizona a couple years ago.. someday.. oh yes someday one will be mine...rllywgn
  17. road rally or dirt? cause dirt is the stuff of dreams.. 4wheel powerslide dreams with popping exhaust and screaching blowoff valves.. rllywgn
  18. i finally have a subaru that runs and everything at the right time for a 45 minute drive to hood river.. Well if i dont do anything too nutty before august.. gives me some time to get some more mods done.. rllywgn
  19. it makes sense with a additional air tank. i called my brother at freightliner, im gonna grab a 4 gal tank and a 120psi pressure switch. ill still need a check valve and airline. Gonna mount the tank in the trunk in that center compartment.. rllywgn
  20. air suspension is expensive.. i just bought my GL-10 the other day, it has air suspension that was just replaced 5 months ago at 1200 for all 4 corners installed... fortunately the previous owner picked up the tab.. had it been my decision i would have gone to a standard spring setup. rllywgn
  21. from another car or aftermarket? what are you using for fuel management? rllywgn
  22. thats awesome, atleast the ease of which this system can go together. my brother works for freightliner, looks like ill be giving him a call for some parts thanks rllywgn
  23. just wondering what unit would be best to install? my only experience is with a aem unit on a integra. any tips or what to do with the factory unit? thanks in advance rllywgn 88GL-10 turbo sedan ft4wd~5spd~lsd
  24. i had a saab hooked up in my wagon for a while.. initially it was open air and the car seemed to stumble some.. after replumbing it seemed to lose the hesitation when reapplying throttle
  25. ive had great luck with trailblazer batteries and there not to expensive (50-60). i believe the foglight bulb is a h3 or h4 55w (short bulb, metal base, single wire) rllywgn
