Everything posted by northguy
What would be the best early Subaru to find
One word - Brat. But then, I'm biased.
Awww Yeah(some questions added)
Kelly, I can't help with your question, but good to hear of your triumph over motor goblins. Next step = LIFT!
T-shirt update
That goes without saying. Your quality speaks for itself and your reputation is sterling. John, thanks again for your fine work and generous prices.
Brakes Squealing like Stuck Pigs!
northguy replied to ScoobySchmitty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNow how would you know what a stuck pig sounds like? - WAIT, I don't really want to know.
*...Is this a good price?...*
Tell you what - If you drive it here, I'll give you a grand for it and a plane ticket home.
what makes cars run bad when cold?
Buy a block heater instead and plug it in.
pics of my new wagon finally
Looks pretty sweet - nice score.
Poll for carb users
1. Stock Hitachi 2. Not much real off road - putzing around - does fine OK on highway but no real dynamo - wish I didn't have to contend with IM, I'd have a weber on it in a flash
"How To" wire dual fans with on/off/automatic toggle switch
Hey look guys, Valentine's day was just yesterday. Where did the love go?
can a 6ft4in guy fit in a sube?
If you bend the knees or cut off the head he'll fit in the trunk just fine. That's what you meant, right?
Project 1982 Brat (Bobby meets Dirt) read last post
cancer in the engine compartment around the strut towers. Almost all other rust is repairable. Strut tower rust is fatal.
Windshield Questions
northguy replied to Atomic Robot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey aren't critical, but for about a quarter apiece, you should be able to replace them and then you don't have to worry about your shroud blowing off the car at 85mph. It just looks better if all of the holes are filled, too.
northguy replied to Atomic Robot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYear and make of car would help. So would the location of the pins. Are you referring to the plastic pins that act as anchoring devices in the plastic trim buttons on the bottom shroud of the shield trim?
Window Replacement
Loyale glass and DL/Gl gass is diferent and the install methods are dissimilar also. The removal of glass from a "glued-in" application is best done with a utility knife from both inside the car (cutting closely next to the glass and pinchweld) and then from the outside along the edge of the glass. The old wire method may work but a heated wire next to a piece of tempered glass will cause it to explode. The Dl/Gl glass may very well be rubber set (I don't rightly recall) but even if not so, you shouldn't be battlingthrough urethane - only butyl.
Alaskans?
Nikfu - welcome to the board. We'll keep you posted on the next meet and greet. Good to see another Alaskan.
A small score today
Good score, Rob. What are you going to do with them?
Engine Steam Cleaning....
Since you are subject to IM inspections, a weber isn't an option, but you could send out a call for help to see if there is a Hitachi available on the board. I'd bet there are several. Also, you could check e-bay to see if there's one there. Depending on where you are in CA, you may be able to con another board member to help you with the swap, if you're not comfortable doing it yourself. Also, as to the clutch cable, WD 40 is good for displacing the water that may be in your cable - it's not good for lubrication, though. Hit the cable with ample WD 40, then lube it.
New to Subaru, Am I Blessed or Cursed?
Hudmud, welcome to the board. There are several members in WI, and a bunch in the midwest. If you play around with the search function you will be able to dig up answers to most any question you may have about Subbies in the archives. You can also access the subaru repair manual for information. Good luck and welcome once again.
04 BAJA Bumper DONE.......:)
Very polished and professional. Great job.
*..More Horsepower?..*
I'd love to upgrade to a weber and a new exhaust, but I've got to deal with stinking IM standards.
highest mileage?
Wagons, how can you have over 2 million miles on various cars and not one of them is a Brat? - I know , the name , Wagons Only, but not even one Brat in the whole stable? That's unAmerican.
scuse me while i gloat over my new brat!
GOOOAAALLLLL!!!!! How could you go wrong with a Brat? Even if there were rust in the bed?
melting hood scoop
One couldtry putting the reflective tape on the underside. It might help.
SOrry for the crossthreading, but this needs to be seen. . .
That's too nice. I'm just happy I don't live closer to you guys or I'd be constantly broke getting all of the mods you think up. Nice job, again.
Kudos To This Board!!
Welcome to the board. You may want to be more specific about where in Oregon. There are a myriad of members from OR that you may want to get to know.
