Everything posted by wtdash
Meet Betty!
wtdash replied to Gnuman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey are a common upgrade on turbo cars when upgrading the fuel injectors...I've not read about any reliability issues. I HAVE read they are noisy, but not on my Forester. There are different sizes, too - @ least a 195lph and 255lph. The 195 is plenty for any stock Subaru (including the WRX/STi - as their stock pumps flow around 175lph.) GL, TD
Meet Betty!
wtdash replied to Gnuman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWalbro pumps are <$100, but overkill for a stock engine. I'm not sure about interchange, but NASIOC has 'em for sale, if a WRX/STi, low-mileage/used is an option - LINK - you may need an install kit. (I put an STi pump on my '90 Legacy, w/the aid of a Walbro install kit, IIRC.) Good luck and enjoy the new ride! Td
How to test EJ25D block out of car?
wtdash replied to wtdash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah 'not worth the effort' is what I'm thinking now, too. Thanks!
I have the EJ25D (Phase 1, DOHC) out of my '98 Forester. It went thru 3 sets of head gaskets per the previous owner - the original set and 2 replacements. They used a local mechanic, in the middle of nowhere MT, who actually knew Subarus from our brief discussion. Supposedly the heads were machined and OEM HG used. But the fact that the HG blew twice leads me to think something else is wrong. The car ran, but not well, and I didn't do any compression tests, etc. before removing it. How do I test / verify / ensure the block is still good before getting the heads done and putting it back together for another project? Can the rod bearings be visually inspected (by a mechanic - not me)? Thanks, Td
New problem swapped transmission won't move
wtdash replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you check the wiring while the pan was off? There is a POST (I can't find it!) about a dented AT fluid pan that I subscribed to on an Outback...my 1st swap I pushed up on the AT trans pan and dented it. This BROKE a wire that caused some issues - can't recall exactly what - it did also throw a code. Dropped the pan, repaired the wire and I was good to go. Just (another) thought.
how to disable the airbag on a 93 impreza
wtdash replied to jelly man's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmm...adding to hi-jack a good idea? Mid-1992 Legacy's got driver's-only airbags, as did the Impreza since its inception in '93. Both got Dual Air Bags in 1995. Source: Cars101.com
wtdash replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAT Trans fluid Capacity is 8.8 US Qts, per the FSM. Doesn't specify the TC capacity separately.
wtdash replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust to clarify...the fluid shows on the dipstick, correct? It's a PITA to fill these 4EATs as the difference between Low and Full is about a pint, and fresh fluid can be hard to see on the 'stick...so it may still be low.
1998 forester death rattle
wtdash replied to Ricearu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe EJ22 had the EGR valve on the Automatic, not the 5-speed, AND the dual-port exhaust heads in '95, which match your EJ25D exactly. The newer EJ22's work too, just make sure it has the EGR and their single-port exhaust header/Y-pipe. Other than minimal vac line rerouting, it's plug-n-play...the Forester's ECU will run it. Also, you checked your heat shields? They've been known to rattle....Just checking the simple stuff, too. GL, Td
wtdash replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi, Post your trans ID # so I/we can double-check trans vs. rear diff ratio, but if it drove fine AFTER the swap before acting up, that's not the issue. I briefly drove a car w/a 4.11 trans/3.90 rear dif and it wasn't as bad as you describe. On my own Legacy I had the delayed AWD engagement and fixed it by following the instructions on here to file down the grooves (POST) on the rear output shaft that hooks up to the tranfer clutches. But the fact that the FWD fuse does NOT help, means it's electrical or completely broken.....if the FWD fuse DID work, you'd get rid of the binding since the Duty C disconnects the rear drive....but the binding in a straight line has me puzzled..unless it completely destroyed the tranfer clutches???..... So.....if it's an electrical issue, look under there and see if you find something loose, etc. IIRC, the Duty C is enclosed in the rear housing (PIC), so unfortunately it has to come off to replace - you don't have to remove the trans to fix, but it's still a big job, IMHO. Also, you should be getting the 'Power light flashes' and can then check the codes. If you have a replacement rear housing, I recommend filing down the grooves b4 installing it...save some more grief later. GL TD
no horn, no cruise, and ABS light on
wtdash replied to johnceggleston's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX99.9% sure it's the roll-connector/ clockspring...same EXACT symptons on my '98 Forester - no Horn/Cruise/ABS light on. Replaced the CS and back in business. Pulling the steering wheel isn't that tough...getting the damn airbag connectors apart and fishing the harness wires out was a PITA though. You'll have no problem w/it. Couple of links for reference #1 and #2....may have to register (free) to see all the pics. GL, TD
strut ?
