Everything posted by ShawnW
are EA82T & EA82 same trans?
Take the axles and the trans out of the donor car and you'd be fine to use it just the Turbo trans will like GD says have a weak low range.
Info on Adaptor Plate Needed
These old tranny's are pretty tough. It would entirely depend on how hes going to drive the car. If hes going to not try going 2-4th gear skipping gears and hard downshifts, etc...he may get away with it. The adapter is needed. The depth of the flywheel and the distance between the engine and trans are what is helped by the combo. The clutch disc sizes are the same outer diameter. Thats a GREAT engine for a conversion like this. We dont have the luxary of a 2.0 WRX engine with no ODBII diagnostics and its a lot easier to wire up than any of our WRX engines are. Take pictures and let us know how long the trans lasts if you go with the EA tranny. The WRX one would certainly last longer but I dont know that its a HUGE difference.
Started conversion today
Smog and plates today. Still dying on idle at stops, gotta try an IAC replacement now and see if that helps.
Trick to "mating" block and trans.
ShawnW replied to nighthawk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDO NOT USE THE BOLTS TO DRAW THEM TOGETHER. You can do MAJOR damage to the transmission, clutch and pressure plate doing this. Make sure you arent hitting the motor mount studs on the crossmember. if you are the trans isnt jacked up enough. Get the bottom studs aligned with the holes in the tranny and then step to each side of the car and look to see that the bellhousings are EXACTLY parallel to each other. If they aren't correct the easiest thing (probably the engine) such that the angle is more condusive. Most of the time when you are fighting this tooth and nail its because the chain on the hoist isnt set at the proper angle for the engine to hang at that proper slant. its magic when it goes together and you get better every time you try. Be sure to use a good clutch alignment tool and that you can EASILY get the alignment tool in after you torque the pressure plate.
Oil capacity and spark plug socket of EJ18
ShawnW replied to bowjam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts a 5/8 spark plug socket. Hardware store should have a socket for you. No need for a wobble on the socket if you ask me. 4.2-4.5 quarts with filter change.
Me=Owned:(
Ej22 Ftw... you know, something reliable and with 1 timing belt that rarely breaks, a coilpack ignition, and regular unleaded pump prices?
Drove on rim for 26 miles.. problems??
Thank you I needed that.
Step-by-Step Head Removal EA82 Turbo
Step 1. Beg to borrow or buy an engine hoist from someone. Step 2. Pull engine from car.
What do I need to get functional cruise control on a '92 Legacy?
Im pretty sure its stuffed up in the dash next to the ECU.
Already got em and im thinking ill debadge the liftgate of anything VW and put the URABUS on the back.
Sure! PM me for a phone number to use when you are out here.
Bumper corner covers on 3 corners (LF, RF and LR)....
Buying a subaru
Buy a copy of how to keep your subaru alive. The first edition would cover yours VERY well and it has a wonderful section on how to look at a used car.
project porsche madness
Junkyard (pull a part type) and get an Audi or Porsche trans you like. Then an adapter plate from kennedyeng.com to put a Subaru engine in is available to mate to a VW/Audi trans so maybe they sell VW to Mazda adapters.....doubt it but try. What does this have to do with Subaru?
syncro westy engine swap?
Thats gorgeous and local to me. Oh well I like mine fine!
EJ22 Head Gasket Replacement Question
Ive rebuilt a lot of them and we use OEM gaskets and copper spray with no issues. Remember the source, they "cure" premature head gasket failure with stop leak. "Cooling system conditioner"
93 Legacy AWD Non-Turbo *almost* Overheating
ShawnW replied to stevenbriggs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow fast does it get to this temp? Any visable leaks or loss of coolant?
Finally posting a photo. The oil marks on the driveway are from my Toyota, not the URABUS.
will welding damage the ecu or sensors???
Unplug the battery and I think youre pretty safe. Keeping the ground lead as close to what you weld is important too.
MEET: CO: May 21th at Red Rocks Park
I feel your pain. I showed up in a Toyota alot of times. This time a VW but its the heart that counts.
Forgot to get a speed sensor so it won't idle when warm and thus I cant take it over to smog it. Ordered it tonight. The first major snafu I need to address is the fuel tank. It obviously hasnt been filled FULL in years....I filled it today and a 4.5' diameter puddle of unleaded showed its ugly face on the ground when the pump kicked off. I think this is probably common just gotta see if the tank is rotted or if the vent hose that probably comes off the top is screwed up.
Please, Put My Lights Out
ShawnW replied to The Dude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPull up 1 click on ebrake cable. Do a search please. Thread is being closed because its been covered ALOT in the past and its known to cause a big debate on safety, insurance precautions, whether or not its legal (you are disabling a safety related item), etc. BTW: Focus on something else your gas mileage isn't dropping a significant amount.
Bringing back to the top, wanted to find the date (May 21st) again.
donating to USMB
Priceless quote. Thank you.
Shes ready to go apply for plates and smog now. Shes burped and the last few connections will take under 10 minutes prior to leaving. 3 months later shes ready to roll but thats a lot of procrastination.
