northguy
Everything posted by northguy
Sure, but you could just PM it to him, he's in Haines now conversing from his computer there.
The fluid was tan and foamy? Normally the fluid should be almost clear, and the foamy part is either air being whipped into it, or water, I would guess. My 4sp whines in 4th, but performs fine. It's just a whiner.:boohoo:
Torxx, if you want to cover him from the border o the Glenallen cut-off, I can pick him up from there and then he's covered "in country".
While you're at it, why not look to expand the product line to include lightweight jackets or vests?
Having to search for snow; now that's funny.
So, how often does it snow in San Jose?
I was just listening to "Car Talk" this A.M. and there was a call that sounded similar to your problem. They said it might be low compression not building enough pressure to get to ignition temperature. Check the compression. Add some Heat - that'll take care of the water problem - buy a magnetic oil pan heater and plug it in.
Iassume you're talking about this in your brat (as seen in the sig. block). Is it just the steering? The shaking at those speeds and then the disappearance sounds more like u - joints or possibly c v joints. If it is just steering, that would be more likely associated with wheel balance or alignment problems.
It really kind of matters where in AK you live. If you live in Anchorage or Fairbanks where you have to pass IM inspections, it won't work as you'll never get it past the inspector. It'll blow his mind. If you are in an outlying area, you can probably sell it eventually as there are a few enthusiasts, but you'd do better advertising it in the lower 48. Sure, it would haul a$$, but the bottom line is that the blue book value for it will still be based on the host car, at least that's how an insurance company will approach it.
Where is this Assieland? I may want to check it out.
Welcome, Jason. We look forward to your collection of knowledge and experience. I think you'll also find there is a good collection of knowledge and experience here that is willing to hep you should you find the need.
How is the return spring on the clutch pedal?
Maybe that's just unethical or illogical.
Where in Alaska? There are a few of us and some are pretty "scoobied" up on things.
So why is it illegal?
I, too, can be a new member!
northguy replied to elcaminokurt's topic in Meet n' Greet. Your USMB Welcome Center
Welcome to the USMB, and there are a number of members in the land of 10,000 ponds. Hope to see more of you on the threads. -
I hope you're carrying survival gear with you and a shovel. On the way back, if you have trouble and get past Tok, give me a call and I'll come pick you up. I'll PM you my home phone number.