wtdash replied to Suba9792's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCovered extensively on here.. Please SEARCH and come back w/questions. Td
Engine Swap
wtdash replied to LanceDa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAccording to this site - right here on the USMB - the phase 2 EJ25 BLOCK started in '99 for all Subarus. The Legacy line - OB/GT - retained the DOHC heads; the rest went SOHC. (No, I don't know why. ) Edit#1: Our friends on SubaruForester.org confirm this HERE. Edit#2: I believe the Phase 2 had the 8 bolts between trans/engine as well. So, that leads me to believe that the '99 DOHC heads should swap over to an original '99+ SOHC engine....and that of course means the engine harness - on the DOHC intake manifold- can be reused to ensure all the sensors and wiring stay the same, which I'm guessing is why you want to swap heads? Edit#3: And since I'm one of many that have done it, you can still swap in a '95 EJ22 (block and heads) from an AT into the '99 Legacy OB/GT and it'll run like stock (just slower). Td
92 turbo legacy questions
wtdash replied to turbo-baron's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX^+1 Stock boost is <9psi. Using an MBC it can be upped to 13 before hitting factory fuel cut. There are 'fuel cut defenders' which can let you go higher. 19psi is the 2-Bar MAP sensor max. The stock VF11 turbo is probably maxed around 14 anyway. Popular upgrade is a WRX TD04 and '06+ IC - but requires custom install to re-route hoses and wiring. You'll want to consider fuel pump and injector upgrades over 14 psi, too. Stock turbo 4EAT is stronger than 5-speed, from what I've read...as stated, keep it cool! The WRX suspension bits should work..not my strong point...there is good info on Legacy Central. GL, Td
Turbo Question
wtdash replied to NV Zeno's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
- Turbo Question
wtdash replied to NV Zeno's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe oil line to the turbo or the return line (a rubber-type hose) to the head could possibly develop a leak but neither requires replacing the turbo. Much more likely it's just a cam seal or similar. Has the T-belt been done? If not, that's a good excuse to reseal the easy to-get-to stuff. Side-jack: Yes, turbo cars are higher maintence...but once you're boost addicted you don't much care. :-) (Not sure the Loyale or Jetta (turbo diesel?) are good examples of turbo's performance advantage - they're both kinda slow in NA form anyway.)- Testing the throttle position sensor on an 1992 Legacy EJ22
wtdash replied to pvenuti's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi, Check out this POST on Legacy Central about 1/2 way down where there are links to the FSM testing of the TPS. Gl, TD- Slow cranking - Delayed start on Forester
wtdash replied to wtdash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know just enough to be dangerous, and a detailed explanation makes it useful for the next person w/an issue. I'll update this quote when I replace the starter, which sounds like the route to take. Thanks to all for you input....- Slow cranking - Delayed start on Forester
wtdash replied to wtdash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was looking @ it and it doesn't look OEM...I'd have to pull it be sure. I noticed that the Forester and Impreza used the same manual/5-speed starter from 1993 -2002, but the Legacy uses a different part number over the same years. Doesn't make sense to me as all the engines/transmissions pretty much interchange...anyone know if the Legacy/Impreza/Forester starters will interchange? Thanks- Slow cranking - Delayed start on Forester
wtdash replied to wtdash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX^^^Awesome info...thanks for the detailed explanation. TD- Slow cranking - Delayed start on Forester
wtdash replied to wtdash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo, if the solenoid is/going bad, would it crank slowly? Or are they 2 different parts of the starter? Thanks, td- 96 Legacy Center Diff lock switch
wtdash replied to JSB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow to pull codes on 4EAT (@ least 90-94): http://www.surrealmirage.com/subaru/trans.html Thanks to JC/Legacy777 for the info.- Slow cranking - Delayed start on Forester
wtdash replied to wtdash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'll double-check...I may have missed it. The batteries are rated the same @ 625/525cca, IIRC. Both are right @ 2 years old, but different brands. Thanks, Todd- Slow cranking - Delayed start on Forester
-1998 Forester w/162K miles (only owned it for a 1.5K of those miles) so don't know much about its history of maintenance. -When 1st starting it cranks slowly and finally starts after 2-3 seconds. It's bit better when warm. With winter coming, I'm worried it won't start @ all below 30. -I've checked my battery connections and cables - Re-tightened the starter cables - Swapped the battery w/my '90 Legacy - no difference - Legacy spins right up and starts almost instantly. -Fresh plugs, good wires, tried a different coil pack. -When starting this morning the starter didn't 'catch'...but did on the 2nd try. I think it's the starter solenoid not engaging the flywheel? There's a whirring/spinning noise, but the engine doesn't turn over. This has happened maybe 3-4 times over the last 2-3 weeks. I'm suspecting the Starter - unknown condition/age, but wanted to hear what else to check. I've read you can replace the 'brushes/contacts' in the starter/solenoid? Thanks Td- My 2nd Rubicon Trip...
Great pics and weather! I'm no 'wheeler, but have been out a few times w/friends in their jeeps. Always lots of fun. Maybe when I get tired of playing w/my Subies, I'll give it a try. There are a ton of places to go up here in N. Idaho. Thanks, TD P.s. your Sig 'links' are broken. - Turbo Question
