Everything posted by nipper
97 outbact driveline noise
nipper replied to TONYB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSilly .... if the tires did not rotate the car wouldnt move!
4EAT noise under load
nipper replied to mulletkill's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRemove the accessory drive belts and find out.
Another "Cranks but doesn't start" thread
nipper replied to skoebl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave we checked the engine temp sensor?
nipper replied to TONYB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMAy be a wheel bearing. Sometimes you need to le a noise get louder before you know what it is. As long as you feel confident that it isnt TB. You may be able to hear a bad wheel bearing by spinning the wheel while off the ground and listening. It is possible that it needs a little side loading (the turn) to make the noise. Check the backing plates of the discs too.
AWD not working? Central diff problem?
nipper replied to bstone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBy any chance was the AC on?
nipper replied to TONYB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo all your tires match and are equally worn. How are the CV joints? The Viscous Coupling is sealed so gear lube has no effect on torque bind. The Test. Find a flat parking lot. Start off straight then turn the wheel to full lock and hold it there, the car should be moving at idle speed. You should be able to do this without lurching or having to fight the steering wheel. If you have either one of theese you have TB.
nipper replied to bstone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd the ever obvious, the oil level?
nipper replied to bstone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHeadgaskets dont make a noise when it goes bad, The squeel can be hideous Do all your accessories turn when the engine cranks? Do you still have the alt belt connected. Does it spin freely. Squeel noise is usually a belt squeeling, and we all know where the belts reside.
nipper replied to bstone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere goes all our fun
nipper replied to bstone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry this, it may help http://www.ultimatesubaru.org/forum/showthread.php?t=78467&highlight=tail+housing http://www.ultimatesubaru.org/forum/showthread.php?t=103860&highlight=tail+housing
Another Coolant Leaking Puzzler
Thats what i am leaning towards, is a crack someplace allowing water to escape. When you let the pressure sit overnight remove all the plugs and crank the engine, just in case coolant has leaked into the cylinder, hydrolock aint pretty.
Check engine light came on.
nipper replied to Highway_Star's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell thanksgiving is coming... One other thing, since it was fine then started loosing power, a partially clogged cat. Get yourself a vacum gauge. If it starts out high then slowly drops you have collapsed/clogged exhaust system, which means a cat.
Sometimes you need to let the car sit overnight or many hours pressurized. White smoke I cant judge, but put your hand up to the tail pipe and see if it smells like antifreeze or funky. Try a vacume gauge reading and see what that comes back as. When you check the plugs is one more cleaner then the others? You may still have a sneaky external leak which sometimes calls for a dye and blacklight to find. You can be loosing coolant from a manifold gasket.
nipper replied to bstone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIve heard from some people, some shops that the clutch packs have to be matched up to the old ones, others make no mention of it. DO a search here, there is an great writeup on how to do it.
nipper replied to bstone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust watching. I am going with tired clutches. Just unplug the tranny harness under the hood. Do you have any flashing dash lights on startup?
bad gas mileage
nipper replied to Meeky Moose's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThose codes are your answer.
Electric to manual windows???
nipper replied to subcyclist's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX`The master switch most likely needs to be cleaned.
new girl needs help w/strange noise!
nipper replied to Ace Ventura's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you feel the knocking in the floor, steering wheel or brakes. Look under the car and see if you see anything hanging down.
What evils shall we find in the New Jersey Pine Barrens
Bumpity, time is a waistin, and the outback board is making USMB look bad as there are 2-3 people comeing from there,
Rarest Old-School Subaru Part or Option?
SUbaru Justy dash clocks.
Crystal ball anyone?
nipper replied to krystolo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe two things that (well three) that will go without any real warning that will strand you on a subaru: Battery Timing Belt Alt Everything else the car will still move and will give plenty of warnings. If it make s you feel better at 290K Blu has only been on the hook once, and that was an Alt on a long road trip at 191,000.
nipper replied to skoebl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is a sprocket that has to go past the sensor to make an AC pulse, again, go get yourself a manual. You just take the measurements across the connector. Why get junk yard ones untill you test the ones on the car first?
nipper replied to krystolo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX"Q1- What kind of annual repair costs can I expect over the next few years? My goal is to get to 250k miles. Q2- Would doing an "overhaul" (changing all the hoses, valves, belts and doing a good inspection) help prevent any problems? Q3- How much would such an overhaul cost?" I don't see the word strand in there anywhere. Blu has nearly 300,000 miles on him and the original fill neck in the tank. Jsut because something pops up here a lot does not mean all the cars will have the issue.
Parts Car-What to keep??
nipper replied to subcyclist's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLets really shorten the list.Dont keep anything that is sheet metal or the carpet.
Got stuck in 4wd today.....
GOing in a straight line with 4wd is no problem, so if you live in a square state....
