nipper
    25
Everything posted by nipper
  1. I prefer the tried and true, and safer method. Let the shop use an emissions sniffer to look for products of combustion in the radiator. nipper
  2. Interesting, as that is only 1/2 the test for any sensor of that type. It is a standard testing procedure engineering wise. nipper
  3. Clutch staying on the floor is either an assist spring or the hydarulic clutch itself (don't remeber if there is an assist spring). All seals from subaru. Valve covers can be aftermarket, spark plug bucket seals from subaru. Headgaskets SUBAUR ONLY! Waterpump anywhere. theromstat subaru PCV valve Tming belt any brand name. Tensioners and idlers yes BTW when you take the engine out the very first thing you do is flush the radiator. Antifreeze and goo can clog a perfectly good radiator when exposed to air.
  4. an FYI, never use tap water in an aluminum engine. Use 50/50 pre,ix or demineralized water. I go for the sooby cap first, then a clogged radiator second. nipper
  5. Odd thats now how you test a hall effect sensor. I cant find it in the FSM (clue me into the section) The resistance is the first test to make sure there are no opens in the sensor, there are only two wires so it is easy. The pattern will be 1-11-1-111-1 . Do the resistance if it fails that you are done. It is possible to loose a tooth on the reluctor (GEAR) and that will keep the car from running. It will be an all or nothing test otherwise.
  6. It is a pulse of high/low AC signal. It does not happe an regular intervals as the signal gear is refernced to specific rotations. Look at the haynes manual even if it is not your year, as all the cam and crank sensors work the same way.
  7. Resistance is one way, but you need both tests. You are looking for an AC pulse as the engine is cranked (which is the FSm way of testing it). It creates a pulse as the toothed "gear" passes under it.
  8. C- says it right on it "cruise control Unit" D - is an antenna to something B - i can hunt down on the FSM if no one has an answer. Leave the green and black connectors alone. they are for diagnostics and reflashing the control units. Cruise control not workind 99% of the time is a bad brake light and or clutch switch in a subaru. nipper
  9. YAY
    Joe Klein
    103 Evans Ave
    Oceanside, NY, 11572.
  10. Sure it does. The more you make of something the cheaper it is. Only 5% of any given AWD/SUV (excpet Jeeps) see any offraod, and even less see real offroad in the USA. Kind of hard to justify making 100 or 200 units (more likely less then 100) for what they would have to charge in the USA. ALso it would affect crash tests and function of the air bags so there would be a huge liability concern. nipper
  11. "will check my options then, here in italy, parts are not as cheap and harder to get." Once again he is in ITALY. He said parts are hard to get and very expensive, he is not in the states where things are cheap. If he was here i would not have mentioned the EU or health and saftey. And in my expierience if money is tight and edpending upon the make of car, repolacing a clutch that is bad is just a bad clutch. One can see when removing the clutch if the bearing is bad or the seal is bad.
  12. It sounds more like the pump. The pulsation is matching the rotation of the pump. There is probably a bad gear in the pump. A rack would be stiff when cold when trying to turn the wheel (and I mean winter cold) or binding. It wouldnt be pulsing.
  13. Except he is in Itally, and i dont know what the nanny state/EU/Health and saftey will allow him to do. I wouldnt be afraid of using a used clutch either. nipper
  14. I would go ahead and replace just the clutch, or if you can get it the clutch coil. I do not agree on a subaru that if the coil burns out the compressor isnt far behind. Compressors last much longer, so just replace the coil/clutch. nipper
  15. no need to shout. Exhaust leaks can be of two types. One that opens up when the car gets warm, or closes up when the car gets warm. Ahev you noticed if the light comes on while the car is warming up, when it is cold, or after it is warmed? Or just havent noticed (not a biggy).
  16. i have seen many so called "Subaru experts" and have has private msgs, and as soon as they say they are an expert, i tell them to run the other direction. This guy is nuts. Steering is as importatn as brakes (wonder if he ever pyts P/S fluid in the brakes to stop the fluid from absorbing water - same logic - none). Just replace the rack. nipper
  17. the do run run .... Do you wnat them to do this all the time or do you want the option of turning them on with the ignition switch off.
  18. Wooo slow down. I see many things wrong with this, first how many miles on this car. Have you EVER done a tuneup on this car? plugs wires PCV vlaves Fuel Filter Ait Filter. Why did you buy a used exhaust system and Cats. it sounde to me, since you passed CA emissions, you do not need cats, you most likely need a new O2 sensor.
  19. No no no it has to be A B C or D None of the above was NOT an option. hehehehe rear wheel bearings are fairly robust, which is why sometimes we forget about them, including me. nipper
  20. You ALWAYS need to do Maint on a car, doesnt mater if it is highway miles or around the block. I bought one of those "all highway miles so only needed once a year oil changes" cars. the engine blew 10K after i bought it. nipper
  21. Im going with again a driveshaft. Next time it happens put your hand on the center console, it should feel strongest there. http://www.driveshaftspecialist.com/ Thats who I would recomend. Many have used them with no issues. Now sometimes time is your best diagnostician. The driveshaft is no where near falling out of the car yet. If it is the driveshaft, soon the speed it starts at will drop to 60, then 55, then 50. If it does drop down (and it will) you have your answer. nipper
