Anti-Afterburning Valve
Backfiring out the exhaust is typical of leaks in the y-pipe or early in the mid-pipe section. The oxygen introduced into the leak combines with unburned fuel and ignites in the muffler. The ASV's fail (reed valve snaps), raw unburned exhaust melts the plastic ASV silencer, and the melted plastic gets sucked right into the carb. Been there, done that..... I was able to remove the plastic bits and drive on. I was lucky. Sometimes it really screws stuff up and the carb has to be torn down to fix it. EA81's rarely (if ever?) backfire out the intake - they are gear timed and as such the valve timing is fixed and to cause an intake backfire an intake valve would have to hang open. GD
Project EJ22 Hatch continues
So what are you doing for the axles? GD
Hubs on older subarus
Typically this is caused by a worn cone washer and improper torque on the axle nut. I've owned dozens of Subaru's and put hundreds of thousands on them - this has NEVER happened to me. I have seen it happen and one time a car I bought for my GF that already had this problem, but once I replace the cone washer, hub, axle, and properly torque the assembly this problem has never returned. GD
ea82 Carb
There's no sensor - the system is entirely mechanical. Check that the choke spring isn't broken. Very often the end with the hook bent into the spring so it can pull on the choke plate lever has worn through and fallen off. GD
Front sway bar clunk (EA82, 4" lift, taller springs)
Obviously the XT6 bar has more of a chance of doing "something" than my stock EA81 front sway (only) had. I'll be interested to hear your results. As for it not being *able* to be built with good handling - that's just total crap. This isn't a lifted truck - it's still lower than most SUV's out there and could easily be built to handle if that's what he want's. While I agree that a sway bar isn't necessarily the best solution out there there are other ways. There are speed sensitive electronic strut systems employed by some of the high-end automakers today - they can stiffen just one side in a turn. I believe Mercedes has such a system. The vehicle can be made to stay 100% level in high speed turns without any sway bars at all. Air suspensions can also do similar things. Sway bars are simply old technology and they have a detrimental effect on the off-road ability of our similarly "old tech" independent suspension systems. It's just about how badly he wants it. He could definitely have both if he really wanted it. This discussion is about whether or not any stock sway bar will do what he wants and what he must do to make it fit *if* it will suffice for his needs. Being he isn't taking it off-road in the immediate future there are good reasons for him to want it to handle half-way decent on the road. I know what you mean about cornering Andy - the difference between my 91 SS and the 93 LS wagon I got for my mother is increddible. I can take corners at 100 MPH in my SS (stock suspension!) that are scary in that LS wagon at 80. As far as I know the only difference are the springs and the SS's big sway bars. It makes a HUGE difference and that's the reason I drive the SS and not my lifted wagon as a daily GD
After-market Platinum/Gold Warranty Coverage for +90K Outback VDC 2003 3.0L H6
Warranty coverage is never worth the cost - if you absolutely cannot repair something yourself and cannot afford the occasional repair bill then you should almost certainly trade it in on a new car. Warranty's are one of two things - an incentive to sell someone a new product, or a racket right up there with selling swamp land. Find out what the average warranty company want's to charge you, and instead put that amount into a separate bank account where it can earn interest. If you have a break-down then use it. Otherwise use it as a down on the next car you buy when you trade the Outback in. That way you aren't just flushing your money down the toilet to some half-baked insurance company. That said, your mileage is still quite low. If I were you I would drop the idea of buying an extra warranty on it, drive it till you are near the next major maintenance interval, and then trade it in. GD
You are correct - you can't heat and bend spring steel like that. It will just turn to crap. Having it re-tempered might be cost prohibitive unless you can do it yourself but I am somewhat doubtful that you have the necessary equipment to temper something that large..... Before you go to heroic lengths though - do a test without the thing. Think about the physics involved here - the body is a lever and the sway bar has to oppose that lever action. Being lifted the body weight is now higher - the lever is thus longer and it will take a much larger sway bar to resist the leverage action of the body. Add to this that the wheel/tire combo is now heavier and pulls DOWN on the bar with more force due to gravity...... both of these together turn the once-barely-adequate sway bar into an extraneous appendage with no real function other than making it harder to change axles. GD
Backseat Swap
They made EA82 GL-10 sedan's with fold-down seats for pass-through access to the trunk. You just need to find one. Or are you talking about a Legacy? Your username says '91 so I'm assuming it's a Loyale.... Legacy's also had the fold-down pass-through option. My '91 Turbo has the fold-down seats as did all the LS and LSi models I believe. GD
Using A/C fan to improve cooling rate
That is the connector for the thermo-switch that controls the main fan. It is designed to be the ground for the main fan - the thermo-swtich grounds that lead when it hits the required temp. As for the AC fan coming on if you apply 12v to the ground circuit of the main fan.... I would have to look at the schematic but I'm assuming they share the same ground and you are back-feeding the circuit by applying 12v to it. Obviously the circuit is not diode protected. Don't do that anymore - it's not appropriate and you could easily hurt something doing stuff like that. As a general rule - green, yellow and combinations of the two are nearly always ground leads - sometimes black is ground as well. Red, black/red, and black/white are almost always hot leads. Those are general guidelines and they are NOT always adheared to so have your schematic and DMM handy at all times. All you have to do is plug that yellow lead into a thermo-switch in the radiator - then you pull the hot lead off the main fan, use that lead to close a relay. Run a seperate fused power lead off the battery, through the contacts on the relay and to both of the fans. When the thermo-switch closes it will energize the relay and power both fans. Start out with a 20 amp fuse and take an Amp reading on each fan - add the two readings together and add a couple amps to find what fuse you should be running in your power lead to the fans. GD
Noob with a general question- what engine do I have??
