25
Everything posted by nipper
how much limted weight for tow boat.
nipper replied to Suba_GL_87's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Tounge weight is easy, use a bathroom scale and for a boat it should read on a scale. The boat should have a weight tag hopefully someplace or ask a boatyard, same for the trailer. -
Blu has almost 300K on him. Nothing you have listed does not go under normal maint, though i would suspect an O2 sensor and not the cat. For 1500.00 where can you get a replacement car that you know that will not require another 1500.00 in repairs. Invest the money. When you hit 500K we will disguss putting her down
all that work to get her...
nipper replied to Lachlan's topic in Historic Subaru Forum: 50's thru 70's
Whale intestines with an ulcer. -
Ungodly grinding left front
nipper replied to OREchipmunk78's topic in Old Gen.: 80's GL/DL/XT/Loyales...
GD, But where does the mustard go ? -
The wheel bearing and it is probably chewing up the hub too. Do not drive this untill it is fixed, as from this point on it will just cost more to fix. -
Classic Subaru Meet - up here ?? PA?NY?NJ?CT?NE?
nipper replied to moosens's topic in Meet n' Greet. Your USMB Welcome Center
Best to do it in the fall past peak tourist ($$) season. Also not all of us have AC The justy should be on the road in a few weeks -
Tire cupping, the most likely issue on a car with 100K on it is a bad strut. Wheel alignment will not cause this issue. What is happening is that the tire is bouncing up and down on the road. This can not be seen as it is just chainging the load on the tire. Random cupping will be a strut. Cupping in the same spots will be a wheel balance issue. This is easy enough to diagnose as only a few things cause it. A bad wheel bearing will not. Make sure the tries are mounted in the proper direction. This sounds silly b ut most tires are directional now. Cheap tires can cause it too.
I will say this then take my ;eave as these posts are confusing. There is no such thing as doing half a rebuild on a auto tranny. You have hard parts damage. Torque bind can either lock up the driveline or "go away" because the clutches are glazed. rebuilding an auto is different from a manual, however as I always say, it is your money.
Cross your fingers you are blessed. The lockups sound like everytime the car wanted to shift, there was not enough fluid to sequence everything. When two gears are engaged at the same time clunk and lockup occures and the car will not move. Check linkages. but..... If nothing wrong linkage wise and no reverse tranny is busticated.
using oil
nipper replied to 4play's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
HOw long since the cam seals been replaced -
The brown dust is normal on an older subaru clutch. Why did you not go to the very first thing to check and not the very last. KISS (keep it simple -----) You are low on refrigerant, as you have a leak someplace. The AC has two pressure switches, one low and one high. They both have to see normal pressures to operate. You have low refirgerant. The refrigerant is liquid at first, as it gets hotter it expands and will not become liquid again due to a lack of refrigerant. If it was a clutch issue they usually don't engage at all. The fact your does (especially for 20 minutes) says it is fine.
