Everything posted by baccaruda
Bucky is getting Temporarily Retired Today
good points on the EJ22 by 91Loyale and Ed.. it *will* be a lot for a 2WD, and an EJ18 swap will make a one-day job of putting in an EJ22 if you ever want to 4WD the buckmobile...
where'd you get those blingin' hubcaps? the start of a new project is so exciting... have fun!
Dragging stuff out of the woods
ahhh.. guess what I found? same incident I believe?
EJ22 Brat Swap, couple questions for those who have done it
"the excess" is best off being removed; this will allow for the harness to route either in place of or parallel to the original harness.
Diesel Subaru EA82
w00t for turbodiesel! I wonder if the turbo could be relocated for easier retrofittification in the older models...
R160 ring & pinion setup
I've changed a few 3.7s to 4.11s.. I've never removed the pinion shaft from the 4.11 case.. I put the new ring gear on the 3.7 chunk, put that in the new case with the pinion assembly left completely alone, then put the races for the 3.7 on the new case, bring all the shims with it to a driveline shop, and plunk down $50 and get that all done for me... hope that helps... BTW a shop could adjust the front-back for you, as well as the side-side like I have done, at the same time.
- T-case
Rust Prevention- Best Method, Hot Oil?
cosmoline Sounds like you'd have to reapply every time the weather got over 80degrees...
Dropping a '81 fuel tank help
Hm, sounds like a job for a square of plywood and some jackstands to me. have fun! maybe take it to the carwash and spray the crap out of the underside to save your face..
Hard Tonneau cover for gen 2 brats
As long as the sides of the top don't slope in upwards toward the center, which would leave gaps on the side when lowered, that sounds like a great idea. I was intending to use Camaro window struts for my "1966 Barracuda hatchback" idea... never came to pass but those would definitely be what you'd want. You could also get struts from a canopy/tonneau shop but they'd probably charge you a lot more...
swapping 2wd 4AT into 3AT car???
John (alleyboy), are you interested in ever running the car as a 4WD? You can block off the driveshaft output of the 4WD with a CV boot w/small end plugged if you want to do just half the conversion now... no gear oil loss that way.
"Desert Fox" Edition Hatch Decals???
easily. My boss just got a pro-grade vinyl plotter but we're all n00bs as far as that's concerned... there's also no reason that custom themes couldn't be produced as well.. Is there a rear piece for the tailgate?
Control arm question
be careful that the hole doesn't have a taper....
what size are the ea81 lower heater hoses?
I think 5/8" will work.. you aren't going to find metric BTW I sent your headlight bezel stuff yesterday
84 GL with ECU light.
make sure that the green test connectors aren't plugged in for regular driving; I just "fixed" my EA81T's ECU light by unplugging the test connectors.. the PO must not have known that they are normally to be unplugged...
I'm sure Ken's got pics of you in distress
Creative Clock Replacement Options
I tell him that if he can fix the clock in your Subaru that he's hired!
yeah, sounds more like a motor donor to me..
EA81 tranny matchin up to EA82 Engine
Your tick can probably be addressed by resealing or replacing your oil pump, search for reseal and pump (3-character words don't register in the search ).. an easy job on your car...
Some have 5-lugged their EA81 cars by drilling out the EA81 control arms to accept the larger EJ ball joints. AFAIK noone's fragged a control arm from this yet. Then swap the tophats.
Rear Disc Brake Swap??
ditto that. Plus you'd be half-prepped for a 4WD swap! (I didn't know bucky was a 2WD! )
what else for the ea to ej swap....
best bang for the buck is the EJ swap. you're talking a couple grand into an EA motor before you can flog it without holding your breath. Plus parts are easier to find for newer motors....
EA flywheel drilled to EJ pattern??
can you put an EJ starter gear on an EA starter?
good for you! and thanks People who dump stuff like that in the woods should be
EA81 overheating
change the thermostat, give it one chance not to overheat, then change the radiator. I personally would just change the radiator anyway..
