mcbrat
Administrator
Everything posted by mcbrat
  1. there's plenty of time Brian, just need to give up a little sleep.......
  2. I'm not sure if there's enough room to have a chain between the tailgate and the sides. the side hinge/supports are made pretty thin so that they fit okay. they are pretty strong too. to get the same strength, you'd have to go with a decent chain... to support the weight of someone on the gate while it was open.....
  3. should be fine. I use the 'Y' insteave of the 'S' version.... it's identical, except it has the "V Power" split....
  4. Here are your options the bottom of the page has a pic of chevy 4x4 wheels before and after drilling.. http://www.ultimatesubaru.org/80s/wheels2/wheels.html and this is what a brat with a 4/3 BYB lift kit and lots of hammering/cutting looks like with 30x9.50x15 tires on those chevy drilled wheels http://usmb.net/gallery/album93/tbnew2
  5. I use these... don't have to worry about losing the pin....
  6. yep. most beadlock wheels aren't DOT approved either.....
  7. Nicky, I can make you one. I have one in Illustrator format (.ai)
  8. yes, Subaru wheels... http://www.ultimatesubaru.org/80s/wheels2/14-subaru-rally-alloys-chrome-closeup.jpg
  9. one good point, is by having the cable mount mounted "on the carb" basically, if you add/remove carb spacers, the mount moves with it and keeps everything lined up.....
  10. got the centercaps on today. the SUBARU name area was blank, so I created a dual layer vinyl name insert
  11. looking at the front of the vehicle from in front of it.... Pos Camber = \ / Neg Camber = / \ Looking at the wheels from above the vehicle, front of vehicle pointed towards you (think pidgeon toed, or walking like a duck ) Toe In = \ / Toe Out = / \
  12. before I put the strut blocks on, I kept testing them in the mounts to see where it was hitting, then grind that area... kept going until it was the bolts that were stopping inward progress.
  13. the ones I modified are on my 82 Brat, and even with the RX springs, and the suspension cranked all the way up, my front tires look perfectly straight up and down. my rears have more pos+ camber because of the torsion bar tweak... I won't be able to easily identify if I'm wearing the outside edges, since they were already worn from being on MtnGrizzly before...... (it didn't have the modified strut tower)
  14. it's sitting in the street right now. I really like those wheels on it
  15. takea look at this diagram. on the 4/3 kit, I removed the metal in the red area with a grinder. this allows the strut tower bolts to slide all the way inward as much as possible. http://www.ultimatesubaru.org/80s/diagrams/strutlift.jpg you also need to be sure you do the proper amount of beating on the inner strut towers to allow the spring to move in as well. if you oval out the strut tower mount holes, you will also need to beat the inner fender enough to make sure the spring isn't rubbing... do you have your springs adjusted up as well?
  16. and the answer is..... before http://www.ultimatesubaru.org/80s/mick/gallery/86brat/before.jpg after http://www.ultimatesubaru.org/80s/mick/gallery/86brat/after.jpg after lightening up the image to see the tires better http://www.ultimatesubaru.org/80s/mick/gallery/86brat/after2.jpg I ended up going with 205/70r14 Dayton Quadra SE's for the tread pattern.....
  17. http://www.ultimatesubaru.org/forum/showthread.php?t=5468&highlight=trans
  18. yes, there are some defects in that page... it was an inherited page, and never got any additional work done on it.... usually when you see the higher numbers associated with an ea81, it's a type, and they should have meant the ea82. it's especially confusing for 85-89 when both engines were available.... I have a 86 Brat, and it's not noticeably different than any other ea81 I've had.... also, there has been alot of talk about the cam differences, but in the 84 Subaru Parts manual, there are only 3 different listings, the Brat other MT 4WD's all have the same part number..... not sure about other years.....
  19. the susp is up maybe .5" in front is all. it's a 3" BYB lift.
  20. DAve, that's the exact same pressure my 86 runs at too. has for the last 11k miles since '99. the oil pressure sending unit is less than perfect usually...
  21. Daytons were what was on it before. it's either gonna be another set of those or some Cheap Kelly Metrics.
  22. I've been leaning towards the 205's too... so what does european styleing on the tires mean? one of the sets I'm looking at list that as a bullet point......
  23. Boz, that's my 86 (86k miles too ) I've had it since '99 the wheels on it (14s) are not the ones that it will have. I have a set of Subaru Chrome 14" alloys that will go on it. This is my 'baby' that stays in a storage garage over the winter to keep rust away. it only gets driven about 2-3k miles a year (11k since I bought it in Oct. '99). I have my 82 for off-roading, so not interested in going real big. I had 205/65R15's on it previously (now with Archemitis). theones in the pic ar 195/70R14s....
  24. trying to decide what size tires to put on my 86... I sort of like the looks of this size.... I can go bigger, but not sure I want to..... and the answer is..... before http://www.ultimatesubaru.org/80s/mick/gallery/86brat/before.jpg after http://www.ultimatesubaru.org/80s/mick/gallery/86brat/after.jpg after lightening up the image to see the tires better http://www.ultimatesubaru.org/80s/mick/gallery/86brat/after2.jpg I ended up going with 205/70r14 Dayton Quadra SE's for the tread pattern.....
