10
Everything posted by ivans imports
had to put 1200ftlbs on a cam bolt on vvt turbo forester other day was crazy tight took 3 of us two holding cam and me with a 4 ft snapon bar to get it to move. Never seen cam bolts so tight broke two snapon allen sockets and one outside bolt remover tool. My 1/1/2 inch snapon impact gun would not touch it
- 49 replies
- turbo
- timing belt
(and 3 more)
Tagged with:
Ea 71 engines and tranys
ivans imports replied to ivans imports's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes lumby Bc Canada have many 1600 units engine cores an trans a'm cleaning my storage yard so would like to get rid of some old stock all these years of cars are long gone and the ones I do have are in good order -
do you use a 3/8" or 1/2" impact wrench for lug nuts?
ivans imports replied to idosubaru's topic in Shop Talk
After 3 years of strait use wore out my 3/8 cordless running 18 volt batt cost me 200 to rebuild it good to go again -
Finding have way to much of these parts have 6 ea71s and 8 4x4 ea71 4 speeds anyone need any fit 77-80 brats/ wagons
Can someone help me with this bearing?
ivans imports replied to Gwywnc's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The small one is ea71 they give both in the kitt do not use. But save for that ea71 brat you will find one day helped me out when I installed my ea71 in my 80 Brat last week. Had saved the bearing for 8 years before I needed it But I had it ! -
2 plug tps? mpfi ea82
ivans imports replied to elgigante's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have two one has a round con on pigtail one has a rectangle con on pigtail both 3 wires both same wires. Looks ok came off a ea82 T 1989 round plug one is off 1988 model -
4x140 to 5x100 bolt pattern adapters
ivans imports replied to matts87glsedan's topic in Products for your Subaru
Mine working well putting on the km's love the wider tires -
Oh the rear wheel bearings on these cars what fun I bought a 1-1/2 drive snap on gun just for that bolt
- 17 replies
- rear
- suspension
(and 4 more)
Tagged with:
I might have one -
Have done over 150 heads on my van Norman 570 since I got it 2 years ago. The heads that give me the most grief are the twin cam 2.5 heads. Or any overheated badly heads. Taking very small amount off at a time helps I also put the heads in the freezer 1rst to get the aluminum to tighten up. They surface better cold
Fwd using a 87 gl high low. Had to use front driveshaft 1/2 from 04 forester with rear half from 02 legacy sedan to get right length homemade xross member. The impreza efi seems to like its turbo engine no check engine lights and good performance. With the outback 2 inch lift and my 225 70 15 bfg km2s this car works well. Will see if can get some pic's. Is this years test bed car
