Everything posted by nipper
And he is home ...
Has no idle, needs a mid-pipe (anyone know a source?), abdly corroded wiper connector (may the only place I have to do surgery) Needs a timing belt (original) some body work, minor dents and minor rust. Valve cover leaks. Going to rebuild brakes. Will get a rebuilt carb. I am great at rebuilding them, but no space and sometimes it just pays to spend the bucks. Going to relocate the oil filter as there is just too small an oil capacity. nipper
And he is home ...
As Justy says goodbye to his old home. (damn that trailer was alot longer then I expected) Blu sniffing the Justy's rear bumper I think there is a spec of dirt under there somewhere, yes that is all original including the shiney parts
89 Justy Exhaust
Justy is home. He has a rotted out exhaust pipe right behind the flex joint. Anyone have a source for this?
Steering rack thrashed???
nipper replied to JimmyJam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPlease only make one post, as it confuses everyone when there are two covering the same subject. nipper
Oil pressure light won't go off?
nipper replied to Tommymc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXStart with the sender and work your way up to the complicated (expensive) items. in the mean time dont use the car. if the sender doesnt do it buy a cheap mechanical oil pressure gauge and see what it says.
Help! Steering wheel locks 90degrees off center??
nipper replied to JimmyJam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAt 285K i would replace the inner tie rod ends and ball joints wheather you need them or not. It is amazing how such minute play in the inner tie rod ends can cause issues. I replaced mine, they didnt even have freeplay but they moved around freely in the ball socket. the new one was a bear to move, but it made all the difference in the world. The groan can be balljoints. Racks dont clunk when they go bad unless they are loose. If it was my car (i did it at 230K) i woudl just rebuild the front end first. the steering wheel lock is wear and tear. It isnt worth digging into as long as it works.
automatic seat belt retractor stuck
nipper replied to Fordman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat is under warrenty is the web belt only. The rest of the mechanisim is not under warrenty. nipper
'99 Legacy Outback engine flutter... HELP!
nipper replied to darrenbrigman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf there is no cat no matter what trick he uses it isnt going to work.
noise after 120K service and timing belt replacement
nipper replied to flapjax's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA stethascope can be awooden dowel put to your ear. Best to do this with the accesory drive belt off the car can run for this test without the alt as it will take only 15 minutesnnwill also give you safer acess to the timing covers, This method works veyry well. This is something the shop should have done. nipper
nipper replied to darrenbrigman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs hard to take O2 reding seriously at this point as A- he has a miss B- he has no cats, meowless he is. nipper
nipper replied to flapjax's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTake a tech with you an dpoint out the noise. I have afeeling this will turn out bad. With the car running look at the main pulley. If it has any wobble at all tow it back to the shop. Remove the drive belt for the accessories and see if the noise goes away, oor spray them with water while it is running and see if the noise changes or go aways. Did they replace the waterpump? Are you SURE the replaced the tensioner and idlers? ARe you secure and brave enough to do the stethascope test? Is this a tinny sound or a deep sound? Is the oil full? Where does it soundlike it is coming from, front or rear of the engine. Manual or auto? This can be a coincidence so i am not ready to condem the shop yet. nipper
nipper replied to darrenbrigman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPay no attention to the Cat codes, you have no cat, so ignore it, as you can not do anything about it. Have you done the water test? Spray a mist of water on the coils in the evening and look for sparklies? Thast where i would start. Did you use subaru wires? What kind of plugs did you use?
'04 Outback performance vs. '99
nipper replied to garwood1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt is a heavier car then the 99. It also has a differnt gear ratio most likely. Every year newer on a car is another heavier model. The consumers want more and expect more every year. form the 99 to the 2004 crash standards may have changed and added weight. nipper
Timing chain?
nipper replied to rteeples's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo you dont. http://www.cars101.com/subaru/subaru_maintenance.html Camshaft Belt (timing belt) 2.5L 4 cylinder (note: 6 cyls have timing chain, should not need replacement)
Any reason a front axle nut should come loose?
nipper replied to mr.radon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you replace the washer behind the nut? (I got 3 hrs sleep so i apologize for being absent minded). There is a washer/spacer/thingy that is supposed to be replaced. nipper
TV static sounding noise between 2000-2500 rpm
nipper replied to theouthouse666's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHeat Sheild. this is common on most cars. Just use a hose clamp to fix it. nipper
Brown Stuff at the Bottom of Overflow Container??
nipper replied to Petersubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck to see if water is oily. If not its your dying water pump and not dying a full flush that is doing it. Aleays replace a waterpump, idlers tensioner and timing belt together, otherwise Mr Murphy shows up. nipper
97 Outback mystery part
nipper replied to AEROCOOK's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSince you know exactly where the part came from and I dont, give me your email and I will send you the FSM for the tranny from a 1998 and then you can find it. nipper
Maybe I'm stupid , but . . . . .
nipper replied to curtisbad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd thats the technical name too!
nipper replied to curtisbad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt is also called the Jiggler Valve. nipper
Engine temperature gauge fluctuates
nipper replied to ktdenali's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust replace it not something to cheap out on unless you like the idea of chainging headgaskets. nipper
3rd Timing Belt in 10,000 miles
Yup replace everything and insepct the pullies for wear. nipper
Help ! ! ! !
nipper replied to curtisbad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX!st, how did you fill the cooling system You may have a air pocket in the cooling system. If not then Head Gasket. Clogged raditor would overheat or run hot depending on load, OP says it is always overheating.
nipper replied to ktdenali's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLets do the sinple things BEFORE somone screams HG. Temp gauge is working fine (why do people blame the gauges?) Replace the thermostat with one from subaru and the radiator cap. Never doubt the temp gauge as it can get you in expensive trouble weather it is right or wrong. It sounds like your T stat is only opening 1/2 way. nipper
clutch needs adjusted or replaced?
nipper replied to bkvail's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell so fare almost everone is saying no matter what the clutch has to come apart. i dont really suspect hydraulics, but its a possability, especially with a 18yo driver + the mileage. nipper
