Everything posted by ShawnW
Crank pulley...what about a gun?
I would just pull the engine out of the car if it gave me that much trouble.
Mini Brat
Thanks for posting I wish I could afford to buy and ship that here.
you guys KNEW this was coming (coupes summer wheels)
Nice job on the repair I cant see it. Something some of us knew all along was those little EA81 era cars that aren't 4wd, hatches, or Brats are still going to draw attention and money eventually. They are unique and are tossed aside quicker than the sought after models.
The Boomerang (Mountain Grizzly) Returns....
Keep plugging along man those bolts aren't going to be that bad to fight. A sharp set of drill bits and a lot of patience should get them out.
Transplanting Aftermarket Fuel tank
Where is Sanders at ? I think you would be able to get a tank from somebody on the forums here. A Wagon, sedan, coupe or brat tank will work just not a hatchback. Must also be from a 4wd car. Post a wanted ad in the marketplace.
Ej swap here we go a wiring
Oil sender: Ive done them with the ea sending unit, take it off the old engine take it to a shop that makes stainless steel brake lines and ask them to adapt the end to a fitting that will plumb into the spot where the dummy sender on the 2.2 is. Give it about 10 inches of line and lay it between the ps pump and the alternator and wire to that. I wish I had a picture of that still. The temp won't send enough reading. I think somebody here used a resistor to make it work. I just used an aftermarket temp gauge.
99 Outback won't start. Loud crackling noise under dash
ShawnW replied to mmfreitas's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRapid clicking is the solenoid making the noise but usually bad battery cable or connection causes it. Crackling is another noise and could be a bad connection as indicated high amp like ign switch connector.
Is there any reason preventing re-studding hubs for ball seat lug nuts?
Doesnt seem like that bad of an idea just limits your ability to put Subaru wheels on it again.
Clutch smell when AWD is engaged?
ShawnW replied to capewaveride's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTake the car to the dealer immediately and have them look at it. If they replace the clutch and the symptoms persist I think it may be you as harsh as this may sound.
EJ Swap - now noise in my speakers
IT could be the fuel pump which I normally ground on the body of the pump itself.
New EA to EJ Manual - Tidied up :)
Downloaded and printed thanks Numbchux and rxleone. Shawn
hopefully, the EJ22T found its destination
ShawnW replied to bheinen74's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXId get 02 WRX complete engine and wiring harness from a rusty or wrecked one and put the 2.2 shortblock in with all its heads and engine management. Then you can do Access Port or similar, lots of wrx upgrade pieces available, and the wiring isn't terribly hard. I have the diagrams and would do a cutdown harness for you for a reasonable fee.
Removing Heads from Impreza w/o engine pull?
ShawnW replied to s'ko's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor one head on a recently serviced engine I might consider it but otherwise I pull the engine. I have become quite quick at pulling them thanks to this practice.
Jibs' EJ Brat
Keep going-- that is looking like a great project!
price of a H6 swap
Bought one here in Colorado for the rally car for 500 with all the pieces we needed except motor mounts which were destroyed in the collision the car had been in.
Anybody near Farmington, NM?
I know its too late for this advice but next time call a theatre and have them physically mail a gift certificate. Thats the "old school" before the internet way to do it. Soft jab with broom handle nothing more.
Just purchased 82 GL Wagon with 54k in NC!!!
A nice set of sheepskin ones would protect it and be a nice added amount of cushion to the seat if you can still find them. I 2nd the plaid seat protect that thing they are brittle.
New From Edmonton Alberta
Keep fresh oil in that motor and it will last a long time. Flush transmission or drain and fill often as well. Coolant change every 2 years. Btw welcome to the forum!
Rebuilt Hitachi has flat spot.
Sounds like time for a trip to the junkyard and find another car like yours and start pulling the vac lines one at a time till you find the pellets.
Momo hub 7302 question
I searched "Momo 7302" and found this thread: http://www.ultimatesubaru.org/forum/showthread.php?t=73409&highlight=momo+7302 Sounds like you need a 7303 adapater or to use a Justy steering wheel as it shares the same splines.
I seem to recall that not working you might do a search to verify though.
How To: Replace bulbs in radio
Awesome I have seen a growing number of these with this problem recently and coupled with the climate control bulb fix this is pretty cool. It would look stupid to have all the climate control bulbs fixed and not the radio.
ShawnW replied to Topher1556's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAwesome I have seen a growing number of these with this problem recently and coupled with the climate control bulb fix this is pretty cool. It would look stupid to have all the climate control bulbs fixed and not the radio.
Got a question about my 98 Forester
ShawnW replied to Subieguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts not all bad. You can use a long block from a 96-99 Outback and many legacy cars. You could convert it to an ej22 rather easily as well but I have a good recipe for not getting CEL's if you want to go that way and many people cut key corners and end up with lots of CEL codes. This might also be a problem in CA though and not possible legally. I like the 96 motor the most its Hydraulic lifters and neater looking valve covers. Otherwise its the same motor. Its also got the 96 piston in the shortblock and less prone to piston slap but not by much.
anyone replaced their seat heaters?
ShawnW replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have done it. You want the smallest hog rings and a pair of pliers usually sold at Farm stores literally they are for Hogs. They are really cheap too. You cut the old rings off by pulling part of the upholstery or leather back and cut the thing off. Usually you start by separating the seat back from the seat bottom. Then there is an obvious gap in the bottom edge of the seat back or a zipper somewhere. Open that up and start finding clips you can cut off. The cover will slowly come off. Then you will find the heater which is a blanketed thing with small wires in it. Usually white cotton looking material with red stitching. Just get it out and put the seat back together with the rings and pliers.
