idosubaru
338
no coil over conversion comments, i have the parts, but i'm not doing it unless time makes me! this is a new to me XT6 i got last week. finally got the AWD automatic i've been looking for.... the compressor runs for 10 minutes then shuts off (by design to prevent overheating). air susp light blinks and no struts air up. installed another computer and the same thing happened, no change. if i ground the compressor (to turn it on) and solenoids for each strut, the drivers side struts air up fine and hold air, but neither passengers side will air up? maybe i just need to jack the passengers side up to get it started? i think i may just swap all 4 air struts from my previous (rusted out) daily driver as i know they are all good. does anyone know how the air tank works?
4EAT's have been around since the late 80's but are not all identical. i'm not positive on the dates....but it doesnt matter just look at your transmission, you can already tell yours has a spin on type. pre-1998 do not have a spin on filter. these are the ones that don't require any filter replacement because there's no filter to replace. change the ATF. there is a screen as nipper said but it's pointless to replace...also as nipper said. 1998 and newer 4EAT's have a spin on that you can change.
are you sure the rear air struts are bad? i'd bet they aren't. if both are deflated it could be something else. it could be a 50 cent o-ring. or it could be the computer or something else. if you're sure the air bag is leaking you can blow tire sealant in the air strut to seal the leaky bag. the front is easy, just blow it in the top...not sure how to get to the rears to do that though. replacement with regular (non-air) struts is the best option by far. the air suspension is expensive and difficult to troubleshoot if you're not doing it yourself and have a horde of extra parts. if you want to trouble shoot - at the drivers side front strut top in the engine bay should be a long connector (female) that doesn't plug into anything. it's just hanging there by the strut solenoid. facing the end of the connector, each pinout grounds a solenoid. facing it from left to right on the top row is: Front Passengers Side, Front Drivers Side, Rear Passengers Side and Rear Drivers Side. if you ground each of these pins (just run a wire from negative battery to the pin, that's it) you should hear a click at each strut. that's the solenoid clicking. anyone that doesn't click means it's not working and needs to be replaced. the rear passengers side is hard to hear yourself while grounding it on the opposite side of the car so listen carefully. i'd be comfortable with using a used air strut assuming it's in decent shape and cheap. inspect the bag and make sure there isn't significant rust where the air bag meets the bottom strut support. the metal rusts and rubs on the air bag. the internal height sensor can fail, but that is rare so if the bags good i'd go for it.
you're positive it's HLA noise and not something else...fuel injector? how long have you been running synthetic? if it's not horrible i'd probably run with clean synthetic and frequent oil changes for awhile and see how it gets. some ATF or seafoam may help if nothing else does. oil pump ever been resealed? that may or may not help.
Resurrect an XT6 party?
idosubaru replied to Ever Victorious's topic in Meet n' Greet. Your USMB Welcome Center
that's your problem, you let minor things get in the way of progress!!!!!! you'll get large fines and tickets, but they let you off when you get to court and knock the fines down to nothing. sometimes they even let you go. -
socket wrench with a hammer. pound that handle hard and it works like an air impact wrench. if the starter is still in place you could give it 12 volts if you can get a battery to the car. put the socket on the crank pulley and rest it against something solid. bump the starter and that'll knock it loose as well. you won't have one but a long crow bar or digging bar placed between the lug studs will keep the wheels from spinning. a similar item, but thin, can be wedged through the rear ujoints to keep the rear output shaft from spinning.
buy the generic $3 bag of o-rings like he said. it'll have the ones you need. be sure to oil them before installing, don't install them dry. not sure what you should oil it with...preferrably lubricant from the a/c system, but maybe motor oil, brake fluid may also work. while the system is open, replace at least both compressor fittings and any other fittings you can easily get to (condensor/receiver/drier)
fuel door latch doesn't work ?
