11
Everything posted by mcbrat
does anybody have the length of an EA82 leading rod? (to the front control arm) how does it compare to a EA81 rod in length?
what do you think......
mcbrat replied to tailgatewagon's topic in Historic Subaru Forum: 50's thru 70's
eh.... just get one of these, and lift it. do away with all the cutting you'd have to do... -
actually, I was more interested in any length differences. I got a spare manifold from Syrinx today, and was comparing it to the length of an ea81 manifold, which was considerably longer, so I was wondering how people had modified a ea71 dually to fit onto an ea81. (thus also determining, that my dually is in fact from the ea81) I'm gonna be putting a weber on the ski wagon, so I wanted a spare intake to use for the weber.
you'll want a weber 32/36 and a soob adapter. there's a sticky thread in the off-road section dedicated to the webers....
are there any differences in the intake manifolds for the ea71, between the early ea71, and the "fat case" ea71 (80+)???
81 Brat Topper on an 85'?
mcbrat replied to gwsbrat's topic in Historic Subaru Forum: 50's thru 70's
if you cut 2" out of the legs that go to the wheel well on a gen1 rollbar, it will sit properly in a Gen2, but be a little narrower than a proper Gen2 bar... -
I've got 2... 5" lift... 3" lift... and one I used to have. 4" lift...
Gen1 (78-81) shells, will not fit Gen2 (82-87)... the Gen2's are about 4" wider. -
Will These Body Parts Fit On My Brat?
mcbrat replied to gwsbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
while it is true, that a '82 fender will fit, the antenna hole is on the driveres side (80-82) and the passenger side (83+) the '85 GL 3dr coupe (ea82) has different fenders. the only 85+ fenders that will work, will be hatchback or Brat. otherwise, you need 83-84 fenders (any model) -
acura brakes on a GEN 1
interesting.... would also be interesting to see what the rest of the acura front end looks like...... -
Just get some old chevy wheels. 3.5" backspacing. 3-4" outside the fender to fling mud everywhere these are 30x9.50x15's
anyone in Missouri?
mcbrat replied to Dr Subenstien's topic in Meet n' Greet. Your USMB Welcome Center
well under it's own power. Shawn put in a motor that really likes to move on the highway. here's a pic from a while back... http://www.ultimatesubaru.org/photos/showphoto.php?photo=7908&sort=1&cat=525&page=1 -
anyone in Missouri?
hey doc. one of the guys from Oregon is down near STL now. his Id is Syrinx. there's more MN guys now. a few new Iowa folks, but Iowa also lost a couple of people to CO and your old Brat that Shawn picked up went to me, and is now with Chef Tim in SD.... -
Rear Windscreen vertical metal supports on Brat
mcbrat replied to BobBrumby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ken had it right. to block cargo from coming through the rear window.... in the US, in 86/87 when we didn't get the jump seats anymore, they put short bars there for that purpose, and in fact did move the mounts spots inward, and closer to the window edge.... -
yes. I put a Electronic disty from a 83 Brat ea81, into a 1980 ea71 that originally had the ignitor
I took my skid plate off, and replaced the oil sender unit tonight. it was bent and dented glad I had the skid plate on, but I've gotta come up with something different now... also, I'm going back to a weber. the Holley did better than the weber on some of the downhill off camber stuff, and some of the uphill stuff too, but I just had to keep the revs too high, so there was no put-putting around.
Any Iowa City, IA owners here?
mcbrat replied to Syonyk's topic in Meet n' Greet. Your USMB Welcome Center
that a permanent move Russ? -
Westchester, PA Oct. 3-5
mcbrat replied to mcbrat's topic in Meet n' Greet. Your USMB Welcome Center
I'm not gonna have enough time to do anything.... coming in late afternoon on the 3rd. meetings all day the 4th, and 'til noon the 5th, then flying out again.... maybe next time.... -
12 inch lift pics, daylight pics of the new paintjob *Updated pics*
mcbrat replied to subarubrat's topic in Off Road
it started out with a 6-8" lift, so there were more clearance issues at first.... -
it was never sold here. that's the one that had the 1800 with dual carb intake.... actually, I believe the heads and cam were different as well, as it was a dual port exhaust. the intake and exhaust valve placement was switched on the heads (thus the cam difference)
looks like he gave a death squeeze to a constipated bird
well, wasn't actually me. this came out of a '83 Brat I bought and parted. only had 86k on it.... I heard it run briefly, but with a bad exhaust leak. it had gas tank issues, so I had it towed home then stripped it, so I never heard it run again until I put the motor into the 87 wagon I used to have, then had to pull it back out because of the knock.
the twisted sleeves.... cylinders 1 and 3 of a ea81 block... you can just barely see the access hole for the wrist pin on the left side of the sleeve cut-out... http://www.ultimatesubaru.org/photos/showphoto.php?photo=8142&sort=1&cat=530&page=1 and this is the other cylinder, where you can really see it better... http://www.ultimatesubaru.org/photos/showphoto.php?photo=8141&sort=1&size=medium&cat=530&page=1 this was a block I tore apart after it got a rod knock... the rod bearing was totally gone!!!
yeah, I sold a set of fiberglass gen1 brat flares to Garner....
all the 82's I've had it worked on hi's but my 80 wagon works on both or just low... it was standard equipment on the GL 4WD models (as listed in Austin's post)
