12
Everything posted by ferp420
i got the rear end pushed back about 3/4 of a inch so the tire is centered now but 2" just dosent seem like enuff lift to clear the tires so eventualy ill go down a size or 2 i cant seem to get the front end clearenced enuff for my liking as is or i would just cut more fender lol
update pics im half way done i need to adjust the rear.wheel location and do some more triming and bfh work before its drivable but its coming along nicely
Tow bar questions for my TOAD 87 GL wagon
ferp420 replied to Crossthread Ed's topic in Old Gen.: 80's GL/DL/XT/Loyales...
ill get those pics asap -
any one ever do the napkin lift on a ej body more specificly a imp i dident have time to pull the struts off my foresrester and wanted a lift right away and dident want to wait so i cut up some steel and in the spirit of the napkin lift i cut me some blocks and they installed just like the ea82 instant 2" lift i did have to buy a bunch of nuts and bolts but $5 for a lift isent to bad i need to finnish the rear still tomarows another day the wheel adaptors are on there way should be here by the end of the week then i can mount up the new rims and tires then no more belly draging while getting grocerys lol
i have u shaped brackets that bolt to the tow bar and then to the tow hooks on the car very simple i can tow from the bumper too but always use the tie down points -
i flat towed the hay out of my loyale with no issues the steering always returned to center without issues i have thousands of miles with my toad i tow from the the factory tie down not from the bumper i have a cheap tow bar with modified brackets to fit the tie down points the same set up works on the imp also with out issue -
i can do $100
need 90-94 loyale rear wagon gate
ferp420 replied to mtnman38's topic in Old Gen.: 80's GL/DL/XT/Loyales...
wow i have a 87 a 91 and a 94 and there all the same they all bolt up and close the same they might have different trim but who cares that can be changed seems to me if you needed a hatch you wouldent be that picky they all fit and there is so little differance the older ones with the wrap around trim look better if you ask me but its just trim and paint and your most likely gona have to paint it anyway so whats the issue -
i know the wrxs are wider i put wrx arms on the front of my forester i used the same axles with out issue its about a inch wider in the front than the rear there getting swaped to the imp soon
ive got a 2ft light bar on my rig i mounted the switch on the grill and i only hook it up to the battery when i need it i also have 4 low powered leds in the bumper pointed low 2 out to the sides a bit and 2 straight ahead those are on a switch on the inside the fog lights are about as bright as the headlights and alot bluer and easyer on the eyes tban a tipicle led light bar so not much chance of blinding anyone with them but they light the side of the road also work good off road when im following someone i have some 6" led mini light bars im installing inside the hood scoop on the impreza for exploring the desert at night
its cool yo its all good fun
cool vid heres some of my johnson valley wheelin vids mudding johnson valley some wash running more theres alot more nothing crazy but some fun stuff
the question is in the title and if you cant figure that out i dont want your answers the rest of the thread dosent mater anyway i got a plan thanks for all the help ill be sure to post up a very long discription of the build grammers for girls
just the way it should be
im building up my impreza as far as grammer goes ill just never get it kinda lik3 names and faces but numbers dates and shapes i get i passed high school in 2 years but could never get english i was in every alturnitive class that passed for english credits my jounior class teacher and my senior year english teachers wrote my essay so i could pass the profincency exams but i had a b+ avaerage when i graduated but english waz a d every class no matter how hard i try im retiered now so i dont give a darn anymore sorry anyway im building up my imp scraping the forester i hate that rig the auto sucks and its way to heavy the suspention is brand new though and i have no problems robing the gears and the suspention out of it the duel range is out of a ea82 the impreza is gona be a cruzer mostly just back roads in johnson valley i just need some ground clearence im looking at 215/75/15 the loyale is now off road only some day ill actualy drive it again its getting a solid axle for the rear end and ej front struts when i get around to it ive been working on my new houses mostly full time so no time for toys grammers for girls and school teachers get over it
GL10 shock replacement problems
ferp420 replied to Larry K's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I think your only gona get coil bind with the fwd struts ive never noticed it with 4wd struts or the nissan 300zx struts i did blow the purch off of the fwd ones the only way that happens is if the coils bind -
Simple Lift 88 GL Wagon
