Everything posted by Sweet82
Give me an Explorer and I'll loose any Outback in no time. They are just two different vehicles. Not even in the same ball park. Comparing them is not realistic. However given a choice for a daily driver... I'd take the Outback with out a second thought!
I'd go for a rear skid plate before I'd worry about a rear brushguard? Seems to me a skid plate would serve you better and it could be a platform for adapting a brushguard? Just a thought? Glenn 82 SubaruHummer--reinforced rear! 84 GL Mad Max--loose rear! 01 Forester--411 rear!
Wish my Forester had a scoop! That's one good looking ride.
Just wanted to say hello.
Sweet82 replied to TheYeti's topic in Meet n' Greet. Your USMB Welcome Center
Welcome, Nice Outback, I had the same questions about your lift. So what's the next project? Glenn 82 SubaruHummer 84 GL Mad Max 01 Forester -
Your basic tune-up is like magic on those little engines. Don't forget the distributor cap, plugs and wires while your messing with it. You'll be back up to 70 in no time!:-\ Good luck, Glenn 82 SubaruHummer 84 GL Mad Max 01 Forester
Be nice to that Soobie! I use to "bank bust" back in high school but I found out the hard way too many times, that it was real hard on vehicles. Glenn
I put one on the Hatch just cause it looked cool! I don't think the car is capable of moving fast enough to actually deflect enough air to clean the dust off the rear window though? I didn't put my deflector back on when I built Summer..... Glenn, 82 SubaruHummer--not currently using rear deflector? 84 GL Mad Max--has defector but incapable of generating the speed necessary. 01 Forester--has fin to hide big dent from when the sky fell.
With three Subies you have already passed the "90 day probation period" requirements. Many members fail to aquire the required number of Subies within the time required for full membership. Welcome to the board. Glenn 82 SubaruHummer 84 GL Mad Max 01 Forester
How many have you meet and greeted.
Sweet82 replied to ezapar's topic in Meet n' Greet. Your USMB Welcome Center
Pssst...I can think of one more but I can't remember his name? -
A fun toy in the city but... I'd be careful with it if you go 4wding, you can easily loose control of your brakes/pedal. My Hill Holder broke/came unadjusted long ago and I prefer it that way. Off-road it can be tricky to deal with. My .02 Glenn 82 SubaruHummer--NO HH! 84 GL Mad Max--Unsure on it's status 01 Forester--Never had one ; )
My kids think it's cool when the Summer is warming up. It will blow smoke rings every few seconds in the cold air. Is this a bad sign? Thanks, Glenn 82 SubaruHummer (Summer) formerly 82 GL Hatch. 84 GL Mad Max 01 Forester
Who lives between MI and CA? Update First Post
Sweet82 replied to NoahDL88's topic in Meet n' Greet. Your USMB Welcome Center
Let me know if I-80 & Salt Lake City fit in your plans? That would be in Utah. Glenn 82 SubaruHummer 84 GL Mad Max 01 Forester -
Moustache Bars - who bends them?
Sweet82 replied to Matty B's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I think everyone has bent their bar to some degree. I think it's a normal part of using/abusing the vehicle. I reinforced my bar by adding a metal strip along the bottom side making the bar shaped like an upside down "T" if looked at from tire to tire. Pics in my photogallery. Good luck, Glenn 82 SubaruHummer 84 GL Mad Max 01 Forester -
Might try an on-line junkyard for the glass. I have chased many Forester items from ebay to the source then made purchases of the parts I actually needed from the yard--Cheap! Forest Ranger has lifted his Forester http://usmb.net/gallery/albuo97 Welcome to the board Glenn 82 SubaruHummer 84 GL Mad Max 01 Forester
Ratio of running vs. non-running subarus
Sweet82 replied to Snowman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Three and they all run fine :D:D Glenn, 82 SubaruHummer 84 GL Mad Max 01 Forester -
A crawl ratio is somewhat misleading when you apply tires. I have always been of the opinion that a new ratio must be calculated that accounts for tire size. Something like a Creep Ratio. In other words a ratio that matches engine rotation to not only wheel rotation but distance traveled. Just a thought? Glenn 82 SubaruHummer with a lousey crawl ratio compounded by a even worse creep ratio. 84 GL Mad Max 01 Forester
What he said! I have experienced similar problems in similar temps. Check your coolant level.
Even though I cleaned the plugs it wouldn't start...... Over the weekend I finally replaced the plugs... and it fired right up. Thanks Glenn, 82 SubaurHummer--now happy! 84 GL Mad Max 01 Forester--dented not sturred!
anyone gonna reply ?
Sweet82 replied to xtguy86@hotmail.com's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I refuse to reply until you have a clear topic posted! -
The stock tires measure out to about 22.5" by my tape. Why can't we get a 235/13?
There are wiring diagrams out there on the board. The lamp is listed as a "Center Lamp" on the actual switch that turns it on. 1982 was the last year it was offered. The purpose was for an aid to the bright lights or high beams. They have the thing wired to only come on when the high beams are on and only if the center lamp switch is turned on. As soon as you flip off the brights, the center lamp door closes and the light goes off. You can install the cyclops light on any early to mid 80's car by swapping the center section of the grill with an 82. Glenn, 82 SubaruHummer--used to have a center lamp. 84 GL--no center lamp yet...? 01 Forester--hummm....
Welcome to the board. There is probably more information on this board than Subaru has at headquarters. Glenn, 82 SubaruHummer 84 GL Mad Max 01 Forester