This is the wrong forum for model specific questions - you need to post in the New Generation forum for Legacy questions. EJ22, Hydraulic lifters (no adjusters). Miss is probably plug/wires/coil pack related. GD
At least try driving it with the bar off - I noticed no difference. With the added leverage of the body being higher and the added mass of the wheel/tire combo the bar became useless - it didn't do anything ON the road and was only a hindrance OFF the road. GD
Different kind of rust repair.
For a beater with a heater I prefer the aluminium sheet and rivets method. Looks much more Mad Max post-apocalypse style. Anyway that's my sugestion. You cut a piece the size you need, bang it into shape with a dead blow or soft face hammer and rivet away. I prefer to avoid methods that will make my rigs look like I had no bloody clue what I was doing..... riveted aluminium will never look like that because there is no mistake - your intention is obvious - to make a lasting, functional repair..... looks be damned. GD
If you are lifted 4" and planning to stay that way toss the sway bar in the dumpster. The sway bar is going to try to STOP the wheels from articulating independently - it wants them to be level with each other. I removed the sway on my wagon many years ago and with the added couple inches of offset from the 6 lug wagon wheels you can't even tell. Besides - I'm not looking for it to take corners at high speeds. The point of the lift is for clearance and articulation - the sway bar goes against the purpose behind the lift IMO. GD
EA-81 Gear Linkage Bushings P/Ns?
EA81 shifter slop is not really caused by the bushings, and frankly they rarely need replacement - I just grind 1/16" off the steel sleeve that sets how tight the two ears clamp down on the bushings to tighten them up a bit. The issue, as s'ko pointed out, is the shift rod/sleeve interface. I have a been through a couple of fixes for this - my most recent is in this post: http://www.ultimatesubaru.org/forum/showthread.php?t=86901 I recently had the opportunity to improve upon this method - I had to replace the 4 speed in my lifted wagon and during the process I decided to change to my "version 2" slop fix as outlined in my above post. I went the next level this time and installed a second locking bolt at a different angle - in this case I had already drilled the shift rod and sleeve for a 3/8" bolt several years back when I did one of my first "clamp style" version 1 slop fixes. Being already larger, I had to go with a 7/16 thread for the main bolt. I then drilled and tapped for a 5mm socket head cap screw at a different angle to help lock the sleeve from pivoting on the 7/16" bolt. I have yet to drive the wagon with this installed as I'm building some new lift components for it, but it feels very solid and I used no new parts in the process. Just off-the-shelf components. I also removed a bit of metal from the bushing ear sleeve as I mentioned above to tighten the rubber bushings and I moved the pivot point of the shifter up by 3/4" to give the shifter a bit less throw and get back some height that it lost with the lift. You can see the where I cut and welded a section of steel rod into the pivot point and moved the shift rod/sleeve section down by the same amount. Anyway - that's the version 3 slop fix as it sits now. I'll be able to fully evaluate it's performance after I'm able to drive it for a while. I'm planning to take it to the show this year. GD
AC refrigerant.
I know at work we often "flush" refrigeration systems with nitrogen - it absorbs any moisture in the system. GD
Radiator verification- and tranny
There is no difference to how the linkage mounts between a 5 speed single range and a 5 speed D/R. The Loyale will take the 5 D/R with no modifications other than the interior consoles and possibly some wiring. GD
Could someone please clarify a few things for me.
All SPFI systems were hot-wire MAF with optical CAS distributors. Being he has a flapper door, his would be MPFI or Turbo - at any rate along with the flapper door MAF always comes the non-optical distributor (read - mechanical advance) thus the timing setting is different. All I have are EA81 FSM's but my '84 FSM shows 15 degrees for the flapper door MAF EA81T's - I'm assuming it would be similar if not identical for the flapper MAF EA82's. GD
Oh Lord Please send me knowledge?
This belongs in the old gen forum. Have you actually tested the fuel pressure? Sounds like perhaps you installed the wrong pump. GD
Rolling Tool Boxes....