ferp420 replied to Lilblusubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sjr has been building lifts for a long time im sure he can hook you up with a kit that includes the extended steering link thats realy the way to go your not going to find a better lift outhere but your gona pay for that bolt in kit he did the engineering and testing for you if you choose to try building it for your self its not hard but anything over 2" is gona need more than just the strut spacers and thats were the engineering comes in you can do alot of damage with a poor lift kit so do your homework the 2" lift is easy and simple and wont kill your rig if your off alittle remeber you get lift from the tires too so a 2" lift with 27" tires will net you 4" over all -
No it still rides in the same position on the strut as it did before the lift your not changing the waight of the rig and the spring dosent change so there is no reason it would max out your suspention a spring lift dose maxes out the suspention not a strut lift the 2" lift is the most comin lift around for subarus if you did want to do a spring lift u can use ford tempo springs i have a 12000lb winch on the front of my rig i used the progressive springs from the ford tempo they work great they will give you a very stiff ride if you dont have extra waight on the front end the controle arms have plenty of room to droop out its the cv axles that limit your lift not the suspention it self the big problem with the strut only lift is your axles do were faster not a big deal on a wheeler but it sucks for a daily driver The rear of the rig you can use honda springs for a 2" lift but that will again put you at the top of your traval unless you add more waight alot of people go that route it hadles realy good too you can also use the fwd rear ea82 struts for a 2" lift in the rear and it wont change the spring rate or were the car rides on the struts so you would keep your 50/50 bias of the stock strut as it was made for the rig i am using nissan 300zx front struts with stock springs on the rear of my rig they retain the 6" of traval but uses a larger diamiter rod so it dosent bend as easaly as the stock strut shafts do and its made for a vary heavy turboed rig so the damping is better than stock also i beat mine till the body failed then i redesigned it and then life happend and i wasent anywere i could work in it or run it but thats gona change soon as im finnaly gona move in to my house and finnaly have all my stuff in one place and be able to work on my rigs and test them and break them and rebuild them again and again -
If you can weld its easy to do a 4" lift but if you cant weld then stick to the 2" lift and a sawsall with all the other limitations of this platform you wont get alot more performance by going any bigger and at 2" you wont need to mod the steering ether any more than 2" the axle shafts hit at full extention so you have to drop the engine crossmember and mod the steering to get the axles to clear -
So i am putting together another ddd rig i pulled my loyale off the road due to to many questionable parts and untested designs and i just dont want to risk it on th3 road i have a 3.9 duel range and a 4.11 outback trans and diff and a forester 4.44 set up the forester is going to be the doner rig the outback is getting a new trans also im planning on running around 30" tires and some bumpers and what not i also have a 2000 2.2 to port and polish and mod out for the imp it should be a great daily driven desert runner i have to traval around a mile through the ohv park to get to my house so i need something that can take the woops at speed cross big sand canyons and dry creaks and light rock running day in day out and thats just getting to town my big truck has a problem getting stuck all the time some times 3 times a trip not a big deal but time consuming and it burns alot of gas just running to the store the plan is to swap all the suspention from the forester use the 15" rims from the outback and swap the trans for better gear ratios i probably wont lift it any more.than just the forseter parts to save gas inshould be moving in to the new house in a month or 2 so i should have plenty of room and time to finnish all my builds like my loyale and the outback and my scout and the imp lol i dont wan5 to move the forester so its off to the crusher unless some one wants it with out its suspention its engine or trans the body is still solid and in good shape there wasent any rust or dents last i looked at it full leather interior too it was just a horable off roader and i dont want t deal with it anymore
Road Trip Repairs, Exhaust woes
ferp420 replied to Brianmitchtay's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If you were in deep water it is posable your timing belt sliped a tooth the belts arent real tight on the pullies so water can get between the pully and timing belt kinda like hydroplaning ive had that happen before its a easy fix if thats a issue -
When i worked at a shop that rebuilt axles we just chucked it up in the vice and smacked it with a BFH but that 2x6 idea shounds nice i dont usaly take that joint apart though unless i have to the silicone boots are definitly the way to go
You can pull the alignment pins out with vice grips and level the block out a bit also
