Everything posted by greg454
Starts; but let the key go to run position(dies)
I know on older cars that is a symptom of the ballast resister being bad. When cranking, full battery voltage is fed to the coil for a stronger spark when starting. After the ignition returns to run, the coil is powered through a ballast resister lowering the voltage at the coil as not as strong a spark is needed. So with a bad ballast resister the car will run in "start" and die in "run" key position. Disclaimer... I dont know what car you have or if it even has a ballast resister or not.
Baja vs. Brat
They did in fact have seat belts in the back for the jump seats! I still have them in my '84.
- Brake fix it question and help with vacuum hoses
Barrett Jackson Brat Sales 2019... WOW
Barrett Jackson January 2019 1987 sold for $16,000 https://www.proxibid.com/asp/LotDetail.asp?ahid=10600&aid=155490&lid=45616495 1983 sold for $12,000 https://www.proxibid.com/asp/LotDetail.asp?ahid=10600&aid=155490&lid=45616452 Hopefully these links stay active for a while... Think Ill hold on to mine for a while!
Compiling database for Gen2 Brat sales evaluations
Barrett Jackson January 2019 1987 sold for $16,000 https://www.proxibid.com/asp/LotDetail.asp?ahid=10600&aid=155490&lid=45616495 1983 sold for $12,000 https://www.proxibid.com/asp/LotDetail.asp?ahid=10600&aid=155490&lid=45616452 :-)
BRAT decals
I bought a set of Gen 2 from ebay about 5-6 years ago. I got a full set but only used the "BRAT" stripe over the cab for a little more minimalist look. If I remember correctly I had to pay a little extra because I wanted gun metal gray instead of one of the offered colors. Mine still look great to this day but my brat has always been garaged so that really helps. I would definitely recommend them. Luckily I had a friend that used to apply decals to company vehicles help me as getting them to fit correctly over the cab does take some skill!
Help with '81 Brat Smog Sticker - picture, please?
I don't know if this helps or not ..EA81, 1984 Brat, 1800, solid lifters,.. high altitude kit,...
Anyone know the part name of this 86 brat Steering shaft rubber bushing?
I always called it the rag joint.
These are a few of my favorite BRATs
Ha.. Mine made it in 4 different times!!
Trying to decide on colour for steel rims on Red Brumby/BRAT
I did mine in black with chrome trim rings. I think it turned out nice.
Brakes won't let me pull out of the parking lot...
My hill holder would leak brake fluid when the cable actuated it. So I disconnected its cable from the clutch fork and have been running that way ever since with no problems. It doesn't leak a drop this way and if I'm on a really bad hill I can always use the hand operated emergency brake, although driving a clutch all my life that really isn't necessary. Also, most drum brakes (I assume subarus are the same) usually have a short shoe and a long shoe. Make sure the short shoe is towards the front and the long shoe is towards the rear of the drum or you may get the kind of symptoms you describe.
- May be wrong place to post Transmission question
Subaru Brat ea82 turbo bastard project
It brought $4950 on EBay. Someone will have fun with that thing
83 Brat - No ECM and failing emissions
I had a problem initially trying to pass Colorado smog test with my '84 brat. They insisted it was supposed to have a computer and o2 sensor and wouldnt listen to me when I told them it never had a ECM. After about an hour with the manager he figured out if he looked it up in his computer as a Subaru truck (he was looking under car) it then showed correctly on his computer and it passed with flying colors. Next time I went back I told them to look it up as a truck and they found it just fine.
Axle REALLY tight going through new wheel bearing.
I clean up the axle and give the surface a thin layer of oil. It seems to help it pull through the bearings easier.
Colorado has updated the rules for collector plates
It looks like it must of been almost 5 years ago as my plates expire in August of this year. I live in Arapahoe county if it makes a difference? It never needs another emission test again as long as I own it. I have two cars with collector plates!
I have collector plates on my '84 right now in Colorado. About 4 years ago the law was 25 year old cars qualified so I got my plates just before the law changed. My car is now grandfathered in and can stay on collector plates as long as I own it.
- Wheel Color Opinions (looking for example pictures please)
I sandblasted mine, painted them black and then added chrome trim rings. I think they look great- The Awesome Older Generation Picture Thread
This is awesome !!- 11.3 V at start up - but why after 5 minutes everything is normal 12+ V?
You should have around 14 volts with the engine running, even if the battery was bad. Sounds like alternator to me.- Help Needed. Gas + Spark does not equal start?!?!
try to spray some starting fluid down the carb just to be completely sure its not a fuel issue.- Prep tips for Running in Cold Weather
I have an hitachi carb and mine starts great in cold weather. If your carb is in good shape are you "setting" the choke correctly? First thing you do before you try to start it is press the gas pedal all the way to the floor and then release it. That sets your choke and fast idle. When the car starts it will fast idle around 2000rpm or so until you blip the gas pedal again and then the idle will drop to normal. Most older carburated cars worked like this and the hitachi does also if in proper working condition. Greg- BRAT Rear "Headrests"
I have some pictures in this thread.. Kinda hard to see.. http://www.ultimatesubaru.org/forum/topic/141474-installing-bed-seats-in-a-1987-brat/page-2- 4wd indicator switch - where to get a new one?
Thanks. I needed one also so I just ordered one from rock auto. http://www.rockauto.com/catalog/moreinfo.php?pk=943375&cc=1267725 - Wheel Color Opinions (looking for example pictures please)