I use both SAE and Metric. Almost all Metric at home and both at work - a lot of stuff I work on is Metric these days but I also work on a lot of old stuff that's SAE - Industrial equipment doesn't get retired just because it's old. Very often I find myself working on gear that's older than I am. But probably 75% of my time is spent working on a specific brand of german pumps and obviously that's all Metric. I have to be prepared for whatever though and I find that most of my BIG stuff (over 3/4") is almost exclusively SAE. I do run into the odd 24mm 6-point or 17mm Allen though. I bet I'm the only one on this board with Ford wrenches (monkey wrench) in 4 different sizes up to 18" GD
The flapper MAF car's are (I think) 15 degree's for timing. Other's will know for sure but I'm pretty sure that's accurate. I know it is for the EA81T's which used basically the same system with a mechanical/vacuum advance distributor. 4WD 3AT's use 6.8 quarts of ATF, front diff is 1.3 quarts of gear oil (it's all GL-5 rated these days - any 75w90 will do). Rear diff is 0.7 quarts. Someone else will have to answer on the filling of the TC - I don't run auto's (especially not the 3AT ) - and if I have to pull one there's no way it's going back in GD
82 Wagon nightmare
I had this issue with a Hitachi once - I am fairly certain it was a float needle that would bind in the seat and stick closed. The engine runs out of fuel and acts like you just ran out of gas. After a period of time, or as soon as you screw with the thing in any minor way the float unsticks and it starts running again. The only way I can thing of that you could test this theory is to wait till it happens again and try to see if there is any fuel in the float cavity - you will need a flashlight to see the fuel level through the sight glass. If there's no fuel on the glass you have found your problem. In my case I rebuilt the carb and had used the aftermarket viton tipped needle and new seat - when I swapped back to a stock brass needle the problem never returned for as long as I ran that carb. GD
engine swap
Depends on how much of the EA81's electrical you want to use. The engine will mount up without much difficulty - I'm not sure if the pitching stop will be an issue but it's something I would look at. At most you will have to fab something for it. The EA71's electrical can be used (complete with the distributor and all) if you want but the EA81 has a superior system that doesn't need the external VR, or the ignitor and ballast resistor. You might ask Jerry if he knows of anyone that's used his kit with an 80 body - the floorpan sheet metal could very well be a different part number and as such you might have rubbing issues. The 5 speed is VERY close to the pan even with his kit - possibly only 1/8" in places. The need for the adjustable pitching stopper to tilt the engine back somewhat for his kit is one reason I asked about it above. You will definitely need a custom driveline. There's no way around it with the hatch body. Jerry will know the exact length of tube between the yokes that will be required. Other than those items - I can't see any reason that you wouldn't be able to do it with minimal effort. Although I hate doing tranny swaps - but that's just me. GD
Check craigslist for out-of-work professional mechanic's selling boxes - decent used high-end stuff is my preference over the Sears catalog replete with Chinese import garbage. I have 20+ year old Snap-On stuff that I have bought off eBay for less than the cost of a new one at Sears - I just had a ratchet rebuilt for free on the truck (took him 5 minutes tops) that cost me $27 shipped out of the bay - I can't buy a Craftsman for that and I would be back there every 6 months having it replaced for not ratcheting correctly or being stripped out. No thanks! My bottom box is a 1982 - it's on it's second owner as far as I know. The drawer capacity is something silly like 125 lbs and they slide freely even loaded up - without BB's. If I break a slide it will be replaced for free - even on something that old! You do enough garage time to warrant something decent Mick - don't go the Sears route if you can help it. I've been there and although you may never have a problem with the thing there's always the chance that you might - it's partially the customer service that's the issue, but mostly it's just that should you find something indadequate about the product the most you will receive is a replacement - a replacement that's just a cheap as the first one you broke. GD
engine swap
Mounts are the same yes. GD
EA 81 Dual Carb.
In over 10 years of working on and owning Subaru's I've seen exactly 1 of these in person. And I'm not sure if it was an actual dual-carb with the reversed valve heads and twin exhaust ports or if it was simply an original dual-carb manifold (not easy to get either but there are some out there - the carbs on them are crap though) coupled to a modified USDM EA81. I'm pretty sure it was the latter though. I have yet to see or hear of an actual full race spec EA81 dual-carb here in the US. I've seen pictures and there have been unverified reports, etc. The JDM dual carb was 108 HP, and the full race version was rumored to be around 150 HP. You are highly unlikely to see one or be able to buy it for your boat. They are coveted and if anyone had one I doubt they would sell it for that purpose. If you want 90 HP with the EA bell-housing then you need look no further than the EA82 SPFI - you can pull off the fuel injection and install the carb manifold and a Weber if you wish. They were rated at exactly 90 HP and they are a dime a dozen. GD
