440
New Motor suggestions for an '83 DL 4WD
GeneralDisorder replied to washakie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Probably just blown head gaskets. These engines are almost impossible to crack. It's been discussed, but no diesel conversions have ever been done. The EA81 is one of the best off-road engines you can build. I sugest you use this opportunity to tear it down and replace the bearings, and while you are at it add a Delta 252 torque cam for better low end. GD -
The factory fog light's (dealer option) used a switch that looked like the rear wiper switch - it goes into the blank under the left side of the column. I would put a rocker switch there. It should control a relay for the fogs. GD
1985 GL Wagon front axles
GeneralDisorder replied to mfolsom's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sounds like you have got the EA81 and EA82 axles mixed up. You have an EA82, and consequently you need the longer axles. Camber cannot be changed with different axles. So if your camber was off, then most likely you forget to tighten something or reconnect something. When you are ordering parts, it's best to ask for later model stuff. For axles ask for an axle for a '89 GL (non-turbo) Wagon. This should prevent any confusion. GD -
Sealants, silicone etc for water pump etc
GeneralDisorder replied to MTSuby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I don't even use a gasket anymore. Just RTV and go. GD -
Pressure in the crankcase is normal - the PCV system is designed to take care of it. I would check that first. If the diagnosis in the add is correct (not likely unless it's been subjected to high boost), then it's going to need an engine rebuild at the very least. GD
87 Subaru GL-10: Injectors not firing
GeneralDisorder replied to bcool's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Just about any EA82T ECU should work - as long as it's for the right type of MAF (hot wire or flapper door). But if you are pulling codes, the ECU is probably ok. They don't usually fail unless someone connected the battery backwards (instant failure). GD -
No. Check your fuel pump. GD -
Rims for wagon...
GeneralDisorder replied to Indrid cold's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I like 15's myself. Larger tire selection. But if you aren't going too big, 14's are good too. Less rim, more tire is good off-road. Just make yourself a lift kit - it's really not that hard. SJR sells just the strut tower bits, and the rest are just simple blocks. GD -
Thoughts of Ultimate 2wd EA82
GeneralDisorder replied to bgd73's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Horray! Gentleman - we have common sense! Can anyone tell which poster in this thread I'm talking about GD -
Prepping Heads....
GeneralDisorder replied to Sonicfrog's topic in Old Gen.: 80's GL/DL/XT/Loyales...
What you will see is the head gaskets squirting out into an adjacent coolant passage with that kind of boost.... If it doesn't crack the head through to the cooling passage in the exhust port. At that kind of pressure, the combustion temps will be too high for the thickness of the exhaust port wall, and without multi-layer-metal HG's, the pressure will destroy the graphite based stock units. O-ring the block, copper HG's, studs instead of bolts so you can get proper torque, SERIOUS water intercooler, exhaust manifold temp sensors wired into a VERY good engine management system..... maybe you could do it without damage for a little while anyway. GD -
EA82T heads on N/A Bock
GeneralDisorder replied to Jub Nub's topic in Old Gen.: 80's GL/DL/XT/Loyales...
He says he's running the turbo and asked if the carb short block will handle it.... the answer is basically NO. At least don't expect it to be reliable in the long term. You may get 500 miles out of it, or you may get 5,000 miles, but sooner or later that high comp. is going to get you. Heads have nothing to do with comp. ratio's on the EA82's. It's all in the pistons. GD -
Zeke's '82 wagon thread
GeneralDisorder replied to zyewdall's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I would go for a little larger diesel. If you want diesel that's fine, but that engine probably will not cut it on the highway. Especially with the 5 speed D/R. The RPM's are all wrong for the gearing in the 5 speed, and if you add a lift and tires you will be lucky to get that thing to 45 MPH. The 5 speed is very tall geared. 5th gear at 60 MPH is 3,000 RPM, which I'm sure is past the power band of that diesel. Diesel engines have a very narrow power band, and something that redlines at 4500 likely has a useful power band between about 2000 and 2500 RPM. Past that and the power/torque drops off badly. This is why semi's have a tough time with hills. The power band can't rev up enough to get you to the next gear, so up a hill you are stuck going 15 MPH in 2nd..... etc. Take it from someone that's driven diesel trucks with engines too small for their own good..... It will work off-road but you will hate life on anything asphalt. What about the 4 cylinder diesel used in the old rabbits? Apparently you simply can't kill them..... and no electronics. They used them in the rabbit trucks too.... GD -
D/R 4spd Question
GeneralDisorder replied to newsoobdude's topic in Old Gen.: 80's GL/DL/XT/Loyales...