idosubaru replied to idosubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
thanks guys. i'll check to see if the latch works. i'll bet mine is spring related, i don't recall it having much spring to it...but didn't really pay attention either as mine have always worked. -
how did you know it was a broken cable and where did it break? the latch at the cap seems to work...it holds the door shut but won't release it. it pries open like you said. -
post this in the off road forum, they may know better. use an on-line tire size calculator to figure out total diameter and compare to what some other guys are running (they probably have 15" or 16" wheels). but there aren't many outback XT offroaders so info may be limited. some vendors (Allied Armament) have made lift kits for some EJ models so they may know as well how big you can go on a stock setup. the search function might be your best bet on this...
can you post a picture? something is certainly weird. you're sure it's not coming from the ATF fill tube where it fits into the trans? you need to verify that part of the transmission housing is flat where it's leaking. if it's flat and the pan is flat it should work. are you sure it's the right pan as well? i guess so if it fit and the gasket fit? i'm still wondering if it's really the pan and not something just above it...which is why i ask about the fill tube/dipstick tube.
just got a new XT6 the other day..finally found the AWD Auto i wanted. the fuel door latch doesn't work. i push it and nothing happens. never looked at one of these jokers before, any clues? did a search and couldn't find anything...except posts where people didn't know how to open it!
how old is this vehicle? the radiator could be plugged up. no coolant loss? are the fans turning on when the car starts to overheat? i'd look into the radiator being plugged. when the car is warm...feel the hoses and make sure both are hot to the touch. a clogged radiator will often result in one of the hoses feeling "cold" to the touch. after that i'd think about the water pump....not sure on how to test it.
More rear disc swap questions
idosubaru replied to mellow65's topic in Old Gen.: 80's GL/DL/XT/Loyales...
this has been discussed/argued in other threads but i don't know that you need the proportining valve anyway. try searching on some other threads if you have questions about that as i'm not positive. -
How to remove an engine/tranny without a hoist
idosubaru replied to Numbchux's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the engine and transmission come out of the engine bay as an assembly. no need to pull them apart, just pull them at an angle. XT6's will come out the same way as well. -
what could it be now...
idosubaru replied to Urabus-84HBDR's topic in Old Gen.: 80's GL/DL/XT/Loyales...
old radiators become inefficient. how is yours? how is the radiator cap as well? in my experience, compression testing is not helpful in diagnosing head gasket failures. all of the slow leaking gaskets i've seen that run and drive fine will test fine. as a matter of fact i've seen them test higher than the other cylinders if they start leaning towards "getting worse". i believe too much water in the cylinders somehow bumps up compession artificially or the gauge just doesn't like it. whatever the reason, i've had good readings on bad head gaskets. i'm not saying yours is. -
i didn't think these has retaining screws but wasn't sure. older soobs do. unless i'm mistaken i think the rotors should come off if you take the caliper bracket off. let someone else chime in but that's how it usually works. newer ones usually have no problem coming off. some taps with a rubber mallet if it's stuck at all. if you jack the front of the car off and try to turn each front wheel slowly you can probably isolate which rotor is warped and only replace that one. you'll feel the wheel "catch" at one point of the rotation. this is the bad rotor. make sure your caliper slides are greased well and the piston moves in and out fine. a sticking caliper will heat up and warp the rotor.
if you wanted to risk it you could keep on going since it's a 1996 which is a non-interference year. not that i recommend that. the tow bill and follow up "emergency" repair bills usually aren't pretty. my buddy has 200,000 on his toyota he bought with 60,000 on it. supposed to change belts every 60,000 and he NEVER has. if he wasn't 1000 miles away i'd do it for him.
need some guys with block experience/ideas
it's at the top of the block towards the front of the engine, the bolt head is on the passengers side. i know exactly what o-ring you're talking about, didn't think about that. picture is no where to be found. i'm going to compression test and clean it off see where it leaks from after that. now that i think about it, the oil dipstick always popping out leads me to believe it's blow-by as well.
