Everything posted by nipper
Squealing noise
nipper replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX"the belts seem to be tight" If what you think was true, he could easily reproduce it in his driveway.
Squealing noise
nipper replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXonly if it was "Lately, if I really stomp on the gas, a massive squealing noise comes from the engine and though the RPMs go up, the car barely moves"
what is this red light?
nipper replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe mode shuts off the alarm for the car wash, the mechanic, and the Valet incase they park the car with the keys in it.
nipper replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOne thing we have learned from Bugs Bunny DON'T PUSH THE READ BUTTON!
Rarest Old-School Subaru Part or Option?
The no rust option?
Squealing noise
nipper replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are no "Clutch Tests". There is just one to see if the clutch is going, and thats when a car can move under it's own power. In essence everytime you step on the gas and your rpms go up and the car does not go faster that is a failed clutch test. That screaming noise you hear is what is left of your clutch destroying your flywheel. Thats is metal against metal noise.
90 Legacy 4EAT problems
nipper replied to 93Newbaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou fried your transmission. With fluid that low i am surprised you have any of the clutches functioing at all.
nipper replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt is an alarm. Someplace on the car, usually the left kick panel shold be a switch for valet mode. This isnt the kind to push for valet, i have one of those in the justy.
Squealing noise
nipper replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYear? Mileage? Manual? If it is manual it is a fried clutch, if not we need to dig into it more.
Fix or Dump?
nipper replied to mikekerstetter's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDealer or not, they all have "boat payments" Find another shop as they are awfully high. Exhaust leak should be fixed because the way subarus are set up, the HVAC will suck it into the car. Most likey it is the flex joint or a gasket. Mine was the flex jont and I had it welded.
Fix or Dump?
nipper replied to mikekerstetter's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo your brain had pre-ignition? and where is my coal!
What does it mean when your obd2 stops sending Intake Air Temp data to your scanner?
nipper replied to Legback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou had way too much Christmas cheer. that year doesnt have one (I have one parked infront of my house so you can trust me on that)
Fix or Dump?
nipper replied to mikekerstetter's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGross he is way over that 100K warrenty. 1800 somebody is behind on his boat payments. What source for the replacement parts have you used ? The fuel smell I would just replace all the little rubber hoses. The alt, well they get tired. The cat? How was that decided, I woudl have replaced the O2 sensor with an OE one first and see what happened.
90 Legacy Out of idea's.
nipper replied to Eljefe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhrmmmm For giggles chek the alt output. What is the temp outside. WHat happens if you disconnect the fan switch. Is the radiator flowing properly
Good deal, Will it work?
Check out this engine completely. Remove timing covers, make sure all the pistons are there (no joke). That is juts too good a price. DO a leakdown test if you can.
- Rarest Old-School Subaru Part or Option?
The Convertable?- Horrid squealing related to steering rack...
nipper replied to efseiler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI curse this belt.- What does it mean when your obd2 stops sending Intake Air Temp data to your scanner?
nipper replied to Legback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think ( I might be wrong ) DOHC use the MAF sensor for this duty. Turbos have them, not too sure about SOHC engines, I think it depends upon the year. Not all cars have IAT sensors. You THINK you saw it, I think you may have not.- Car has no spark again
nipper replied to plodder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell i did not want to suggest using a carbon based fuel source for anything drastic other then heating the wires. Goodness knows how those things can easily get out of control- Heater core blew out!
nipper replied to 2.5GL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe yellow harness and plugs are the air bag wires. If it is in your way unplug it. if in doubt unplug it. The only nthing I would do because I am paranoid is cover the connector with electrical tape.- Car has no spark again
nipper replied to plodder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor giggles... have an extra ECU around?- Heater core blew out!
nipper replied to 2.5GL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX4. Main Harness A: REMOVAL AND INSTALLATION 1) Turn ignition switch off. 2) Disconnect ground cable from battery and wait for at least 20 seconds before starting work. i can meail you the SRS section. This is for a 1998 but they are all the same I checked- Whats broke on your subaru lately.
Power Steering Rack- no speedo
nipper replied to shin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXElectricity is an evil and confusing God ... it has to be spun in the car to really check it and read the AC pulse. Glad it is fixed. - Rarest Old-School Subaru Part or Option?