4th gear in the 4 speed is close to the same, but a little lower than 5th in the 5 speed. The jump from second to third is definately the biggest gearing problem for the 4 speed. You can cruise nicely in 3rd gear at 25 MPH with the 5 speed. Low range changed from 1.45:1 in the 4, to 1.59:1 in the 5. GD -
Prepping Heads....
Personally I just use a razor blade and some castrol super clean or carb cleaner. Then I use a good quantity of brake cleaner to make sure there is no residue of any kind on the surfaces. This is of course if I'm not milling them. I've found that almost every EA series head I've pulled off is warped (unless they have been milled already), and when they come back from my cylinder head guy they are REALLY clean so no worries. I razor blade the block, and chase all the threads in it. As long as it feels smooth and you can see metal, not old gasket debris, you should be fine. GD -
D/R 4spd Question
Third gear syncro is gone. It's relatively common on the 4 speeds. Your best bet would be to swap in the 5 speed. Better fuel economy, vastly improved shift linkage, and lower low range gear. There's not going to be any way to fix it without rebuilding the tranny. I had one that was the same way - I could get it in gear if I held it FIRMLY in 3rd and released the clutch while holding it. It would click hard and go in. Of course I bought the car knowing the tranny was bad, and replaced it immediately. GD -
Carbed blocks are 9.0:1 You can do it, but I would rebuild it first. This combination is known for not taking a lot of punishment. Several folks on here have tried it, and most have blown them up in only a few thousand miles. The extra comp. doesn't work well as the EA82's have weak heads and head gaskets. As for better internals.... the rods are bulletproof, you may be able to get some better pistons from RAM performance (and maybe a bit lower comp.), and it would be best to replace all the main and rod bearings too. GD -
Leaking Gas Tank Repair - Coating/Liner
GeneralDisorder replied to Anthenium's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Best way is to weld the tank. You drop it, clean the tank out very well, and let it air dry for a few days or so. Then you hook up a low pressure air source to the tank so that any welding sparks are blown outward. Clean up the rust, weld in new metal, and then treat the entire area with POR15, and paint it or coat with bedliner. Or you can just find a new tank. I wouldn't use any kind of sealant or epoxy. Easy enough to just get another tank, and removing it is probably one of the WORST jobs you will ever come across on a subaru. It would be worse than losing the family pet to have to do it twice.... It's trapped up there by the diff and diff hanger, it's full of dirt on top of the tank, and you need about 16 arms and 37 thumbs to get all the hoses and filler tube unhooked without totally ruining 25 miles of rubber tubing that's old and crusty from 20 years in there....... yeah.... can you tell I hate that job? GD -
ER27 Swap into 93 Loyale
GeneralDisorder replied to MoscowSubaruDude's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I understand what you are getting at, but the flange is superior. Larger diameter spreads out the load better, and it's easier to change the axle. No need to compress it to slide it off the splines, just remove the bolts and pull down. GD -
maybe my first soob
GeneralDisorder replied to autoaddict's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Comp. testers are about $9.99 at harbor frieght - invest in one if you are shopping for used cars. GD -
Not the entire car - just some select suspension components. It's nothing that the baja bug community hasn't already done many times over for a couple decades. There's many examples of super beetles with 25-30" of travel. Getting something like the H1's geared portal's going for a subaru will be a lot more difficult, but I have a few ideas there as well. I need to expand my machine shop tools but I know it can work - it's just going to be a matter of how many prototypes I have to break before I manage to get it right. GD -
To do a 5 lug, first you have to find an XT6 that's "partable"..... well just doing that is hard enough so I'll leave it alone. 85/86 rear struts are adjustable for height. You can turn the adjustment (lower spring perch) with a large pair of slip-joint pliers. Front..... well as mentioned without major mods or the 5 lug you are stuck. The KYB GR2's are good, and relatively cheap. Need a spring compressor for the front to change them. They sell cheap ones, but after using one I can say there is no safe place in all the land, and if you value all your appendages get one of those full-body blast suits the swat guys use for bomb handling. GD
